UPR Billet Valve Cover Crank Case Breather - Page 4
This is a discussion on UPR Billet Valve Cover Crank Case Breather within the F150 Ecoboost Performance forums, part of the F150 Ecoboost Garage category; Originally Posted by D0ncH To those that had a lot of oil on the motor. Did you do a lot of wot or heavy foot ...
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Like Tree19Likes
Thread: UPR Billet Valve Cover Crank Case Breather
  1. #31
    Ecoboost Master TOWMA8R's Avatar
    Sep 2017
    Two States
    1,406
    44498
    493 times
    Quote Originally Posted by D0ncH View Post
    To those that had a lot of oil on the motor. Did you do a lot of wot or heavy foot driving? That could be why some are finding the breather messy and some are not. More blow by and therefore more air under pressure coming out of the breather
    I will disagree, at least for me..... I have had plenty of boosted throttle pulls learning my BCB tune..... I will venture to say that the older (older than mine) might experience more blow by than the new trucks do..... that might be one issue..... but I have had my share of getting on it within the 620 miles with the breather in place...
    D0ncH likes this.
    2019 F150 CC FX4 XLT - Max Tow & Much More
    RIP-2015 CC FX4 l 3.55's l Raptor Style Grille l Level 2" l 305/60/18 on Vision Manics l Bilstein 4600's l Powerstop Z36's l AEM CAI l MSD Coils l Exhaust Tweaks l Tow Mirrors l Upgraded Trans Cooler (GH 13.31 1/4)
  2. #32
    Olathe Ks
    758
    14790
    214 times
    I had a couple of WOT pulls but aside from that just normal daily driving. My truck is a 2012 with 122K on the clock. My breather was on for about 6 weeks. The first month I saw no signs of oil anywhere. It all came in the last couple of weeks.
    ~Jim~
    2012 Lariat Screw; 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 KO2s
  3. #33
    Sep 2017
    Two States
    1,406
    44498
    493 times
    Quote Originally Posted by DBCooper View Post
    I will keep that in mind and check weekly.....
  5. #34
    Ecoboost Veteran BAD454SS's Avatar
    HELL Arizona
    367
    14381
    161 times
    I have had mine on 2 months now , ordered before this thread came out . I was a bit worried it was going to make a mess , but i have no signs of oil and i have been running it hard. I also installed one on my Raptor 6.2 and it is also dry light oil mist on bottom side. no oil on breather itself . I did notice some of you bottomed out the breather pushing as far down on stem as possible , i installed breather as high as could go and still tighten hose clamp, this just give a little more room for oil to accumulate and may drip it way down back into valve cover. If your seeing a ton of oil coming out i would say you have a good amount blowby . I did have one instance where idle was funky on a remote start , i was running late for work was boosting pretty hard , and pulled in shut off truck ran in to punch in , going home end of the day remote started and idle was wonky and then smoothed out after 20 seconds. Think it was that the check valve may been stuck open. Only did it the one time.
    2014 FX4Tremor,FullraceDP,Wagner,BBK,Afe CAI,ITV22,MSDcoils,180 thrmostat ,Unleashed 91 tune.
    2010 Raptor ,6.2L, 2.9 Whipple 650 hp kit .MODS everything
    2002 Lightning ,3.4 whipple ,800 RWHP, MODS everything
    1993 454 SS ,502 ci and 2.4 kennebell, 600 rwhp MODS everything
    1979 10th annivesary trans am 400 4spd , 56,000 orig miles, Stock
    1963 Impala 21,000 orig miles
    2015 POLARIS Scrambler 1000,Stock
    1995 BANSHEE ,Not Stock
    1985 Yamaha RZ500 ,4 cylinder2 stroke,12,000 miles , Australia
  6. #35
    1,150
    416 times
    For a while I had my Full Race catch can vented to atmosphere. There was a steady stream of vapor coming out of it at all times, and there would be a ton of crud build up inside the rear bumper, which was where I had the exit routed to through a breather filter.
    2016 2.7 4x4 screw
    You have any pics of how you had that set up?
  7. #36
    9,098
    3573 times
    Probably not, that was a long time ago. There wasn't anything complicated about it though.
