Making my own intake!
This is a discussion on Making my own intake! within the F150 Ecoboost Performance forums, part of the F150 Ecoboost Garage category; Soooooooo......... I'm thinking of making my own AFe replica intake. I'm not sure if anyone has tried this but when I'm done I will post ...
Results 1 to 10 of 11
Thread: Making my own intake!
    Ecoboost Jr Member shreker's Avatar
    TEXAS
    25
    14476
    Soooooooo......... I'm thinking of making my own AFe replica intake. I'm not sure if anyone has tried this but when I'm done I will post pictures up. I don't think paying 500 dollars for a intake that could be made under 150.00. I will be using silicone hoses to reduce some heat, I will use some imagination ofcourse. I f anyone has any ideas, I am open to any comments as long as they are not negative which I'm sure someone will be the lucky one! Thanks!
    Eco-Beast madmaxmutt's Avatar
    Colorado Springs
    3,476
    3707
    1608 times
    Quote Originally Posted by shreker View Post
    Hey if you have the skills, material and time, go for it. I take it, you are going to buy existing filters and just make the housing and tubes?
    IIRC we had this AlaBAMA fan that threatened (for a long time) to make what he called The Chicken Scoop. No idea if he ever made it, though. I don't think he is here any more.
    2017 Ford F350 Lariat FX4 SRW 4x4
    2017 Ford Explorer Sport 3.5 Ecoboost.
    Traded my boost: 2013 Ford F150 Ecoboost FX4 SuperCrew.
    Should've got a V8 - Check
    Should've got a Diesel - Check
    Should've got a 1 Ton - Check
    You'll run out of payload - Not Likely
    TEXAS
    25
    14476
    Quote Originally Posted by madmaxmutt View Post
    I will be using some intake tubing and silicone tubing, and and I see that the drivers side has an opening so I just might do a cold air intake.
    Colorado Springs
    3,476
    3707
    1608 times
    You might want to check out the Banks and Air Raid intakes then. Those might be a better models to copy because they have front facing cold air inlets. I think the Banks is just a cover for the existing air box. Not sure about the Air Raid. I will say that almost no one believes the intakes help the Ecoboost much. The stock air box is said to have plenty of flow for the motor. Sounds like a fun project, though. Pictures are required. . .
    Grim Reaper likes this.
    Eco-Beast 2Canches's Avatar
    Jun 2013
    KOOTENAYS eH! um CANADA
    13,020
    1439
    5062 times
    Just make sure you do the s&b mod if you're pulling air from the stock location
    Sent from my iPad Air using The app
    Teezy likes this.
    http://www.leadingedgetuning.com 91 tune & 87 tow tune
    2015 5.sL0w
    XTR trim
    Flowmaster DBX muffler
    exit rear tire with CORSA twin tips
    Hellwig rear ani-sway bar
    2" lift all around
    truck is so fast I had to install SYPPO
    tow mirrors 😹😹😹
    Ecoboost Regular crankinaway's Avatar
    Nov 2015
    Maple Ridge
    126
    13990
    19 times
    s&b mod? Enlighten me.
    TEXAS
    25
    14476
    Quote Originally Posted by crankinaway View Post
    Me too!
    3,891
    Pick one up, you'll see.
    Ecoboost Master Teezy's Avatar
    Aug 2015
    Cedar Park TX
    1,090
    13192
    318 times
    I like my S&B
    Jun 2013
    13,020
    1439
    5062 times
    I took out my driver side headlight for easier access but when doing 11-14 in the instructions, (I had a stage 2 AFE) the spot where the inlet pops out, the whole dang side pops out. Into fender. Pull it out. Then instead of small hole or s&b bigger hole, you have a HIGE hole for your "cold" part of the air intake. I think I have a pic or 3 of it somewhere on this forum. Probably take me ten years to find them. Sorry
    2015 5.sL0w
    XTR trim
    2" lift all around
    tow mirrors 😹😹😹
  1. truck making pop sound
    By str8up8up in forum F150 Ecoboost Chat
    Last Post: 05-02-2016, 10:37 AM
  2. making the switch
    By suukiquadrider2006 in forum Introductions
    Last Post: 06-08-2015, 06:59 AM
  3. Rained out guys making it OK?
    By Ducatti20 in forum Off-Topic
    Last Post: 05-27-2015, 05:24 PM
  4. Making some decals
    By BKHDFW in forum Buy/Sale/Trade
    Last Post: 05-29-2014, 08:09 PM
  5. Any vendors making advances with E85?
    By alteredego in forum F150 Ecoboost Performance
    Last Post: 09-06-2013, 05:10 PM
