Trying to do a brake job, rear wheels will not come off. - Page 3
This is a discussion on Trying to do a brake job, rear wheels will not come off. within the F150 Ecoboost Brakes forums, part of the F150 Ecoboost Garage category; @ FUHL I didn't read the other comments, but I had the SAME problem when I mount my snow tires (separate rims) back in 2013. ...
Results 21 to 30 of 31
Like Tree20Likes
Thread: Trying to do a brake job, rear wheels will not come off.
    Eco-Beast Grim Reaper's Avatar
    Prisoner of the other ........... 39% minority
    4,654
    1898
    2325 times
    @FUHL I didn't read the other comments, but I had the SAME problem when I mount my snow tires (separate rims) back in 2013.
    I modified a larger 3 prong gear puller and used a socket extension 1/2" drive, that I put in the center to increase it's length. I then have each prong on the metal part of the wheel, and keep turning until it pops off.
    When it first happened, my brother and I tried about a half dozen of Old School tricks (including heat) ... nothing worked.
    That was when I went through my tool chest, found the large 3 prong gear puller - put the socket extension on the center part, and worked like a charge without any hammering etc.
    https://www.bearingscanada.com/produ...iABEgLDKfD_BwE
    Here is a link to a similar gear puller I used.
    FUHL likes this.
    2013 F-150 4x4 Supercab 145"WB Ecoboost XLT, Group 302A, XTR Trailer Package, E-Lock 3.55s ...
    Bolt-ons Installed:
    Banks CAI, Wagner CAC, Full Race Catted Downpipes, Custom 3" exhaust w/3" Flowmaster dBX Muffler
    Tuned by Torrie McPhail at www.unleashedtuning.com 91+ Octane 535 RWTQ @ 2750 / 372 RWHP @ 4900 - (Mustang Dyno)
    Mods (Waiting): Mishimoto Hardpipes, Tifosi Ported & Ceramic Coated Exhaust Manifolds, Full Race GT Turbos & SPD Ported Adapters
    Ecoboost Sr Member Bird1's Avatar
    Jan 2018
    Southern Illinois
    59
    54266
    19 times
    I've tried many ways to break them free but the one and only successful method involved smacking the inside of the tire with a big sledge hammer.
    FUHL likes this.
    2014 F 150 Supercab XLT 4wd 3.5 Ecoboost
    Rookie medic149's Avatar
    19
    4048
    4 times
    I've had the same problem every single time I need to pull the wheels. I've had to get my buddy to come help me. Sprayed WD40 all inside the rim and lug nuts. Then we took turns hitting the tire with a sledge hammer, with wood in front of the rim so not to damage it. It finally came off, but it took forever. Good luck.
    Rookie Zremac's Avatar
    Apr 2017
    Chicago
    34073
    So physical...ok you will need pice of 2x4
    1 loose your lug nuts keep it loose of the wheel you want to remove
    2 lift the side of your truck/car you want to remove a wheel
    3 put 2x4 underneath of tire half way of it’s width
    4 drop your truck/car on 2x4 in control matter
    It works always beats driving around with loose lug nuts or beating tire with sledge hammer
    Ecoboost Jr Member snydmax's Avatar
    Feb 2019
    23
    70114
    Us hillbillies like to get out the blow torch when metal gets stuck together... with today's powdercoated rims, not sure this would be the smartest idea but I wonder if simply getting things hot on an aggressive drive (with lots of braking) would help to free your wheel...
    Seriously though, I had this problem systemically on an A4 I used to have until I started coating the mating surfaces with anti seize. Once you get it loose, be sure to take this step to prevent the problem in the future. I like to put a little on the lug studs too
    2011 FX4 SCrew level’d bagg’d & CAC’d 17.5avmpg
    Rookie jimbobjo's Avatar
    64634
    I know its crazy, but i used a spare tire jack,
    scissor style.
    Put a 3/4 socket on an adapter with my impact driver and worked it off.
    you will have to move spots to work it off evenly.
    I did it for my 02 Honda accord, and '10 chrysler town and country.... keep in mind you will need to keep the caliper up and out of the way
    Rookie 13PlatinumBoost's Avatar
    Apr 2019
    71024
    I had the same issue and here is what I did:
    I went down to the local part store and borrowed a little 7 & 5 ton gear puller. The 3 jaws are held on by a simple nut at each of the 3 pivots. Combine the jaws on the 5 ton to the jaws on the 7 ton and WHAM! A Ford F-150 PITA rear rotor puller is born.
    In all seriousness, just return the tool and they'll give you the refund. It's free.
    Eco-Beast FUHL's Avatar
    Nov 2013
    Sandpoint Idaho
    1,886
    2965
    1132 times
    Got them off.
    Penetrating oil soaked for a week. Sledge hammer on the backside.
    Thanks for all of the suggestions.
    2013 Ford XLT 4X4, 2013 Range Rover Evoque, 2007 Can-AM Renegade 800, 2001 Yamaha TT-R125L, 2016 Beta Xtrainer 300 Traci, as in Traci Lords, because it is like riding a young porn star. 2018 Jeep Wrangler Rubicon 2-Door.
    Oc
    674
    4453
    251 times
    Hopefully you put some anti-seize on the rotor hat before reinstalling?
    FUHL likes this.
    Ecoboost Jr Member ForestMyth's Avatar
    Dec 2012
    Ft. Bragg, NC.
    35
    77
    Next time just put a bottle jack on the inside rim of the opposite wheel, then position either a 4x4 post or steel pipe between the jack and the inside of the rim your trying to remove and just start jacking. It works like a charm on the 18 wheelers I've had the same road salt rust issues with.
  1. Dealership scam? Brake job suggested at 27000km's
    By Jordan in forum F150 Ecoboost Chat
    Last Post: 08-13-2018, 10:56 AM
  2. Trying to upgrade to an after market wheels and tires which will fit and work?
    By Hyperider in forum F150 Ecoboost Wheels and Tires
    Last Post: 04-06-2016, 03:27 PM
  3. Do these pickups come with bluetooth connectivity for your phone?
    By futuref150 in forum F150 Ecoboost Chat
    Last Post: 06-18-2015, 02:39 AM
  4. What temp do fans come on?
    By gotboost150 in forum F150 Ecoboost Performance
    Last Post: 07-10-2014, 07:36 PM
