Fluid Change - Page 3
Fluid Change
This is a discussion on Fluid Change within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Check this out from fordtechmakuloco... his take on Ford's Recommended Service intervals are that they set you up for a bunch of expensive repairs out ...
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Like Tree8Likes
Thread: Fluid Change
    Ecoboost Jr Member snydmax's Avatar
    Feb 2019
    23
    70114
    Check this out from fordtechmakuloco... his take on Ford's Recommended Service intervals are that they set you up for a bunch of expensive repairs out of warranty. He seems to know his way around the EB and has a bunch of informative videos on youtube.
    goJim likes this.
    Ecoboost Regular SkyMaster19's Avatar
    Sep 2013
    South Florida
    137
    2429
    18 times
    Getting all fluids changed tomorrow at the dealer minus the oil. 107K 2012 3.5. Let them have the mess that would happen as well as in their records for my extended warranty.
    Ecoboost Jr Member Warthog5's Avatar
    Dec 2014
    Pensacola,Fl.
    35
    7397
    17 times
    I been waiting on the 35,000 mark to roll around. Yes I took it to the Lincoln dealer where I know a few of the line mechanics. I will not deal with local Ford dealer.
    Anyway The work I had done was slightly over $700....Ouch! Trans got flushed....BG cleaner run thru it. Then I had them drop the pan clean any clutch residue and metal off the magnets and change the filter. Obviously more fluid then too.
    I keep a vehicle. So I want to take care of it.
    The line mechanic said....You got it broken in now and your doing it right.
    2015 F150 XLT S/Cab - 4X4 - 3.5EB - 3:55 Elec lock - Ruby Red - 302A Equip Group - Blind spot system - Nav - Max Tow - Tailgate step -Ext range tank - Bed Extender
    Ecoboost Veteran mj0528's Avatar
    442
    57273
    45 times
    Quote Originally Posted by 716ap2 View Post
    So I called the dealership to schedule a transmission and rear diff service. I'm currently at 32k on my 2017 3.5 ecoboost. When I told them the mileage, they stated there was no need until I hit 60k. Does this seem correct? This is my first ford and all my gm trucks were always down around 30k..
    Did you get the roll pin TSB on your 2017? Mine had a TSB so they dropped the pan and apparently used 7 quarts to fill back up. That was at 20k so I will do a filter and refresh in 5k or so.
    Might be a way to get some transmission maintenance for free plus an issue fixed!
    Ecoboost Veteran GuyGene's Avatar
    Columbia Co, GA & Ozarks, MO
    295
    2088
    60 times
    My 2015 only has 26,000 miles now, but I think I will have all fluids changed at 30,000. Differential, transmission, transfer case, etc. Probably wait until 50k or so for the coolant. Then brake fluid at same time I think.
    That old man, he don't think like no old man.
    "He's pinned under an outcropping of rock. Lucky for him, the rock kept the dirt from burying him alive."
    "I thought I was wrong one time, but I was mistaken." Command Sergeant Major Jim
    Your = Is that your truck? Possessive.
    You're = You are. E.g., You're a nice old boy, and I like your truck.
    '15 Platinum Supercrew, 3.5, 3:31 differential, 4x4, White, comes when you call it.
  1. Replies: 3
    Last Post: 06-05-2016, 04:52 AM
  2. How hard is it to do: Coolant Flush and Rear diff fluid change?
    By Kbuicker in forum F150 Ecoboost Maintenance
    Last Post: 09-21-2015, 09:49 AM
  3. Change your Brake Fluid!
    By Talley in forum F150 Ecoboost Brakes
    Last Post: 08-13-2015, 01:25 PM
  4. Transmission and differential fluid change??
    By Ccmul in forum F150 Ecoboost Chat
    Last Post: 02-16-2015, 09:19 PM
  5. Transmission fluid change
    By fieldsleah in forum F150 Ecoboost Maintenance
    Last Post: 11-21-2014, 11:38 AM
2013 f150 ecoboost transmission fluid change
