All-New Ford F-150 2.7-Liter ECOBOOST V6 Engine Released
This is a discussion on All-New Ford F-150 2.7-Liter ECOBOOST V6 Engine Released within the F150 Ecoboost News forums, part of the Ford F150 Ecoboost category; ALL-NEW FORD F-150 2.7-LITER ECOBOOST V6 ENGINE DELIVERS V8 CAPABILITY AND PERFORMANCE Tougher, lighter 2015 Ford F-150 welcomes two new engines to its four-engine lineup, ...
Results 1 to 10 of 13
Like Tree7Likes
Thread: All-New Ford F-150 2.7-Liter ECOBOOST V6 Engine Released
    Administrator NickJ's Avatar
    Jun 2013
    104
    1383
    111 times
    Tougher, lighter 2015 Ford F-150 welcomes two new engines to its four-engine lineup, providing choices to meet almost any customer need – from hauling tools to towing trailers
    High-output 2.7-liter EcoBoost® with standard Auto Start-Stop broadens engine lineup by providing mid-range V8-like towing capability of 8,500 pounds, payload of 2,250 pounds, 325 horsepower, 375 lb.-ft. of torque
    Standard 3.5-liter V6 engine with twin independent variable camshaft timing delivers impressive power and efficiency with towing of 7,600 pounds that can't be beat, 1,910 pounds of payload, 283 horsepower and 255 lb.-ft. of torque
    Use of high-strength steel and high-strength, military-grade, aluminum alloy plus smart engineering saves up to 700 pounds, improving power-to-weight ratio and allowing for gains in towing, performance and efficiency
    With its new 2.7-liter EcoBoost® with standard Auto Start-Stop and new 3.5-liter V6 with twin independent variable camshaft timing, the 2015 Ford F-150 resets the bar in light-duty pickup truck performance, capability and efficiency.
    "The 2015 F-150 is the most capable F-150 yet, while shedding up to 700 pounds," said Bob Fascetti, vice president, Powertrain Engineering. "These two new V6 engines – the 2.7-liter turbocharged EcoBoost and normally aspirated 3.5-liter Ti-VCT – set a new standard for Ford for capability and efficiency."
    2.7-liter EcoBoost power
    The high-output, twin-turbo 2.7-liter EcoBoost V6 features an entirely new design that delivers power and performance in a strong, smart package. The engine produces 325 horsepower and 375 lb.-ft. of torque – improving the power-to-weight ratio of the 2015 truck by 15 percent over the 2014 5.0-liter V8-equipped F-150 with similar torque output, thanks to vehicle light-weighting.
    The 2.7-liter EcoBoost 4x2 has a maximum payload rating of 2,250 pounds and maximum tow rating of 8,500 pounds, ideal for meeting mid-range capability needs.
    Boosting 2.7-liter EcoBoost fuel efficiency is the debut of standard Auto Start-Stop technology for F-150. This technology, specially tuned for truck customers, shuts off the engine when the vehicle is at a stop. When the brake is released, the engine restarts quickly. Auto Start-Stop helps reduce fuel consumption and emissions when the truck is stopped and the engine is off. The technology is off when towing or in four-wheel-drive mode.
    The 2.7-liter EcoBoost engine also features Ford's first use of a compacted graphite iron cylinder block in a gasoline engine, the same material used in Ford's 6.7-liter Power Stroke® turbo diesel V8 in Super Duty trucks. The composite CGI/aluminum cylinder block saves weight while providing strength where it's needed most for durability.
    Advanced technology, power and efficiency combine to create an engine for F-150 that boasts more than twice the horsepower, torque and towing capability of the Toyota Tacoma midsize pickup truck with identical displacement 2.7-liter four-cylinder engine.
    Ford testing shows the 2.7-liter EcoBoost also outperforming Ram 1500 3.0-liter V6 EcoDiesel and Chevrolet Silverado 1500 5.3-liter V8 while towing a 7,000-pound enclosed trailer up Davis Dam in Arizona. This is the same grade the Society of Automotive Engineers uses for its J2807 towing testing standards, which the 2015 Ford F-150 will follow.
    3.5-liter V6 tuned for responsive power
    Thanks to vehicle weight savings, the standard 3.5-liter V6 with Ti-VCT offers a 5 percent improvement in power-to-weight ratio over the larger 3.7-liter V6 in the 2014 F-150, with better fuel efficiency and performance.
    The 3.5-liter V6 produces 283 horsepower and 255 lb.-ft. of torque. The engine has a maximum payload of 1,910 pounds and a maximum tow rating of 7,600 pounds – unsurpassed for standard V6 light-duty pickup trucks.
