Hang in parking brake - Page 2
This is a discussion on Hang in parking brake within the F150 Ecoboost Brakes forums, part of the F150 Ecoboost Garage category; Originally Posted by WooBoost Word for the wise, use parking brake every time you park. Apply it while in gear or N, then go to ...
Results 11 to 18 of 18
Thread: Hang in parking brake
    7,614
    3311 times
    Word for the wise, use parking brake every time you park. Apply it while in gear or N, then go to P. This help keep all the tension off the park pin. I do this every time. Also you won't have problems with the brake freezing like noted above.
    YOu apply while in Neutral or in Gear? Guess I never thought about it
    Gold Supporting Member Marvin's Avatar
    Mar 2015
    Bancoober, BeeZee
    539
    9196
    270 times
    I put it in P, keeping my right foot on the brake pedal, engage the parking brake, and then let the brake pedal go.
    Same outcome. I'm with you: I don't like the parking pawl bearing any tension.
    Pax.
    - Marvin
    ______________________________________
    2013 F-150 Platinum / White Platinum / DuraTracs/ Roadmaster Active Suspension / Rx Catch Can / Wagner CAC / BakFlip FiberMax
    “The question is not 'Can they reason,' nor, 'Can they talk,' but, 'Can they suffer?' " - Jeremy Bentham
    4,210
    1215 times
    yes, half of the time i even forget to put it in park, it wont let you remove the key unless in park so I shift it to park after turning truck off.
    And then I shift it to drive before removing brake too, the gauge cluster screen goes nuts telling you emergency brake it on before you release it.
    Rookie adamglista's Avatar
    Buffalo Grove, IL
    6039
    I have 27,000 miles on my 2014 FX4 and use my parking brake ALL the time. Lately, it has been hanging up and not releasing all the way. Also, there is a nasty high pitch metal squeal when under 5MPH in drive or reverse. Ford said the backing plates had to be replaced because of corrosion(this apparently requires the axle to be dropped). How does it get corroded if I use it all the time and with Ford asking about $600 to do the job, does anyone have any insight on this? Of course my warranty expired in April! Maybe a Ford Service Rep could help me out? Thanks....
    2014 Oxford White FX4 SuperCrew Shortbed (stock)
    3,894
    1738 times
    Quote Originally Posted by adamglista View Post
    Seeing as your truck is a 2014, I do not understand why they need replacing this early, unless maybe they got bent enough to rub the rotor.
    By the time backing plates need replacing due to corrosion, the rest of the truck isn't too far behind.
    Buffalo Grove, IL
    6039
    Yeah, I might understand if I never used the parking brake it could corrode. But when I engage and release about 3 times a day.... Seems like crap craftsmanship. Might even look at a different brand truck. Nissan Titan looks like hell but they seem to have a decent warranty.
    Ecoboost Pro Jsrunnlus's Avatar
    Piedmont, SC
    728
    1980
    186 times
    My guess would be something to do wit what they put on the roads in Illinois for winter season. Wasn't there a person here not long ago from Idaho who mentioned having a truck about the same period with rust on the cab corner? Whatever they are using in Ohio and West Virginia is also extremely rough on the undercarriages - even if you wash it fairly frequently. Recently replaced some fairly pricey backing plates on a Mitsubishi. Coated them with a spray rubber to protect from the Ohio chemicals. Too soon to tell how it will work out. I have never tested Ford's warranty on backing plates, but the corrosion warranty is much longer than the 3/36 bumper to bumper.
    Nissan is usually quite good with their warranty support. If memory serves the new Titan has a 5/100k bumper to bumper warranty. I have seen dealers replace front hubs that were shred from high speed off road use as well as brakes from towing beyond the vehicle's rating. Fred Diaz of Ram went to Nissan when obama gave Chrysler to Fiat. The Cummins that was headed for Ram also went to Nissan.
    2015 F150 SuperCrew 4x4 King Ranch, 3.5L EcoBoost w/ Max Tow (3.55) - Blue Jeans Metallic w/ Caribou accent, 601A equip, Tech pkg, ACC, FX4, Wheel Well Liners, Tail Gate Step, Box Side Steps, Diode Dynamics XML2 LED bulbs, WeatherTech Floor Liner, Recon Xtreme Scanning Tailgate LED, Amber LED Grill Light
    Ecoboost Veteran devin's Avatar
    Aug 2016
    Pacific Northwest
    415
    19409
    107 times
    My truck is doing this now. Any solution so far aside from replacing the cable?
    Devin
    Sold it! No truck for now.
  1. Parking Brake Adjustment/Alarm Sensor
    By norcal_ecoscrew in forum F150 Ecoboost Problems
    Last Post: 01-06-2017, 05:43 PM
  2. Brighter Running/Parking lights
    By Motodmast in forum F150 Ecoboost Lighting
    Last Post: 01-09-2015, 04:48 AM
  3. LED 3157 (parking/turn bulb) Replacement - hyperflash or other issues?
    By Bwlandu in forum F150 Ecoboost Appearance
    Last Post: 04-07-2014, 08:24 AM
  4. Parking the F-150
    By randomwalker in forum F150 Ecoboost Chat
    Last Post: 02-23-2014, 05:35 PM
  5. Truck moves after parking brake...
    By tragusa3 in forum F150 Ecoboost Problems
    Last Post: 01-12-2014, 03:45 AM
2015 f 150 problems with parking brake and hill assist light
all threads hang on park
f-150 parking brake forum
f150 parking brake getting weak 2014
parking brake hanging up 2014 f150
