changing spark plugs - Page 4
This is a discussion on changing spark plugs within the F150 Ecoboost Maintenance forums, part of the F150 Ecoboost Garage category; Originally Posted by snakebitten Miles gets us all labeled. He's cantankerous, would you say? Sent from my SM-N950U using Tapatalk pshh...whatever....
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Like Tree18Likes
Thread: changing spark plugs
  1. #31
    7,600
    3305 times
    pshh...whatever.
  2. #32
    1,909
    1072 times
    Quote Originally Posted by DBCooper View Post
    Most tuners will recommend the Motorcraft SP-542s. They are one heat range colder and gap is .026-.028. Trial and error on the gap. Try .026 then next change try the .028. Or maybe it is somewhere in between them that works best for you.
    I hope this helps.
    Same recommendation here. Your tuner would be your best source.
    I’m running a pretty modified configuration and run the SP-542’s @ .026.
    These plugs fall under the “extremely cold” designation from Ford
  3. #33
    Ecoboost Regular Fstrnyou's Avatar
    SC, near Charlotte NC
    109
    70710
    40 times
    I think I read somewhere that the correct plug is 7. And the gap should be 7.
  5. #34
    466
    66176
    209 times
    Quote Originally Posted by Fstrnyou View Post
    Incorrect. The answer is always 42.
  6. #35
    Ecoboost Jr Member Willshire's Avatar
    Jun 2019
    Small Town, Ontario, Canada
    31
    71852
    Quote Originally Posted by tvsjr View Post
    29 goes into 29, 29 times. Twanny, twan, twan......
    542s at .26. Beats the 350 vortec champion coppers at .56 in the racecar. But we want a hot burn in the old 2 barrel tugboat
  7. #36
    Ecoboost Regular butthead's Avatar
    WI
    118
    36530
    49 times
    Tuner for my 2.7 recommended NGK 6510 gaped .026-.028. OEM plugs pulled were around .030. I used .026 because all my experience was that gaps widen with time and it's a pressurized engine. Have several thousand miles on them now running very well, idle did seem smoother. Happy with the BCB recommendation and will use them again.
    Far cry and difference from the plug eating high performance motors of my youth (ran a 68 Z28 that ate plugs quickly). KM
    2017 XL 2.7EB 6speed 2WD RCSB 3.73EL, Supernova V.3-XD Pulley300-Nitto Grappler G2-Pypes 4 inch catback-Bullydog GTX with BCB tunes-Icon Stage 1
  8. #37
    Ecoboost Regular 2016XLT4x4's Avatar
    Texas Hill Country
    121
    25641
    52 times
    Hitchhikers Guide to the Galaxy? I think I have read every book that Douglas Adams wrote.
    2016 XLT Crew Cab 4x4
    2.7 / 6spd / 3:55's / 302A package Texas Edition / Twin panel moonroof / 2" level kit / Westin grill guard / 9500# winch
  9. #38
    466
    66176
    209 times
    Quote Originally Posted by 2016XLT4x4 View Post
    I knew there had to be another hitchhiker around here.
  10. #39
    Olathe Ks
    761
    14790
    214 times
    Us hitchhikers are everywhere but you just can't see us. We blend in well with the general population.
    ~Jim~
    2012 Lariat Screw; 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 KO2s
  11. #40
    3,896
    3178 times
    Ummmm, DBCooper, I'm sorry but I just don't see you blending in.
