Ecoboost timing Chain replacement
This is a discussion on Ecoboost timing Chain replacement within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; So i had the phaser rattle and the engine started throwing the P0016 codes. So i did as much research as i could to figure ...
Results 1 to 10 of 23
Like Tree6Likes
Thread: Ecoboost timing Chain replacement
    Rookie Patf10's Avatar
    PA
    26809
    So i had the phaser rattle and the engine started throwing the P0016 codes. So i did as much research as i could to figure out how to do this work myself as my truck was out of warranty. So I tore the truck down and replaced the chain phasers and guides. I couldnt find a complete write-up and figured id see if anyone would be interested. I signed up for a ford service thing so i could get access to all the torque specifications. There are im sure a lot of people out there who have trucks out of warranty and dont want to spend 3000$ to have the dealer perform this work. So post up and if there is enough interest ill put something together for the job. Honestly its not that hard just time consuming and very few special tools are actually needed.
    Urshermo likes this.
    4,890
    1797 times
    There was a small write up at f150forum but a more detailed one would be amazing especially if you took step by step pics but that's quite time consuming during the job.
    Special tools being a cam holding tool and crank pulley remover?
    It would be great and we could get a sticky with all the parts referenced in the tsb etc and torque specs.
    I know if it happens again on my truck I'll be doing it myself.
    PA
    26809
    I dont have step by step pictures but i can provide a lot of part numbers and the tools and techniques that I used. Ill get something together. It will at least get people in the right direction to be able to do the job themselves.
    winchested likes this.
    4,890
    1797 times
    Thanks Pat.
    Ecoboost Veteran aj.n.amber's Avatar
    Lockport, NY
    440
    14906
    58 times
    Quote Originally Posted by Patf10 View Post
    That would be awesome. I'll have to do it one day, and maybe I'll put together all of it from what I can from photos and descriptions around to do as much detailed write up as I can, post it on my site. Unless mine gets worse and I have to do it in spring.
    Anyways write up and any additional info would be very helpful. I got a kid on the way coming very soon and no $3k to be spending yup that would be me, that guy. Haha.
    Thanks for any info you post.
    Current: 2011 F150 Eco STX 3.5L 4x4 6'
    Current Toy: 2016 Keystone Springdale Summerland 2980BHGS
    Previous: 2003 F150 FX4 4x4 5.5'
    Ecoboost Guides & Info:
    - http://f150ecoboost.com
    RV Keystone Springdale Summerland:
    http://bit.ly/2ihPPHI
    Travel Trailer & RV Fun Times:
    http://bit.ly/2ihLzbf
    2011 F150 XLT XTR 3.73 SuperCrew Ecoboost.... w/Tow Package w/o Payload Package...
    Rookie jar944's Avatar
    6
    26697
    Feel free to use these pics.
    Ford service manual
    Fuel pump control under bed
    Intake off
    Driver side turbo plumbing removed
    Valve covers off
    Crank pulley puller
    Front cover off
    Worn intake gear
    Torx plus TP-55, 22mm wrench, breaker Bar and a pipe for the cam gear removal
    Parts replaced
    New intake phasers, cam chain, crank gear, outer guides, and idler gear (coolant spigot)
    Lockport, NY
    440
    14906
    58 times
    Quote Originally Posted by jar944 View Post
    Ford service manual
    Intake off
    Valve covers off
    Crank pulley puller
    Front cover off
    Worn intake gear
    Parts replaced
    Thank you for posting those pics.
    PA
    26809
    Is there a way to post .pdf files? I have a bunch of ford procedures that were very helpful along the way that i want to post with my write up im working on.
    Lockport, NY
    440
    14906
    58 times
    I think normal file attachment will work when you are posting, otherwise you'd have to use external stuff for hosting it, getting the link and posting it here. (ie. Dropbox, Google Drive, etc..)
    Ecoboost Regular devin's Avatar
    Aug 2016
    Pacific Northwest
    231
    19409
    58 times
    I can host files, if you can't find anywhere else to do it from.
    Devin
    2013 Kodiak Brown XLT XTR 4x4
    www.shopowered.com
  1. Replies: 520
    Last Post: 04-25-2017, 12:28 AM
  2. 2011 F-150 Ecoboost Cold Start Grinding Noise - Timing Chain
    By qbfordguy in forum F150 Ecoboost Problems
    Last Post: 11-25-2016, 05:27 PM
  3. Timing chain help
    By Ctownrocks in forum F150 Ecoboost Chat
    Last Post: 10-08-2016, 11:07 AM
  4. Timing Chain Rattle
    By Big_Boy in forum F150 Ecoboost Chat
    Last Post: 08-04-2016, 04:50 PM
  5. Timing chain
    By 3six7 in forum F150 Ecoboost Maintenance
    Last Post: 11-04-2014, 03:51 PM
2011 f150 ecoboost phaser replacement
2012 ecoboost timing chains and phasers
2012 ford f 150 ecoboost timing chain problem
ecoboost timing chain repair kits
f 150 ecoboost timing chain replacement
f150 ecoboost timing chain and cam phaser replacement
ford ecoboost timing chain problems
how to replace timing chain on 2011 f150 ecoboost
