2013 Aging , maintenance and Towing performance (or lack of) - Page 3
This is a discussion on 2013 Aging , maintenance and Towing performance (or lack of) within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Originally Posted by DNA Dan When I did my tests with different octanes while towing I found that the engine seemed to run a little ...
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Like Tree8Likes
Thread: 2013 Aging , maintenance and Towing performance (or lack of)
    Ecoboost Jr Member 2013EBF150's Avatar
    Louisiana
    29
    8314
    When I did my tests with different octanes while towing I found that the engine seemed to run a little cooler the higher the octane. The PCM can advance timing more, for a longer period of time on the higher octane. I found only a slight difference between 87 and 91 that is blended with ethanol. However, if you can find NON-ethanol 91-93, then the differences are much more noticeable. The cost of pure gas however negates any savings over blended 87. In fact, it may end up costing you more because you don't gain an equal amount of MPG to make up the difference.
    Now if you routinely ran 87-89 in the past, you shouldn't have to put higher octane in the tank to "regain" performance from before. So if your habits haven't changed, but the truck has, then I would still focus on fixing the truck's performance.
    Towing I have tried to always run 93. I’m sure I’ve forgotten before but I’ll be sure to try and run 93 from now on.
    The PSI readings from this morning are perplexing though. I talked to our company mechanic about it and he had the same puzzled look on his face. We decided if the two sensors are the same part number maybe I should flip-flop them, and see what happens.
    3,223
    1144 times
    Quote Originally Posted by 2013EBF150 View Post
    Never considered compression. The truck runs really smooth just doesnít pull like I remember.
    I have the Torque Pro but rarely use it but I hooked it up for a few minutes this morning.
    My old android phone seems to have lost all my PIDs but I was able to get ďIntake Manifold pressureĒ and ďTurbo Boost and VacuumĒ. The intake manifold read constantly higher than the other. Iím not sure of location on either. I assume the intake manifold is the one on top the manifold and behind the throttle body. The second is on the charge pipe. Memory is a little fuzzy but it shouldnít be hard for me to locate. Hereís what I thought was interesting and I donít recall this before. The manifold consistently read way over 13.5psi. While the boost/vacuum gauge would only peak at 13.5. I didnít have a long straight away to make sure it would hold 13.5psi so Iím not ready to say it wonít but that was a problem before I replaced the BOV earlier this year. I would like to think under normal conditions the manifold would be slightly lower than the charge pipe not massively higher. Looks like itís peak was 28-29psi. Which is way out of spec but no check engines and no faults.
    Intake manifold pressure is in absolute psi. Its boost + atmospheric pressure.
    Turbo boost is gauge pressure. It is manifold absolute pressure - atmospheric pressure.
    Intake manifold pressure should be 14.7 psi higher than turbo boost if you are at sea level. This would make sense since you saw 28-29 psi at the intake while seeing 13.5 psi of turbo boost.
    Both are reading the same sensor, they are just offset by atmospheric pressure.
    kettels likes this.
    3,223
    1144 times
    Towing I have tried to always run 93. Iím sure Iíve forgotten before but Iíll be sure to try and run 93 from now on.
    Do not swap the map sensor before and after the throttle body. They are scaled different in the PCM because the one before the throttle body is a 3 BAR map and the one on the manifold is a 2.5 BAR map. It would screw up your pcm ability to read the boost, probably throw codes, go into limp mode, or worse.
    snakebitten and kettels like this.
    Louisiana
    29
    8314
    Awesome thanks for the info I would have confirmed part numbers match. But it doesn’t sound like a worth while test based on the scaling you mentioned they are working correctly.
    Rookie rodgersfam1980's Avatar
    12
    11170
    You're experienced enough, you probably already know about these tricks, so if I'm being too simple, I apologize.
    First off, have your dealer reset your KAM or CAM memory. (If they don't know what that is, you should find a smarter dealer). My dealer is great, and even resets mine for free if I'm having other work done. Otherwise, they charge about $39.
    Clean your mass air flow (MAF) sensor. Buy the appropriate CRC kit from pretty much any auto parts store, maybe even Walmart. Do a search on YouTube to see vid explaining how-to.
    Cleaning MAF sensor is so easy, you should never pay a mechanic to do it.
    You may find your MAF to be damaged or broken. If so, that may be the root of your problem. However, that "should" be throwing a code or three, so I doubt that is the problem..
    Best of luck...
    Sent from my SM-G950U1 using Tapatalk
    3,223
    1144 times
    There is no MAF on the 2013, only a 2011, and even then its not functional. There are 3 map sensors on trucks after 2011. But yes you could clean em.
    rodgersfam1980 likes this.
    1,204
    445 times
    Quote Originally Posted by rodgersfam1980 View Post
    Best of luck...
    You can reset your KAM by disconnecting your battery and leaving your headlights on to fully discharge. Then it should reset.
    Louisiana
    29
    8314
    I assumed that was what he was talking doubt I ever knew the proper name.
