MAP sensor cleaning
MAP sensor cleaning
This is a discussion on MAP sensor cleaning within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Truck has 46k miles on it now. Anyone here pull the MAP sensor located on top of the intake plenum and clean it with throttle ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Like Tree18Likes
Thread: MAP sensor cleaning
    Ecoboost Master BlueFlameFX4's Avatar
    West Central Missouri
    1,310
    4133
    408 times
    MAP sensor cleaning
    Truck has 46k miles on it now. Anyone here pull the MAP sensor located on top of the intake plenum and clean it with throttle body cleaner? Any improvements?
    Thanks in advance!
    2013 F 150 FX4 SCrew Loaded(3.5L GTDI)
    Eco-Beast Vozaday's Avatar
    Jul 2014
    Alberta
    5,138
    5575
    2535 times
    I have heard of a couple people doing it throughout the forums. It helped fix their drivability issues. One was reading too high of boost and another was a bit of a shudder.
    2013 F150 FX4 Appearance Loaded Eco. w/Max Tow. Level lift with 305/55r20 Open Country ATII Extremes. Rear Raptor Shocks. 5 Star Tuned/X4. Wagner Intercooler. AFE Stage 2 Intake. RX Catch Can/UPR CSS. Boost-Bars Raptoid Grille. 30" Hanning LED Bar. Rigid Backup Lights. JW Speaker Fogs. GlowShift Boost Gauge. Remote Access.
    1971 Mustang Grande 351C
    Gold Supporting Member Marvin's Avatar
    Mar 2015
    Bancoober, BeeZee
    539
    9196
    270 times
    My MAP is held in place by a single screw/bolt on the driver's side. The passenger side of the MAP has a hole for a second screw, but the intake plenum looks like it isn't tapped for that second screw. Do others have the same setup?
    Pax.
    - Marvin
    ______________________________________
    2013 F-150 Platinum / White Platinum / DuraTracs/ Roadmaster Active Suspension / Rx Catch Can / Wagner CAC / BakFlip FiberMax
    “The question is not 'Can they reason,' nor, 'Can they talk,' but, 'Can they suffer?' " - Jeremy Bentham
    Ecoboost Master Sub_Elect's Avatar
    North Dakota
    1,050
    748
    583 times
    I vaguely remember something about another person worried about the second screw not tapped issue. It was found to be normal the way that you just described.
    2013 XLT Ecoboost 4x4 6.5' Box SCrew - Tuxedo Black, Grey Interior - 3.73 Max Tow, Backup Camera, Skid Plates -2" Leveling Kit, 2" AAL, Box Side Step, Tail Gate Step
    1/2 ton Fords......doing the work of 3/4 ton Chevys since 2011!
    Eco-Beast scap99's Avatar
    Jul 2013
    Lone Star State
    9,641
    1668
    5100 times
    One screw only.
    '13 FX4 3.55 LET Tuned
    Stock Turbos = 451hp/532tq
    58mm Turbos = 482hp/591tq
    Mar 2015
    Bancoober, BeeZee
    539
    9196
    270 times
    Many thanks.
    Pax.
    - Marvin
    Ecoboost Regular Sir_Boosted's Avatar
    Jul 2014
    DFW
    145
    5600
    43 times
    I just pulled out and cleaned all 3 of mine. I kept getting a P012D code that would pop back up after a hundred miles or so. The one on the intake pipe right by the air cleaner needs a star bit socket to pull the stud holding that MAP sensor in place. The one right before the throttle body has 2 torx bit screws holding the sensor in place. And finally the one on top of the intake manifold has 1 8mm screw holding it in place. I just cleaned them with maf sensor cleaner in a spray can and blew them out with air really good. So far the code hasn't come back. The sensors by the throttle body and on the intake manifold were really oily.
    2013 Limited
    7,571
    3295 times
    Suggestions to get this caked on and dried oil off the map sensor?
    Sent from my SM-G900V using Tapatalk
    west coast mountains
    4,703
    1714 times
    This stuff works great, May have to give it multiple shots though if it's dried onName:  maf1.jpg
    Mar 2015
    Bancoober, BeeZee
    539
    9196
    270 times
    I wonder if you could safely fill an ultrasonic eyeglass cleaner with MeOH/Isopropanol/similar and clean it that way.
    Pax.
    - Marvin
  1. Cleaning intercooler
    By G-rant in forum F150 Ecoboost Maintenance
    Last Post: 03-08-2019, 09:19 AM
  2. CAC cleaning.
    By tabcheck in forum F150 Ecoboost Problems
    Last Post: 03-07-2015, 11:38 AM
  3. CAC removal/cleaning
    By Biggyniner in forum F150 Ecoboost Problems
    Last Post: 02-19-2015, 04:18 PM
  4. Cleaning CAC
    By Snakepit in forum F150 Ecoboost Guides and How-Tos
    Last Post: 11-26-2014, 05:12 AM
  5. Cleaning interior
    By NFLD in forum F150 Ecoboost Maintenance
    Last Post: 05-27-2014, 11:43 AM
ecoboost map sensor
f150 ecoboost map sensor
f150 ecoboost map sensor cleaning
how to clean air sensors 2011 f150 ecoboost
map sensor cleaner
map sensor cleaner f150 ecoboost
map sensor cleaning
what sensor is right before the throttle body on 2011 f150 ecoboost
