2016 3.5L Ecoboost Temperature Gauge Slow to Rise to Operating Temp
This is a discussion on 2016 3.5L Ecoboost Temperature Gauge Slow to Rise to Operating Temp within the 2016 Ford F150 Ecoboost Chat forums, part of the 2nd Gen F150 Ecoboost Forum category; My temperature gauge is very slow to rise to show normal operating temperature. In 40 degree weather I get heat pretty quickly, so I assume ...
Results 1 to 7 of 7
  • 1 Post By Alaskan_boost
Thread: 2016 3.5L Ecoboost Temperature Gauge Slow to Rise to Operating Temp
    Rookie AZRocks's Avatar
    Arizona
    22978
    Resolved--2016 3.5L Ecoboost Temperature Gauge Slow to Rise to Operating Temp
    My temperature gauge is very slow to rise to show normal operating temperature. In 40 degree weather I get heat pretty quickly, so I assume the thermostat works, but the gauge sits at minimum forever. It takes 20-25 minutes (10 minutes on streets/ 10 minutes on highway) for it to get to a normal operating temperature reading. Is that what everyone else is experiencing?
    Last edited by AZRocks; 01-20-2017 at 10:33 AM. Reason: Was looking at the wrong guage.
    2016 F-150 XLT FX4 3.5L EB; Icon Stage 2 kit; Halo 3" rear lift blocks; SumoSprings; 275/70/18 Toyo Open Country ATs; BAKFlip MX4 Tonneau.
    Ecoboost Jr Member JaDO81's Avatar
    Fort Worth, Texas
    45
    14808
    I get the same thing, and hadn't really noticed it until this winter. I have noticed that if I punch it (the throttle, not the truck) after the truck has warmed up, but still showing cold on the t-guage, it will jump to the correct "normal" temp.
    2013 SCREW 502A Lariat. 3.15's. Drilled CAC, removed CAC plates. LEDs all around.
    Rom. 8:28
    Gal. 2:20.
    4,886
    1795 times
    It's normal.
    Ecoboost Sr Member RMINC's Avatar
    97
    14634
    19 times
    I've got the opposite problem. I have a 16 3.5 and the temp is in the middle of the guage within minutes. Maybe I've owned Japanese cars for too long (Pontiac forced me away from anything American). I'm used to it taking 20 mins to get warm.
    Ecoboost Sr Member Makoto's Avatar
    Sep 2016
    59
    20250
    you sure you aren't looking at the trans temp gauge? i was confused by that at first.
    2016 XL F150 2.7 ECOBEAST Sport - Factory 20's & Electronics package
    Ecoboost Regular Scott91370's Avatar
    Burleson, Texas
    160
    14930
    43 times
    Use ForScan and turn on the numbers above both gauges and you'll know what the actual temp is.
    So worth it!
    2015 Ingot Silver - 3.5 Ecoboost
    Ecoboost Jr Member Alaskan_boost's Avatar
    Feb 2017
    40
    28457
    7 times
    Quote Originally Posted by Scott91370 View Post
    So worth it!
    I assume this option isn't available on the XLT package, or is there a trick? Is that the same thing that shows the boost gauge that I can't seem to find?
    Sent using my fat fingers on a small phone
    thewheelman likes this.
  1. Long time to reach operating temp. (6R80 Trans.)
    By jim_87 in forum F150 Ecoboost Chat
    Last Post: 12-08-2016, 04:23 AM
  2. 2016 boost gauge/pod, or Ultra gauge vs OBD-I I Mx
    By Jmbucknertx in forum Introductions
    Last Post: 09-25-2016, 05:31 PM
  3. Coolant operating temperature
    By CrawlerHauler in forum F150 Ecoboost Problems
    Last Post: 06-15-2016, 08:25 PM
  4. Torque Convertor Lockup Speed vs. Trans Temp vs. Coolant Temp
    By Mike Wood in forum F150 Ecoboost Chat
    Last Post: 11-13-2014, 06:10 AM
  5. 2013 Ecoboost engine operating parameters
    By Longhornamus in forum F150 Ecoboost Chat
    Last Post: 01-16-2014, 03:52 PM
