Coolant temp too low with a 170 t-stat? - Page 2
This is a discussion on Coolant temp too low with a 170 t-stat? within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; I know, right? Someone go tell all the people that have done this as well as all the tuners that can better control ECT they ...
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Like Tree8Likes
Thread: Coolant temp too low with a 170 t-stat?
    Ecoboost Veteran greg hazlett's Avatar
    Nov 2015
    Chesapeake, VA
    344
    13966
    55 times
    I know, right? Someone go tell all the people that have done this as well as all the tuners that can better control ECT they are doing it wrong...sheesh.....
    Really? My truck performs perfect with the 170° thermostat...with all my tunes. I also don't see any coolant temps over 200° even when it is over 100° ambient.
    Contact me for your Amsoil needs.
    2016 3.5 TT Lariat 4x4
    UPR DVCC
    170 tsat
    Unleashed tuned
    AFE CAI
    Fox 2.0 shocks
    Hellwig RSB
    Weathertech mats
    Kicker speakers
    Nov 2015
    Chesapeake, VA
    344
    13966
    55 times
    Did them on my f150 and Exp, it is a bit of a PITA due to the angle of the housing and it is messy.
    Man. I really need to get mine installed. Had it in the box for a while now. My coolant runs about 205. Spikes to 210 or so.
    UPR DVCC
    170 tsat
    Unleashed tuned
    AFE CAI
    Fox 2.0 shocks
    Hellwig RSB
    Weathertech mats
    Kicker speakers
    Eco-Beast milesej05's Avatar
    4,977
    1831 times
    Quote Originally Posted by greg hazlett View Post
    This is the truth. I've had to do mine twice. Luckily I found out the concentrated coolant at the local dealership is cheaper than buying on Amazon by $12 dollars/gallon
    2013 Oxford White EcoBoost FX4 with a few goodies
    Quote Originally Posted by erick View Post
    Does a s&b intake need a tune to make it work because im running one on stock tune and it made it slow
  4. #14
    Nov 2015
    Chesapeake, VA
    344
    13966
    55 times
    I used the Prestone safe to add to any coolant from Wal Mart.
    UPR DVCC
    170 tsat
    Unleashed tuned
    AFE CAI
    Fox 2.0 shocks
    Hellwig RSB
    Weathertech mats
    Kicker speakers
  5. #15
    4,977
    1831 times
    As much as it has been debated on the forum, both my current tuner and previous tuner (neither of which were Shawn) said to use the same coolant that was in my truck (Motorcraft Orange) unless I was planning on draining the whole system.
  6. #16
    Ecoboost Sr Member cdat81986's Avatar
    stafford va
    70
    5432
    I called Reische back today, and am having one of the new prototype T-stats shipped out to me free of charge. Joel told me that it's built exactly like the oem and is better than what's being produced currently. It's so new that he didn't have any gaskets for them yet, but it's the same at the oem gasket which I still have and it's still in good shape so I'm sure it will be ok.
    He asked me to provide any feedback to him as soon as I can so I will report back here and to him as soon as I get it installed.
    noodles likes this.
  7. #17
    2,894
    982 times
    Best possible outcome
    2013 XLT S. Crew cab 4x4
    3.31 Gears
    Bilstein leveling coil overs top setting
    3" rear blocks
    Husky floor liners
    Raptor Grill lights
  8. #18
    Ecoboost Regular Brute840's Avatar
    Va
    194
    6591
    33 times
    I have a Rat Stat and mine runs at around 186* most the time never seen on 203*
    2012 FX2 Ecobeast
    MPT/Unleashed tuned
    SCT X4
    AEM drop in filter
    Wagner Intercooler
    Robs 170 Tstat
    3/5 Drop kit
    VAS Traction Bars
    Kicker Soundgate Kit
  9. #19
    Rookie metroplex's Avatar
    SE MI
    12
    15060
    The Motorcraft Orange is just Dex Cool, same as GM. I believe ford switched to dexcool around 2010. The Prestone all makes green, from what I heard, is dex cool without orange dye.
    Ford Yellow or Gold was just Zerex g05, but that is not compatible with Dexcool.
    I changed the tstat on my SHO and needed about .75 gal. I too noticed my temp gauge or rather bar drop while cruising. I also noticed that if I rev the engine in neutral and let off the throttle, the temp will drop momentarily. I haven't datalogged it yet since I'm still checking to see if there's air.
  10. #20
    4,155
    1251 times
    how sure are you that it is just dexcool? I ask because I have been told that this is not the case.
  1. 170* Stat ?????
    By MudnRox in forum F150 Ecoboost Performance
    Last Post: 08-04-2016, 11:29 AM
  2. Custom Low Temp Thermostat
    By Daltonkk in forum F150 Ecoboost Performance
    Last Post: 01-07-2016, 09:18 PM
  3. 170 Degree T-Stat
    By Daltonkk in forum Wanted
    Last Post: 01-05-2016, 10:33 PM
  4. 170 T-stat
    By Rutt3.5 in forum F150 Ecoboost Performance
    Last Post: 09-14-2015, 11:34 AM
  5. Torque Convertor Lockup Speed vs. Trans Temp vs. Coolant Temp
    By Mike Wood in forum F150 Ecoboost Chat
    Last Post: 11-13-2014, 07:10 AM
