My (Never Ending) Build Thread - Page 317
This is a discussion on My (Never Ending) Build Thread within the F150 Ecoboost Builds forums, part of the F150 Ecoboost Forum category; Ditto Big Ryan Sent from my SM-N950U using Tapatalk...
Page 317 of 331 FirstFirst ... 217267307315316317318319327 ... LastLast
Results 3,161 to 3,170 of 3307
Like Tree2285Likes
Thread: My (Never Ending) Build Thread
  1. #3161
    4,027
    3235 times
    Ditto Big Ryan
    RMB_Ryan likes this.
  2. #3162
    Ecoboost Veteran Grabber70Mach's Avatar
    Nov 2014
    Southern MD
    361
    6910
    87 times
    Had a great one Ryan hope you did also. Same to all the rest of the father's out there.
    RMB_Ryan and snakebitten like this.
  3. #3163
    4,027
    3235 times
    Happy grandFAther's day.
    Elmore328 likes this.
  5. #3164
    Sponsor RMB_Ryan's Avatar
    NorthEast
    6,979
    6210
    4037 times
    I found myself laughing just now over that drink in the plastic solo cup. Those are the things that stick with me forever. Still makes me giggle and smile.
    Happy grandfathers day to you sir. I know your day was blessed.
    We are not huge on gifts but my son and daughter each picked me out son funnies and thought I’d share. My daughter got me the t-shirt and my son matching hats.
    They each show their personalities to a T.
    That baby is going to a tough cookie. Beautiful! Thank you for sharing and hope your day was full.
  6. #3165
    NorthEast
    6,979
    6210
    4037 times
    For anyone pulling their motor. Little trick where you do not have to pull the fan, rad, front clip, headlights, nothing. You can even leave the hood if you’re careful, just remove windshield cowl and windshield wipers.
    Saves hours.
    Summit, $7-$15 bucks. 4 barrel carb lift plate. Trans and driveshaft can remain untouched as well.
  7. #3166
    Ecoboost Regular Fstrnyou's Avatar
    SC, near Charlotte NC
    128
    70710
    52 times
    Removing the cowl/wipers is an amazing trick for my Mazdaspeed6 as well. I pull it out the top vs removing the front clip like everyone else. Its a very tight squeeze with the transfer case hanging off the back, but it works. Bonus: I don't have to recharge my A/C system when it's back together.
  8. #3167
    NorthEast
    6,979
    6210
    4037 times
    Quote Originally Posted by Fstrnyou View Post
    Agreed. I don’t charge it either!! Rad and fans staying is rad also. Nice
  9. #3168
    128
    70710
    52 times
    Yep. I leave all that crap as is. My coolant overflow bottle can stay too and its mounted top-front-center of the radiator on the Speed. One small mishap though and I could pop a hole in it. Patience is key.
  10. #3169
    NorthEast
    6,979
    6210
    4037 times
    2.3l build.
    Probably the worst flowing head in history on the flow bench.
    So this is a focus RS block, so we closed the deck, keyed the crank, crank gear, and pulley. We also welded up a crack plate to reinforce and transfer load outward away from the weak point where these blocks crack. It’s actually been working along with a JE pro Seal head gasket
  11. #3170
    128
    70710
    52 times
    Nice work. CSS plate?
    The MZR DISI in the mazdaspeed 3/6 and the CX-7 was the precursor engine to the current ecoboost 2.3's. These blocks are semi-closed deck and don't suffer the same block cracking issues as the RS block. 600, 700, 800whp mazdaspeeds are becoming more common these days and still using the stock block. Some even on stock head/cams, albeit 40+psi of boost to reach those numbers with a PT6466.
    I had my crank keyed and I pinned my cams in the shop when I had the alignment tools in place. I never have to replace friction washers ever again or worry about slipped timing.
    My head flows similarly crappy, probably even worse, than the RS head. I intend to send it off for port work in the coming months if I dont feel like doing it myself and I'll be upgrading cams sometime down the road. I was going to upsize the exhaust valves (30->32), but they're on backorder. So screw it. I'll stick with the stock size for now (35/30). Probably for the best anyways since bigger isn't always better.
    It seems I may gave derailed this thread a tad. My apologies.
    Let's get back to the RMB madness.
    Envious, snakebitten and RMB_Ryan like this.
  1. My Slow build thread.
    By bagged_expo in forum F150 Ecoboost Builds
    Last Post: 11-04-2017, 06:32 PM
  2. My 9 month (and counting) build thread
    By Ducatti20 in forum F150 Ecoboost Builds
    Last Post: 09-22-2017, 12:10 PM
  3. Big Green Boost build thread
    By Steelheader in forum F150 Ecoboost Builds
    Last Post: 05-19-2017, 08:19 AM
  4. BoostedFX4 Build Thread
    By KissMyWhtSS in forum F150 Ecoboost Builds
    Last Post: 04-03-2017, 07:55 PM
  5. Silver Sleeper Build Thread
    By thewrubelator in forum F150 Ecoboost Builds
    Last Post: 02-04-2014, 09:54 PM
285 70r17 for f150
best black wheels for f150
never ending
news
