2013 Ecoboost engine operating parameters
This is a discussion on 2013 Ecoboost engine operating parameters within the F150 Ecoboost Chat forums, part of the F150 Ecoboost Forum category; Hello fellow members! I am new here so please be gentle. I have purchased an Edge Insight CS to monitor the different temps, pressures etc. ...
    Ecoboost Regular Longhornamus's Avatar
    Texas
    129
    3419
    Hello fellow members! I am new here so please be gentle. I have purchased an Edge Insight CS to monitor the different temps, pressures etc. in my truck. I can see this is going to be a nice tool -once I learn what exactly all the normal operating parameters are for my truck. Can anyone point me to a location that will tell me what the "safe" range of these temps and pressures etc. should be? It is nice seeing the numbers, but I do not know if everything is normal, or if my truck is about to have a meltdown. I have looked around the Edge website, checked the manual that came with it, and sent an email to them that I have not had a response to as of yet. I also did a search on this site, but may not have put in the correct keywords. Thanks in advance!
    Super Moderator Kc311's Avatar
    Texas
    2,431
    801
    1272 times
    I don't have a specific answer but have you checked the truck manual?
    Ecoboost Regular jared's Avatar
    Jan 2013
    214
    336
    65 times
    I know alotnof people fret about trans temp. Normal seems to be 195 towing ive seen 215 but wouldnt start to really worry unless it stayed at 230+ for long periods of time. Water temps should be similar. I think factory they run a 195 deg thermostat. And the fans probably don't kick on until over 200. Higher Water temps are bad for performance but good for mpg.
    Texas
    129
    3419
    I have checked but all I can find is capacities etc. I can't find what the Engine Coolant Temp range is for example. Now, that does not mean that I did not overlook the info.........I also have tried searching it on the net but must not be typing in the correct key words as surely the info. is out there to be had.
    Texas
    129
    3419
    Thank you for the response. The product has a lot of info. that I probably have no business worrying about, but it would be nice to know what range is normal for them. I am pretty sure I can set alerts for them if they go over a certain temp / pressure, but I would not know what to set them at until I know what the normal ranges should be. Just more eye candy is all...I do love the toys!
  1. 3.5L Ecoboost vs V8 5.0L Engine
    By KY Fordman in forum F150 Ecoboost Chat
    Last Post: 02-21-2014, 09:55 PM
  2. Which option should I go for ( Ecoboost or v8 engine)
    By fordfever in forum F150 Ecoboost Purchasing
    Last Post: 01-06-2014, 09:11 AM
  3. 3.5L EcoBoost Engine on 17G Dyno
    Last Post: 10-06-2013, 03:37 PM
  4. My 2013 f150 keeps throwing engine code p050e low exhaust temp
    By GORDYGEISE in forum F150 Ecoboost Problems
    Last Post: 09-19-2013, 04:53 AM
  5. Federal Probe into 3.5l EcoBoost Engine
    By SPPD in forum F150 Ecoboost Problems
    Last Post: 06-04-2013, 05:08 PM
2013 f150 trouble code p050e
ecoboost operating range
eshast temp 2013 f150
f150 ecoboost edge insite
f150 ecoboost normal engine temperature
f150 ecoboost safe parameters
what is normal engine temperature in ecoboost f150
where should the engine temps be on a 2013 ecoboost
