Coolant temp too low with a 170 t-stat?
This is a discussion on Coolant temp too low with a 170 t-stat? within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; I bought a Reische 170° t-stat for my truck and was wondering if anyone else has seen their temp gauge drop when coasting without applying ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Like Tree9Likes
Thread: Coolant temp too low with a 170 t-stat?
    Ecoboost Sr Member cdat81986's Avatar
    stafford va
    72
    5432
    13 times
    I bought a Reische 170° t-stat for my truck and was wondering if anyone else has seen their temp gauge drop when coasting without applying any throttle? Even with 90°+ days and the ac blasting at cruising speed if I take my foot off the throttle and just coast after about 10 seconds or so the needle will start to drop off of the normal range about a quarter inch. When you go back into the throttle it will come up back to where it normally is supposed to be.
    I had had my tune updated for the for the new temps, install went fine, no problem bleeding the cooling system.
    I wanted to make sure I didn't have a funky sensor or gauge so I data logged it the entire way to work, all highway 55-85 mph and when I would take my foot off the gas the temps would drop into the mid to low 160s and when I gassed it again it would go back up to about 180 or so. So seeing that it confirms what I was seeing on the gauge.
    I called Reische this morning and spoke to the guy for a few minutes and he said while it's cause for concern, it's not a big deal unless I get a P0128 code. He said the t-stat might be getting hung up opening and closing and if I got the code he would replace it. He also told me that he's getting ready to release a new t-stat for the ecoboost that is better made and built exactly like the oem.
    I'm a bit concerned about this, especially if the temps drop like that in the summer, what's it going to do when it's below freezing out?
    Sorry for the long winded post just wanted to explain it clearly. Has anyone else seen anything like this?
    3,073
    1055 times
    Well I'd tell him to send that new style thermostat on over when it's ready, free of charge.
    Those temps seem too low.
    Mike Wood likes this.
    2013 XLT S. Crew cab 4x4
    Bilstein leveling coil overs top setting
    3" rear blocks
    34/10.5/17 BFG KO2's
    Husky floor liners
    Raptor Grill lights
    Ecoboost Veteran cecoboost's Avatar
    United States
    280
    14905
    70 times
    go back to the tune for the stock thermostat. The fan is probably set to come on sooner now. That should help for now but if the thermostat is faulty it won't be a long term fix
    stafford va
    72
    5432
    13 times
    I agree that they are too low. I'd really like to swap it out for another one, preferably one of the upgraded ones. I can't force the guy to give me one for free but I don't think I should have to pay for another
    mwemaxxowner and cecoboost like this.
    5,154
    1594 times
    You tried being nice. This is a high dollar truck being threatened by a low dollar part. It won't kill him to send you another.
    I'd try asking nicely once more. If you aren't satisfied, threaten to oust him on the internet. That can carry a lot of weight these days. One unhappy customer can make waves.
    Just look at Elkhart. Haha
    stafford va
    72
    5432
    13 times
    That's true. The guy was nice, I suppose that I could always just tell him that I got the p0128 code if I had to. I definitely want the newer updated style one though.
    So these temperatures are definitely not normal, correct?
    Ecoboost Pro slothman's Avatar
    CA
    873
    14592
    231 times
    this motor isn't designed for a 170 Tstat.
    Moral of the story: use the stock Tstat
    If you want it to run cooler, run 70% distilled water during the summer
    My catch can 'how to': http://www.f150ecoboost.net/forum/42...catch-can.html
    '15 Screw 3.5 EB - Unleashed E30 tune - SCT LivewireTS - MBRP 4" catback - VTA - tint - RX catch can
    03 Cobra Terminator
    98 Viper GTS
    United States
    280
    14905
    70 times
    Go to vendors list and buy a rat stat and be done with it
    Brute840 likes this.
    Eco-Beast milesej05's Avatar
    5,335
    2036 times
    Quote Originally Posted by slothman View Post
    Really? My truck performs perfect with the 170° thermostat...with all my tunes. I also don't see any coolant temps over 200° even when it is over 100° ambient.
    greg hazlett likes this.
    2013 Oxford White EcoBoost FX4 with a few goodies
    Quote Originally Posted by erick View Post
    Does a s&b intake need a tune to make it work because im running one on stock tune and it made it slow
    5,154
    1594 times
    Man. I really need to get mine installed. Had it in the box for a while now. My coolant runs about 205. Spikes to 210 or so.
  1. 170* Stat ?????
    By MudnRox in forum F150 Ecoboost Performance
    Last Post: 04-08-2017, 10:13 PM
  2. Custom Low Temp Thermostat
    By Daltonkk in forum F150 Ecoboost Performance
    Last Post: 01-07-2016, 08:18 PM
  3. 170 Degree T-Stat
    By Daltonkk in forum Wanted
    Last Post: 01-05-2016, 09:33 PM
  4. 170 T-stat
    By Rutt3.5 in forum F150 Ecoboost Performance
    Last Post: 09-14-2015, 10:34 AM
  5. Torque Convertor Lockup Speed vs. Trans Temp vs. Coolant Temp
    By Mike Wood in forum F150 Ecoboost Chat
    Last Post: 11-13-2014, 06:10 AM
