Mishimoto thermostat review
This is a discussion on Mishimoto thermostat review within the F150 Ecoboost Performance forums, part of the F150 Ecoboost Garage category; Summary: avoid if possible Details- approximately 5000 miles on this thermostat (sitting next to a STANT Superstat) The diaphragm (for lack of technical term) material ...
Results 1 to 10 of 15
Like Tree13Likes
Thread: Mishimoto thermostat review
    Eco-Beast ptown's Avatar
    1,533
    659 times
    The diaphragm (for lack of technical term) material appears bonded from top to bottom new. Longevity is not there.
    Bleeder valve is lose, about to fall out.
    Left to Right - Stant to Mishimoto
    Envious and Mikedick77 like this.
    1,160
    421 times
    I love my stant superstat. Was idling in 80 degree weather and I peaked at 197 water temp and stayed around 195-196. Turned on AC and it dropped to 193. I also believe it flows more from what @DNA Dan was seeing
    825
    259 times
    Finally got a chance to take a 500 miles trip last weekend on the super stant. While on the highway for extended times, temp range seemed "tighter" and more consistent, right around 195-200. Overall it seems to have lowered the operating temperature of the motor about 5-7 degrees. Before I would cycle between 195-210. This was only in 60 degree weather, so still not sure how it's going to function when challenged with 100 degree heat soak situation. So far it's pointing in the right direction.
    I also have the Saudi trans cooler installed. That lowered the trans operating temp 5-10 degrees as well. I could see it get up to 195 then quickly come down to 190. At only $100, that upgrade is a no-brainer - truck should have come with it.
    Other than the build quality, how was the opening compared to stock on the Mishimoto stat? How was the regulation of the temperature? This one is colder than stock correct?
    1,160
    421 times
    I don't know why I am seeing such lower temps than you? Cruising I have never hit 200 yet. Peak was like 199. I don't think it could be the Amsoil coolant making such a big difference?
    Just got my second Saudi trans cooler in. First one was bent to high hell and finally got a response from Tasca so I ordered from another dealer while I was waiting. Second is in perfect condition.
    825
    259 times
    I think they are about the same. I am only a few degrees more than you. I was only checking temps off and on. The trip had some rolling hills so it could have been going up a moderate grade. I never broke 200 significantly, whereas on the stock stat I would routinely be over. I am also on the stock coolant, not that special sauce you got.
    1,160
    421 times
    Fair enough. I was hitting the highway going 80. But still too early to tell. Hopefully we get more good data with just a damn t-stat!
    Ecoboost Pro Boostking's Avatar
    Jun 2015
    Florida
    789
    12619
    869 times
    Quote Originally Posted by ptown View Post
    Just curious if you contacted them. It says lifetime warranty on the website.
    I happen to be friends with a few of those guys. I'd be surprised if they dont take care of you. Maybe you got a defective unit?
    2013 Tuxedo Black SCrew Ecoboost FX4 w Appearance Package 5.5 box, 3.73. Mods: SCT LWTS+ custom tuned, Full-Race/BorgWarner OEM+ "GT Turbos", Tifosi Exhaust Manifolds, RTR HPFP, CP-E FMIC w/ TurboSmart SuperSonic, CP-E 3" Catted Downpipes, AFE Magnum Force Pro Dry-S Intake, Borla Touring Cat-Back, Terra G2s 305/55/20 on Method N/V 20x9, Leveled Bilstein 5100 RHA 1.5", 20" LED light bar, Hellwig Rear Sway Bar, Morimoto LED Fogs, Extang Revolution Tonneau Cover, Custom LED bed lighting, DeeZee Tailgate Assist, Tailgate Remote Power Lock Mod, MaxLiner Floor Mats, Ford OEM Underseat Cargo Box, LED Interior and Reverse Lights (Diode Dynamics), Recon LED 3rd Brake Light, NL Door Detents, .50 cal antenna, Custom Coding (ForScan)
    1,160
    421 times
    Quote Originally Posted by Boostking View Post
    I'm sure they would. From my experience with them, they are very prompt with their customer service.
    1,875
    1045 times
    Probably a defective seal or something about the coolant that the seal doesn’t like. Either way, if I was Ptown, I wouldn’t put another one in. They make a mess when swapping and I hate dealing with coolant.
    Boostking likes this.
    1,533
    659 times
    Wasn’t happy how cool it ran honestly so I never considered putting it back. Went back to factory temps
    Blown F-150 and TX-Ripper like this.
  1. Mishimoto CAC Review?
    By duffmanFX4 in forum F150 Ecoboost Chat
    Last Post: 05-14-2019, 06:00 PM
  2. Mishimoto 3.5L Performance Intercooler R&D
    By Mishimoto in forum F150 Ecoboost Performance
    Last Post: 07-21-2017, 07:54 PM
  3. Mishimoto is seeking a 2015+ EcoBoost test vehicle near DE!
    By Mishimoto in forum 2nd Gen F150 Ecoboost
    Last Post: 03-15-2016, 06:46 AM
  4. Mishimoto is seeking a 13-14 EcoBoost test vehicle near DE!
    By Mishimoto in forum F150 Ecoboost Chat
    Last Post: 10-24-2015, 09:03 AM
  5. Mishimoto 160 Degree Thermostat for Ecoboost
    By RoastinF150 in forum F150 Ecoboost Performance
    Last Post: 10-06-2015, 04:26 PM
