Cab corner replacement - Page 4
This is a discussion on Cab corner replacement within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Originally Posted by winchested Did you ever get it oiled to actually protect the metal? No oil treatment. I did have a rubber undercoating on ...
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Like Tree13Likes
Thread: Cab corner replacement
  1. #31
    Ecoboost Sr Member adkhunter1590's Avatar
    Jul 2016
    51
    17945
    12 times
    Quote Originally Posted by winchested View Post
    No oil treatment. I did have a rubber undercoating on most of the underbody but it flaked off within the first few years. Dealer I bought it from applied that stuff and idk what it was but it sucked. I moved 2000 miles away after buying the truck so I never went back to complain about it.
    I have a 2016 Titan XD that will be getting a oil treatment before winter though. Hoping to get that truck to last longer.
  2. #32
    Ecoboost Veteran Burns363R's Avatar
    Iowa
    316
    6432
    60 times
    Replacing one of my cab corners now. The dealership is putting POR on everything inside. I had them run the drain tube out the inside rocker. Im going to peel all my tape off both sides after this is all said and done and POR everything inside the rockers. I also now know where the double wall is in the cab corner, so i can drill my hole high enough to clear the double wall on the drivers side and get POR on both sides of the cab corner to stop any rusting. Hopfully i can get my hands on the drain tube and get it routed outside as well.
    12' F-150 SCREW, FX4, 3.5TT, CRP Manifolds/SPD Turbo Adapters/MBRP Offroad DP/AFE Intake/170 tstat/CP-E intercooler, 3.73 gear, 33" Duratrac
  3. #33
    4,240
    1228 times
    Quote Originally Posted by Burns363R View Post
    Do you have a sunroof?
  5. #34
    4,240
    1228 times
    Also, i know you guys with 4 doors, the back cab corner/back piece of door is very slim. On my regular cab, it is wide. I wonder if water etc gets trapped in there easier?
  6. #35
    Iowa
    316
    6432
    60 times
    Yes.
    My dad has a 2012 Screw as well with no sunroof. He has worse rot than I do.
  7. #36
    4,240
    1228 times
    The information I saw on that the lines barely make the hole. I would get some kind of connector that you can fit into the drain tube and then extend it out the hole completely.
  8. #37
    Ecoboost Jr Member Birdman15's Avatar
    Burlington, Ontario Canada
    42
    65998
    reading over this, has anyone actually ( I know hard to think about ) drilled a small drain hole in the bottom underside of the corner so water just drains out?
    I have 2014 SCREW with sunroof. I see currently nothing starting yet. I live in Ontario Canada so lots of road salt & moisture for sure. I have seen videos of people trying to re-route the sunroof rear drain tubes, spray RUST CHECK or FLUID FILM type of stuff in there, but what if there was a actual drain hole there? I mean when they do oil spraying they drill holes and cap them, but what if not capped, paint off the fresh drill metal then still spray a rust inhibitor in there. with this drain hole all water & moisture would just come right out now? just wondering if anyone has drilled.
  9. #38
    Iowa
    316
    6432
    60 times
    There is a double wall. Make sure you drill more towards the outside of the truck if you want to have any chance getting anything to drain from the parts thats actually rusting.
  10. #39
    42
    65998
    so drilling right from the bottom straight up in will not clear this double wall?
  11. #40
    Iowa
    316
    6432
    60 times
    No way of knowing which side of the double wall you are on.
  1. With summer around the corner Let's see the boats
    By sloans4x4 in forum F150 Ecoboost Towing
    Last Post: 04-27-2017, 01:49 PM
  2. Sound system in crew cab aka extended cab
    By cumbersome101 in forum F150 Ecoboost Chat
    Last Post: 09-18-2016, 02:38 PM
  3. bugs in the cab!
    By mchapp2 in forum F150 Ecoboost Chat
    Last Post: 03-07-2016, 03:07 PM
  4. Sub Box in a Regular Cab?
    By Abraham5G in forum F150 Ecoboost Electronics
    Last Post: 09-24-2014, 10:05 AM
  5. '11 EB Crew Cab Build
    By C.swanson21 in forum F150 Ecoboost Builds
    Last Post: 07-29-2014, 08:29 PM
how much will it cost to replace cab corners on a 2013 f150
tape or no tape over rocker panel holes