    2016 2.7 4x4 screw
  8. #37
    Sponsor UPRjoe's Avatar
    Nov 2013
    United States
    435
    2972
    221 times
    Nice reviews and feedback just wanted share the NEW UPR Billet One-Way Breather Options.
    I have 3 different 3.5L Ecoboost vehicles that each have the breather on them and they range
    from a 2015 Expedition - 2016 Explorer - 2019 F150 Platinum and they all are equipped with
    UPR Plug n Play™ Catch Can Systems with the NEW ECSS = Electronic Clean Sides Separator.
    The UPR Billet One-Way Breather has multiple benefits for any vehicle they get installed on.
    The benefits range from keeping the crankcase evacuated and eliminating the positive pressure
    under the piston during the down stroke and allowing the hot air to exit immediately and draw
    in fresh cool ar right away resulting in cooler oil and short block temps. These both result in
    freeing up power and improving engine efficiency.
    You will also collect less oil as the excessive pressure that used to push the oil out of the PCV
    is now eliminated and you have the full effect of the vacuum from the intake and will also be
    sucking in much cooler fresher air.
    All 3 of my 3.5 Ecoboost's have tuners and I do best them daily so I always know what to expect
    from our UPR Plug n Play™ Catch Cans and One-Way Breathers. Now coming from the world of
    boosted performance I can say some setups can get a vapor mist of oil emitted from the filter.
    These engines are usually higher mile and or just looser from the factory as my 2.3 Ecoboost
    Mustang would blow a mist out of the filter the first week we got the car. Even before we had
    any mods other than the UPR Dual Valve Plug n Play™ Catch Can and Billet One-Way Breather.
    Yuck, and it got a light mist on the engine cover.
    I build tons of supercharged 5.0's and they experience oil mist from and breather filter let
    alone the custom baffled UPR Billet One-Way Breather. Because of this we developed a Plug
    n Play™ Breather tank to vent the excessive blow-by to and it simply replaces the filter and
    uses a custom bonnet over the UPR Billet One-Way Breather.
    This is the ultimate solution to eliminate oil blow-by mess with a Billet One-Way Breather.
    The best part is all the benefits you get daily driving with a Billet One-Way Breather and
    your engine bay remains spotless without any worries.
    We have kits available that come with a UPR Plug n Play™ Breather Tank with 36" of
    hose to be able to mount anywhere you like.
    Here is what the kit looks like as we have filed for a patent on the bonnet with a
    billet one-way oil cap breather to a breather tank as this will fix the problem with
    the oil mist and mess on all similar products as well.
    We also have kits that can be plumbed right into the exhaust system.
    Name:  Mustang CCV One-Way Breather Kit Installed.jpg
Size:  292.6 KBName:  Mustang CCV One-Way Breather Kit.jpg
Size:  123.7 KBName:  Universal CCV.jpg
    I'm looking for a reviewer on this board and will be giving a discount to
    any members that respond to this post so you can go back to the UPR
    Billet One-Way Breather and enjoy all the benefits without any mess.
    Hope you guys like how we are always working to continually offer
    the best solutions to common problems.
    Thank you, Joe
    D0ncH likes this.
  9. #38
    HELL Arizona
    367
    14381
    161 times
    That looks a nice set up !!!
  10. #39
    Olathe Ks
    758
    14790
    214 times
    That's a nice looking kit.
    ~Jim~
  11. #40
    Rookie brodysf150's Avatar
    Jan 2018
    Houston - CC
    5
    54481
    Possible to plumb into exhaust with factory downpipe, post cat?
  1. Crank Case Pressure and oil leaks
    By pminnc in forum F150 Ecoboost Problems
    Last Post: 12-16-2016, 10:48 AM
  2. Replies: 10
    Last Post: 12-09-2015, 09:24 PM
  3. CFM Performance valve cover breather
    By finallyonair in forum F150 Ecoboost Performance
    Last Post: 01-22-2015, 08:24 PM
  4. venting the crank case
    By stevenmverrill in forum F150 Ecoboost Problems
    Last Post: 12-02-2014, 09:56 PM
