Speaker problem
Speaker problem
This is a discussion on Speaker problem within the F150 Ecoboost Electronics forums, part of the F150 Ecoboost Garage category; I had my drivers side front speaker going in and out. I talked to a friend that has an 11 F-150 and he has the ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Speaker problem
    Ecoboost Sr Member skeet's Avatar
    Dec 2012
    The Thumb of Michigan
    54
    110
    10 times
    Speaker problem
    I had my drivers side front speaker going in and out. I talked to a friend that has an 11 F-150 and he has the same problem. I took it to my Ford dealer and asked them about it. Service Manager said they had one on order for someone. He took my VIN and ordered me one. Had it replaced today in under and hour. Anyone else have this problem?
    Jcraft1980 likes this.
    Administrator STdan's Avatar
    Nov 2012
    Austin, TX
    887
    234 times
    Nope, so far so good. I guess something else to watch out for though. Glad they got it fixed for you quickly.
    Rookie Dam Electrician's Avatar
    Dec 2012
    Onalaska, WA
    16
    67
    Yes both rear speakers on a 2012. Intermittentant problem be suprised if it is the speakers.
    Ecoboost Veteran TraciInTexas's Avatar
    Sunny South Texas
    491
    788
    163 times
    "Intermittent" would indicate a short of some sort. Connections/wiring.
    Ecoboost Jr Member HAA2011's Avatar
    Jun 2013
    Louisiana
    34
    1283
    I've had the exact same problem with my driver side front speaker. 2011 Screw XLT. Glad its still under warranty, barely.
    Rookie enzzone's Avatar
    Victoria, BC
    1895
    2011 Ext Cab - I have had the same problem with driver's side front speaker. I can replicate the problem by wiggling the door wiring bundle with the door open. Had it into the dealer and they cleaned the contacts which helped for about a month. Taking it back in soon. I don't care if they have to solder the leads onto the speaker, I just want it fixed! Has anyone actually had their dealer resolve this problem?
    Eco-Beast akmedic77's Avatar
    Feb 2013
    South Central Alaska
    2,352
    421
    533 times
    Not sure the number of the TSB, but I did see this on another forum. Instructions for the tech were to check the connections and fix if required or replace the doors wiring harness. I'll check and see if I can find it.
    Sent from my iPhone using Tapatalk 2
    2013 Oxford White FX4 CCSB | 402A | 3.55 | S&B CAI & BBK TB | Leer Cap w/DZ TG Assist | DD 3.0 | Tint, Brow, Pinstripe | Interior LED Swap | OEM HD Flaps | Cold Weather Front & Winterization | Arc Rite Brush Guard & Rigid Lighting| JW Speaker 6146 Fogs | Build Thread
    2008 Black Slate Pearl Mariner Premier | 303A | Moon & Tune | PIAA Heads/Fogs | Cold Weather Front & Winterization
    Feb 2013
    2,352
    421
    533 times
    FRONT DOOR SPEAKERS—INTERMITTENT OPERATION—DEARBORN TRUCK PLANT—BUILT ON OR BEFORE 12/1/2011
    FORD:
    2010-2012 F-150
    The article supersedes TSB 12-10-18 to update the Part List.
    ISSUE
    Some 2010-2012 F-150 vehicles built at the Dearborn Truck Plant and built on or before 12/1/2011 may exhibit an intermittent operation of the driver and/or passenger front door speaker(s). This may be due to a poor pin connection at connector(s) C219 and/or C237, or a faulty door speaker.
    ACTION
    Follow the Service Procedure steps to correct the condition.
    SERVICE PROCEDURE
    1. Disconnect the connector C219 or C237 located at the lower A-pillar(s).
    2. Inspect cavities 1 and 2 on the female side of connector C219 or C237 for terminal pins not seated. Refer to Wiring Diagram Cell 150-1 for connector views. Are the terminal pins 1 and 2 seated in the connector?
    a. No - remove door trim panel and replace the front door harness. Refer to Workshop Manual (WSM), Section 501.05
    b. Yes - reconnect connector(s), proceed to Step 3.
    3. Replace front door speaker(s). Refer to WSM, Section 415-00.
    Ecoboost Sr Member rb1boxer_3's Avatar
    89
    2045
    I have this same problem on my 2013 xlt still waiting for the dealer to fix it. One guy said its mr hearing things cause he didn't hear it.
    Ecoboost Regular aharmon5050's Avatar
    southern il
    118
    2141
    15 times
    ive had all the door speakers repalced n my 12 eco screw. all were done under warrenty, they all was intermitting,
    2012 f150 ecoboost SUPERCREW
    20% tint all way around
    k&n drop in
    bed liner
    black tool box
    18/9 xd 809 machine wheels -12 off set
    33/12.50/18 toyo open country mt
    2 inch day star leveling kit
    2 inch pocket style fender flares painted to match
    OTHER TOYS
    2013 Can Am Outlander 1000XT Yellow
    OEM Fender Flares
    can am factory beadlocks with 27inch big horns
    OEM Fully Belly Skid Plates
    ODI grips
    highlifter lift springs
    OGIO rear rack bag
2013 ford f150 speaker problems
2014 f150 speaker issues
2014 f150 speaker problems
2014 f150 speaker static
2014 ford f150 speaker problems
f150 speakers not working
ford f150 speaker issues
