2017 9.75 rear diff fluid change
This is a discussion on 2017 9.75 rear diff fluid change within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Changed the fluid but I'm noticing that there is a hole in the diff that looks like it should have a bolt that goes through ...
Results 1 to 4 of 4
    Ecoboost Veteran mj0528's Avatar
    421
    57273
    42 times
    Changed the fluid but I'm noticing that there is a hole in the diff that looks like it should have a bolt that goes through the front and through the rear (part of diff that is facing the front of the truck)
    I used a lube locker gasket and cleaned the RTF very meticulously and no other leaks. I also noticed this after a drive as it was dry before the drive.
    I don't recall a bolt longer than others so I'm wondering if RTF needs to be inserted. Stuck a piece of paper towel to make sure I'm not crazy
    Oc
    649
    4453
    235 times
    Isn’t that just the back side of where the cover bolts thread in?
    421
    57273
    42 times
    Quote Originally Posted by Mulyhuntr View Post
    There is one that has a whole on the backside which I thought was odd
    421
    57273
    42 times
    Paper towel is dry as a bone. Looks like I may have not dried it up.
    The lube locker will make for an easy change next time
  1. What frequency those who tow a lot change trans and diff fluid?
    By Track Out in forum F150 Ecoboost Towing
    Last Post: 09-01-2018, 04:49 PM
  2. Rear diff fluid and cover upgrade
    By noodles in forum F150 Ecoboost Maintenance
    Last Post: 08-14-2016, 09:43 PM
  3. How hard is it to do: Coolant Flush and Rear diff fluid change?
    By Kbuicker in forum F150 Ecoboost Maintenance
    Last Post: 09-21-2015, 09:49 AM
  4. Transmission Fluid Exchange and Rear Diff
    By coyconner1983 in forum F150 Ecoboost Chat
    Last Post: 09-17-2015, 05:35 PM
  5. Nitro 9.75" diff cover
    By BlueFlameFX4 in forum Buy/Sale/Trade
    Last Post: 08-29-2015, 11:13 AM
