Spark plug replacement? - Page 11
This is a discussion on Spark plug replacement? within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Originally Posted by milesej05 That soot is most likely from you cruising along and then you romp on it, causing it to come out of ...
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 113
Like Tree36Likes
Thread: Spark plug replacement?
  1. #101
    Ecoboost Sr Member Platinum WOLF's Avatar
    Nov 2016
    Raleigh, North Carolina
    87
    23610
    20 times
    That soot is most likely from you cruising along and then you romp on it, causing it to come out of the tail pipe. I notice it alot more running 91 Octane fuel and my 91 performance tune than my winter 87 tow tune and 87 octane.
    This is normal.
    I appreciate the info. Now on the selecting a catch can. From the looks of things on this forum everyone has their own opinion. Looking for quality, durability, and ease of operation. Effectiveness is key as well.
  2. #102
    7,469
    3252 times
    Quote Originally Posted by Platinum WOLF View Post
    (Pre-$hit show) RX catch can, UPR Mega Can, or Full Race Can seems to be the consensus.
    I personally run a UPR can because of the Customer service from Joe. Any issues or problems I have had in the past 2 and half years has been addressed and dealt with in a timely fashion from him.
  3. #103
    Nov 2016
    87
    23610
    20 times
    I feel like the UPR setup is the easiest to install as well as it comes with all hoses and connections needed. Where did you buy it from? You can get them everywhere
  5. #104
    7,469
    3252 times
    I purchased directly through UPR
  6. #105
    Nov 2016
    87
    23610
    20 times
    Thanks for the info! Ordered
    milesej05 likes this.
  7. #106
    Ecoboost Sr Member ilowr22's Avatar
    Feb 2017
    IL
    51
    29689
    Quote Originally Posted by rbrown View Post
    SP-534
    Gapped to .028 with a tune
    If fully modded with turbos I gap at .021
    15 min job with one hand behind your back.
    No anti-seize, no di-electric grease
    Easy peasy done
    Is it safe to run 0.28 without a tune? Gunna change mine in the near future I just bought plugs today. Tune is in the near future; more curious if that gap is satisfactory for the time being.
    2013 F150 3.5L EcoBoost XLT SuperCrew, Ingot Silver Metallic, aFe Magnum FORCE Stage 2 Pro 5R Intake, TurboSmart SP Supersonic BOV, Evenflow 160 Degree Thermostat, NGK .030 Gapped Plugs, Livernois XV1 Tuned, Full Race Catch Can, Full Race catted Downpipe, Fox 2.0 Coilover level kit with rear shocks, 285/60r20 Cooper Discoverer AT3's on Fuel Mavericks.
  8. #107
    3,448
    1755 times
    Quote Originally Posted by ilowr22 View Post
    Yeah its safe. You can actually mess around with the gap to find where she likes it best. .028-.030 seems to work pretty good.
    Sent from my SM-N900V using Tapatalk
    ilowr22 likes this.
  9. #108
    7,469
    3252 times
    Quote Originally Posted by meaz93 View Post
    Since there hasn't been a new thread on spark plugs lately, I'm sure one will pop up. Maybe stating it here will keep another useless thread from being created.
    New guy: Hey, just rolled over 90K miles and got a misfire code. I assume I need to change out the spark plugs. What plugs should I get?
    Annoyed Forum Members: SP534, gapped to .028-.030
    New guy: Ok, even though you just stated to gap to .028-.030...why not just close the gap tighter, wouldn't that eliminate misfires and rough idles altogether?
    Annoyed Forum Members: SMH...wish Ford4Thot was still around.
    Elmore328 likes this.
  10. #109
    Ecoboost Sr Member msirach's Avatar
    Feb 2017
    IL
    72
    28785
    27 times
    I just changed mine at 130,000 miles. They were worn and had .035 to .045 gap with rounded electrodes. I set the gap at .028 and have put 5000 miles on them. No misfires and it idles smoother. Stomp the pedal and it pulls hard.
  11. #110
    Ecoboost Sr Member Dreadi's Avatar
    Apr 2017
    Tacoma, WA
    81
    33545
    20 times
    After having confirmed that I needed a weep hole in the CAC and having done so, it was time to check the plugs.
    Old plugs a 48k miles.
    Gap was around .042 and I'm off today sooooo. New plugs and boots, gapped at .028. We'll see how it plays out.
    Mr B likes this.
  1. Factory plug replacement
    By Xtrmbldr911 in forum F150 Ecoboost Maintenance
    Last Post: 11-02-2015, 07:00 AM
  2. Ford F150 3.5L V6 Ecoboost Misfires: Spark Plug Replacement
    By makuloco2000 in forum F150 Ecoboost Problems
    Last Post: 02-21-2015, 11:40 AM
  3. Spark plug gap - What was/is yours?
    By dewserb in forum F150 Ecoboost Chat
    Last Post: 01-27-2015, 11:10 AM
  4. Spark plug gap
    By reynolds243 in forum F150 Ecoboost Chat
    Last Post: 12-27-2014, 04:16 AM
  5. MPG After Spark Plug Re-Gap....
    By OxfordFX4 in forum F150 Ecoboost Performance
    Last Post: 10-25-2013, 05:19 AM
2011 f150 ecoboost spark plug replacement
e3 plugs in ecoboost
e3 spark plugs
f150 ecoboost spark plugs
ford f150 ecoboost spark plug replacement interval
