Catch can question
Catch can question
This is a discussion on Catch can question within the F150 Ecoboost Performance forums, part of the F150 Ecoboost Garage category; I really like the build quality of Mishimoto products. I was looking at their dual can catch system for my 2016 3.5. It appears it ...
Results 1 to 4 of 4
    Ecoboost Jr Member Rds912's Avatar
    36
    64474
    Catch can question
    I really like the build quality of Mishimoto products. I was looking at their dual can catch system for my 2016 3.5. It appears it does not collect under boost like the upr products. Any thoughts?
    Ecoboost Sr Member Fstrnyou's Avatar
    SC, near Charlotte NC
    81
    70710
    22 times
    The PCV system on the passenger side closes up in boost due to a check valve. PCV catch cans retain the check valve so you don’t have a very large boost leak. UPR, I think, has a unique catch can for the PCV side that has an extra check valve that can still vent crankcase pressure when the check valve in the PCV line to the manifold is closed.
    The CCV system will function normally at vacuum and boost, with and without a catch can.
    3,891
    Quote Originally Posted by Rds912 View Post
    The UPR dual valve catch can setup collects under boost and vacuum into the same can.
    When using separate catch cans for each side, one can will collect while in vacuum (pass side), and one can for under boost (driver side). The driver side also acts as a fresh air inlet for the engine while under vacuum.
    36
    64474
    Great, appreciate the info. So essentially different approach same outcome.
  1. RX catch can or UPR catch can
    By coryhussey in forum F150 Ecoboost Accessories
    Last Post: 04-05-2017, 04:35 AM
  2. Replies: 1
    Last Post: 11-18-2014, 02:34 PM
  3. Replies: 4
    Last Post: 10-19-2014, 09:24 AM
  4. Replies: 0
    Last Post: 10-17-2014, 05:46 PM
  5. RX catch can or UPR catch can
    By coryhussey in forum F150 Ecoboost Performance
    Last Post: 10-10-2014, 05:30 AM
