This is my first post to this forum, I just purchased a used 2013 F150 FX4 w/ the EcoBoost 3.5L, 42k miles, and going through normal inspection and preventative maintenance stuff I found the positive battery terminal is very corroded. Since the original battery is almost 4 years old and obviously leaking near the post, and I love having a maintenance-free sealed AGM battery, I ordered an Optima Red Top battery.
I also wanted to replace the terminal with a new one, or course. Well, if you go to Ford and ask them for just the terminal, they don't have it in their system. Instead they quoted me $269.99 for the whole positive side harness! I did some looking around on Amazon and found that the Ford Edge shares the same terminal, so I grabbed the part number and called the local parts dept. They DO sell that separately... Ford part number is BT4Z-14450-AA, my dealer had it for $13.99.
You will have to remove one crimp from your old terminal, and recrimp the cable on the new one, but it can be done if you're careful with a die grinder, and recrimped with a hammer and pliers if you don't have access to the proper crimping tools. I will be replacing later this week once my battery shows up but I thought I'd pass this along since the parts guy at the dealership was clueless.
I'm not sure if they figure that if you can afford a $40-50k truck, you can afford to spend $250+ to replace a corroded terminal, or what, since it's the exact same part on the Edge.
-Aaron
-Aaron
