2013 Limited - Coolant Leak
This is a discussion on 2013 Limited - Coolant Leak within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; I noticed my reservoir was empty when I changed my air filter the other week. So I topped it off... it's gone down already... so ...
Results 1 to 8 of 8
  • 1 Post By jibtechwarrior
Thread: 2013 Limited - Coolant Leak
    Rookie tri4autism's Avatar
    8
    52226
    I noticed my reservoir was empty when I changed my air filter the other week. So I topped it off... it's gone down already... so I'm thinking I've got a leak somewhere.
    I do not have anything leaking to the point of a puddle or any obvious signs.
    From what I'm reading on here, there are a couple places it seems to leak from.
    1. Reservoir joint
    2. Fitting on turbos
    3. T-fitting
    Anywhere else I can check? I looked at the fittings under the reservoir and don't see anything there... like I said no puddles either. Hoping it's not the turbo fitting... looks like it could be a bit of work pulling the turbos.
    TIA
    859
    280 times
    Could also be a blown head gasket and you don't see a puddle because your motor is trying to combust the liquid leaking in there.
    Also check your oil. I think it's possible that the oil cooler can leak coolant inside it.
    1,219
    449 times
    I remember that elbow leak is pretty quick and doesn't leave much evidence. Maybe get some dye in the system too?
    Ecoboost Veteran jibtechwarrior's Avatar
    edmonton, alberta
    289
    61321
    72 times
    Check the underside of the elbow at the reservoir, that's where the drip propagates from. It will end up on the d/s frame rail as well. Stick your hand or a paper towel under there and see if it comes back greasy/coolanty. Super common and pegasus racing makes a kit that solves the problem 100%.
    GearHead_1 likes this.
    8
    52226
    Quote Originally Posted by jibtechwarrior View Post
    Found the kit here:
    Pegasus Kit on Amazon
    Will check it more thoroughly as it's been mentioned a few times.. the reservoir elbow that is. As I understand it, there's an o-ring in there that goes bad... the Pegasus would certainly resolve that... forever. Fingers crossed it really is leaking and that's all it is. Simple fix if so!
    Mishimoto's Avatar
    Nov 2014
    DE
    260
    7092
    141 times
    Quote Originally Posted by tri4autism View Post
    Found the kit here:
    Hey @tri4autism,
    Did you find your leak? If it was the quick-disconnect at the bottom of the tank, you might want to check out our replacement expansion tank. Our tank replaces that QD and a portion of the stock line with a proper barbed fitting and silicone hose. The QD fitting on the tank isn't designed to hold a hose with a worm-gear clamp and we've seen a few continue to leak with that method.
    Feel free to let me know if you have any questions or if we can help in any other way!
    -Steve
    edmonton, alberta
    289
    61321
    72 times
    When installed properly that pegasus kit is bang on. It is a little janky in construction, but it does work.
    Ecoboost Sr Member Lghtnfst's Avatar
    Dec 2018
    Raleigh, NC
    77
    69342
    18 times
    "janky in construction" that is a good way to describe the Pegasus kit. I installed mine about a year ago, and you definitely know it's not factory, but like you said it gets the job done
  1. Coolant leak at expansion tank
    By Brute840 in forum F150 Ecoboost Problems
    Last Post: 08-24-2017, 08:36 AM
  2. 2013 F150 Turbo coolant tube leak
    By palacios289 in forum F150 Ecoboost Problems
    Last Post: 04-05-2017, 01:12 PM
  3. Ford F150 EB Coolant Leak...what is this part? (video)
    By chdev77 in forum F150 Ecoboost Problems
    Last Post: 03-27-2016, 02:21 PM
  4. Coolant leak
    By bohnman in forum F150 Ecoboost Maintenance
    Last Post: 01-17-2016, 04:50 PM
  5. Another coolant leak thread
    By boosted6 in forum F150 Ecoboost Problems
    Last Post: 05-03-2015, 10:15 AM
