BoostKing’s OEM+ Turbo Project - Page 27
This is a discussion on BoostKing’s OEM+ Turbo Project within the F150 Ecoboost Performance forums, part of the F150 Ecoboost Garage category; I am going to log my BCB tune with HP tuners and watch the turbo shaft speed(its a PID there, couldnt find it in LiveLink). ...
Page 27 of 28 FirstFirst ... 1725262728 LastLast
Results 261 to 270 of 273
Like Tree307Likes
Thread: BoostKing’s OEM+ Turbo Project
  1. #261
    3,208
    1138 times
    I am going to log my BCB tune with HP tuners and watch the turbo shaft speed(its a PID there, couldnt find it in LiveLink). If it gets to 210-220K+ rpm then I'd say thats a good indicator of if the wastegate upgrade is really the answer for me.
    snakebitten and Blown F-150 like this.
  2. #262
    3,208
    1138 times
    If the waste gate was opening, wouldn't we see less than desired boost levels?
    The reason I even discovered that my BCB tune was going to 100% WGDC was because it threw a underboost code while I just happened to be doing a 3rd gear pull while logging.
    I am still not convinced whether its the wastegate blowing open, or simply asking to much from the stock turbos. It could just be falling off the right side of the compressor map.
  3. #263
    3,955
    3206 times
    Just curious, but what's the shaft speed at say 18 lbs of boost at sea level?
    And what is considered the safe limit for these oem Gen2 turbos, if anyone has an opinion?
  5. #264
    4,206
    1214 times
    Right, so if you're targeting a certain boost and it only requires 50% waste gate duty cycle, why is the upgraded waste gate going to do anything? I dont understand geoff's post "blowing open at 50%" because 50% is exactly all that is required to meet the boost you're asking for (in this example), it it stayed closed, it would make more boost than I would want. Am I looking at this wrong?
  6. #265
    1,199
    443 times
    Good stuff right here for the mountain dwellers!
    I'm only a visitor to paradise and the sea-level Ecoboost set up gets me there and back. Amazingly so, in fact.
    But if I were to stay (I have ZERO intention of being one of those "foreigners that ruined everything") I'd definitely be going this route for addressing the atmosphere.
    (I'd also adjust my Espresso recipe to accommodate the change in boiling temperatures. Lol)
    Nah you are welcome. I will give you your credentials lol
    And we can drink espresso. That sounds good right now!
  7. #266
    3,208
    1138 times
    I dont know exactly without a compressor map or someone logging it. HPTuners shows an "overspeed limit" map that plots the pressure ratios vs mass flow and air charge temp for my 2014. It doesn't say what they consider overspeed though.
    Safe speed limits: almost every compressor map out there has a high limit of 540-580 m/s tip speed(speed of the OD of the compressor). For the 2013+ Ecoboost turbos with an OD of 50.8mm, that puts it somewhere in the 200,000 to 220,000 rpm range.
    You wouldnt change it out if you are hitting your boost. This would be for people who are not making their boost target.
    And yeah i get what you mean after rereading. If your truck is holding 50%wgdc then it’s probably not blowing open, otherwise it would be increasing the duty cycle to try and match the desired boost.
  8. #267
    3,955
    3206 times
    Haha. The welcome mat is incredibly flattering. And much appreciated.
    But what you might not know is I could never relocate without bringing my family with me. And I'm sorry to be so blunt about it but you should NEVER agree to that!
    Still, I'll be privileged to ever brew you up a cup.
    There's a coffee bean roasting guru in Mancos. His beans are available right about where I put the red dot. Good stuff!
    In an effort to not be 100% guilty of hijacking, I will ask another Turbo Boost question.....
    200,000+ RPM's? I just can't get my head around how this stuff we have under our hoods these days actually survive. I mean it is EXPECTED for a Turbo to last 100,000 miles now. It's just crazy.
  9. #268
    Ecoboost Regular full-race geoff's Avatar
    Phoenix, AZ
    245
    822
    412 times
    I dont know exactly without a compressor map or someone logging it. HPTuners shows an "overspeed limit" map that plots the pressure ratios vs mass flow and air charge temp for my 2014. It doesn't say what they consider overspeed though. Safe speed limits: almost every compressor map out there has a high limit of 540-580 m/s tip speed(speed of the OD of the compressor). For the 2013+ Ecoboost turbos with an OD of 50.8mm, that puts it somewhere in the 200,000 to 220,000 rpm range.
    unfortunately your OEM frame turbos do not have speed sensors (can not log speed without a sensor) and the compressor maps are not allowed to be released. HP Tuners' turbo speed is inferred (not actual). and yes 560m/s tip speed is a safe bet for max rotational speed. 580 is pretty much the critical limit. Only F1 turbos are safe to 600m/s tip speed range
    In that instance, a stiffer WG spring will typically allow for earlier spool (only a benefit on bigger turbos). there is no benefit to the top end boost if a softer spring is already achieving target. The thing to keep in mind is a wastegate is literally *Wasting* energy. the best wastegate is no wastegate
    the smaller a turbo is, the higher rotation speed (RPM) will be reached at 560m/s tip speed. really is impressive when you think about the fact that these turbos have a relatively long life and are using journal bearings. almost every car on the road has a turbo operating well above 100,000rpm. On that same note, its a bit scary to think about how many small shops bastardize turbos, stuff random chinese wheels inside the housings with no concern or ability to test for burst containment
    some bedtime videos:
    BRoell likes this.
    Cars are no longer simple.
  10. #269
    3,955
    3206 times
    Holy Exploding Turbos!
    I thought the 500frames per second exploding Turbo video was impressive. And violent.
    But the real time exploding counterfeit Turbo in the Cummins video made me CRINGE.
    I never really considered the counterfeit world in light of turbochargers. We live in amazing times. Lol
    By the way, now I'm gonna have nightmares.
    My hood is aluminum and my windshield is glass. So how do I relocate my turbos behind me? In the bed. In a lead box. Gonna need some loooonnnnggg headers and cold charge piping.
  11. #270
    3,208
    1138 times
    Here is a screenshot of the log using my Unleashed 91 performance tune:
    Was hovering around 210,000 rpm and dinged 211,000. Peak flow was ~37.5 lb/min
    For some reason my BCB and GH tunes won’t load up properly in HPTuners. I think its because they change the strategy so the software doesn’t recognize it as a default PCM and doesnt load up the extended PIDs. It actually does the same thing in LiveLink too.
  1. 2.7 ecoboost turbo size vs 3.5 eb turbo size
    By 15boost2.7 in forum F150 Ecoboost Chat
    Last Post: 03-09-2018, 08:10 AM
  2. Project GrampZilla: 67mm turbo'd 2010 mustang GT
    By skizzo81 in forum Off-Topic
    Last Post: 09-16-2016, 07:44 AM
  3. Really Ford?... You turbo'd the turbo's?... Pic inside
    By Talley in forum F150 Ecoboost Problems
    Last Post: 05-23-2014, 06:47 AM
  4. Replies: 30
    Last Post: 04-23-2014, 11:56 AM
display turbo boost with forscan f150
f150 boostking
news