    Designed for impressive power and durability, the 24-valve 3.5-liter V6 features a valvetrain with direct-acting polished mechanical buckets with twin independent variable camshaft timing for impressive torque across a wide rpm range. Six-bolt main bearing caps, a fully counterweighted forged steel crankshaft and cast exhaust manifolds are designed for heavy-duty operation.
    Both the upper and lower intake manifolds of the 3.5-liter V6 are tuned for responsive power, and both the intake manifolds and cam covers are composite-formed to reduce weight. The die-cast aluminum cylinder block features bay-to-bay breathing to reduce internal pumping losses, while a deep-sump oil pan contributes to extended oil-change intervals.
    Advanced materials save weight
    Extensive research by Ford engineers led to the use of more advanced materials on the 2015 F-150 than found in previous trucks. Military-grade aluminum alloys make the new truck's body lighter, stronger and more resistant to dents.
    Overall, F-150 is up to 700 pounds lighter – helping the truck tow and haul more, accelerate and stop faster, and operate more efficiently than the previous F-150. High-strength steel in the frame and high-strength aluminum alloy throughout the body produce an inherently stiffer truck with greater dent and ding resistance. The aluminum upper body sits on a fully boxed ladder frame with more high-strength steel than ever to make it stronger yet lighter.
    In addition to the new V6 engines, the all-new 2015 F-150 offers the proven 3.5-liter EcoBoost and the 5.0-liter V8 with Ti-VCT, providing a comprehensive, capable and efficient engine lineup to meet the specific needs of Ford truck customers.
    2015 Dream and 4Nines like this.
    Ecoboost Pro spyder982's Avatar
    873
    1958
    175 times
    Haha it beat out the. 5.3 in a towing test????? That's amazing and a video is like to see
    2015 Dream likes this.
    Gold Supporting Member Pinero61's Avatar
    Jun 2013
    Houma, Louisiana
    9,643
    1545
    3499 times
    Evodiesel too
    SSG Outdoors
    2013 FX4 S-crew
    FBO, Full-Race turbos, Tru-Trac, 4.56 gears (power numbers to come soon)
    Full Raptor Suspension w/ upgraded components
    Fiberwerx fenders with custom paint
    Rigid LED lighting
    Retro-Shop heads and Rigid DOT fogs
    Rockford Audio
    Method wheels w/ 37" ATZ P3 tires
    Need parts for your build? www.stage3motorsports.com
    Super Moderator Kc311's Avatar
    Texas
    2,431
    801
    1272 times
    Lol poor ecodiesel.. Why compete with the 3.5 EB when the 2.7 EB is still more efficient
    ford4thot likes this.
    Jun 2013
    Houma, Louisiana
    9,643
    1545
    3499 times
    Quote Originally Posted by Kc311 View Post
    Tows more with less tq too...
    SSG Outdoors
    2013 FX4 S-crew
    Rigid LED lighting
    Rockford Audio
    Ecoboost Pro mc4100s2's Avatar
    Dayton Oh.
    640
    4315
    201 times
    Plus it does not have those wing nut mirrors
    ford4thot and 2015 Dream like this.
    873
    1958
    175 times
    Quote Originally Posted by Pinero61 View Post
    Evodiesel too SSG Outdoors
    Nice I missed this part.
    Banned Fordskin's Avatar
    Jul 2014
    27
    5857
    Kinda sad, the max towing is only rated to 7800? are they trying to force people to buy a 3/4 ton?
    Jun 2013
    Houma, Louisiana
    9,643
    1545
    3499 times
    Quote Originally Posted by Fordskin View Post
    What do you mean?
    SSG Outdoors
    2013 FX4 S-crew
    Rigid LED lighting
    Rockford Audio
    Eco-Beast agentjohnson's Avatar
    East Texas
    3,859
    4749
    1509 times
    What do you mean?
    SSG Outdoors
    I think he's a bit slow, I did see this,
    peon
  1. Foxnews - ford ecoboost engine busted
    By Jboyahhh in forum F150 Ecoboost News
    Last Post: 01-07-2016, 03:29 PM
  2. 3.5L Ecoboost crate motors to be released by Ford
    By PLASMAN in forum F150 Ecoboost Performance
    Last Post: 12-27-2013, 02:05 PM
  3. Ford Racing Releases EcoBoost 3.5-Liter Crate Engine
    By STdan in forum F150 Ecoboost News
    Last Post: 12-16-2013, 11:33 PM
ford f 150 ecoboost crate engine
grabber bar ford eco boost
