2 part question about FR catch can/transmission cooler
This is a discussion on 2 part question about FR catch can/transmission cooler within the F150 Ecoboost Performance forums, part of the F150 Ecoboost Garage category; Ok first situation I installed full race catch can on 2016 3.5 xlt it works fine (I guess) install was simple I've triple checked all ...
Results 1 to 10 of 25
Thread: 2 part question about FR catch can/transmission cooler
    Ecoboost Jr Member C mobley's Avatar
    May 2017
    Mobile Alabama
    34
    35370
    Ok first situation I installed full race catch can on 2016 3.5 xlt it works fine (I guess) install was simple I've triple checked all connections no leaks but it's throwing a 204something code. My sct resets it it stays off then comes back intermittently. Is it ok to drive it when that's going on? Second part is there a transmission cooler i can add to aid my oe one in keeping my transmission cooler than 210 when stuck on a bayway in heavy traffic? Thanks.
    Rookie itsbob's Avatar
    Jul 2016
    Dameron, Maryland
    19
    17553
    Quote Originally Posted by C mobley View Post
    Not sure what your code was but I installed a UPR catch can and after install I noticed arrows on the tubing.. had to call to ensure I had all the arrows/tubes installed in the right direction.. thought I did but had a nagging feeling. All was ok, but if your getting idea post install and none prior that would be the first thing I checked.
    Sent from my SM-G955U using Tapatalk
    May 2017
    Mobile Alabama
    34
    35370
    This kit just has what looks like fuel hose that comes with it. I did save all the parts and didn't drill out the check valve it may be best to just put it all back in.
    Jul 2016
    Dameron, Maryland
    19
    17553
    I would just to see if the code goes away.
    5,538
    1836 times
    It's okay to drive, but the remote start won't work. The crankcase flow sensor is seeing more flow than it wants to. Call full race and let them know. When I called them about it they said they have not heard of this being an issue. If they don't know, they can't fix it.
    The code won't go away. It'll come back every time. Mine always does within 30 miles.
    The code is p04db
    Sent from my Moto G (5) Plus using Tapatalk
    5,538
    1836 times
    The code is p04db
    Rookie wlee32's Avatar
    May 2017
    Atlanta
    10
    35426
    I have this code as well.
    5,538
    1836 times
    You can tune it out, or live with it, or try swapping to another mfgr can and see if it still does it. Afe includes a reducer for the nipple on the inlet pipe to prevent this code with their "cai". I'm curious if the same thing can prevent the code with the catch can.
    However, it's going to impede the low through the can system. Is it worth it?
    Ecoboost Veteran ptown's Avatar
    370
    99 times
    Quote Originally Posted by itsbob View Post
    Full race catch can doesn't use any valves at all.
    Jul 2016
    Dameron, Maryland
    19
    17553
    Quote Originally Posted by ptown View Post
    That there could be the problem couldn't it?
  1. OEM Aux Transmission Cooler Install Question
    By RMINC in forum F150 Ecoboost Towing
    Last Post: 03-02-2017, 04:48 PM
  2. Transmission Cooler damaged - Transmission Low on Fluid - Damage???
    By defiant1 in forum F150 Ecoboost Problems
    Last Post: 02-02-2017, 09:02 AM
  3. upgraded transmission cooler?
    By jdm1904 in forum F150 Ecoboost Performance
    Last Post: 12-16-2016, 03:50 PM
  4. Transmission cooler?
    By I am Back in forum F150 Ecoboost Towing
    Last Post: 09-18-2015, 09:34 PM
  5. Replies: 10
    Last Post: 07-09-2014, 09:45 PM
