Door Trim (Ultra ROokie Question)
This is a discussion on Door Trim (Ultra ROokie Question) within the F150 Ecoboost Accessories forums, part of the F150 Ecoboost Forum category; The door trim on my vehicle needs to be replaced entirely. I've removed it but of course there's a layer of gunk and glue there. ...
Results 1 to 4 of 4
    Rookie Shinespike's Avatar
    May 2019
    4
    71532
    The door trim on my vehicle needs to be replaced entirely. I've removed it but of course there's a layer of gunk and glue there. Before I start blasting it with Goo Gone, is there a better alternative anyone has used that won't damage the paint? Thanks!
    Ecoboost Jr Member stereotype one's Avatar
    Sep 2017
    Austin Texas
    48
    45706
    28 times
    I have no idea what glue is used (never had to mess with the door trim on my truck, knock on wood), but Goo Gone should be safe. 3M also makes a silicone remover if the glue is silicone based; I've used it on paint with no issues.
    Cheers,
    -David
    May 2019
    4
    71532
    Thanks!
    Rookie Pacsun82's Avatar
    Oct 2017
    14
    48330
    7 times
    Google "3M adhesive eraser wheel" your fingers will thank you!
  1. Rookie Question: Would Eliminating Turbos Fix a Lot of Problems?
    By Jeff Carver in forum F150 Ecoboost Problems
    Last Post: 06-23-2018, 03:24 AM
  2. Removing door trim
    By jskwarek in forum F150 Ecoboost Chat
    Last Post: 04-17-2016, 09:05 AM
  3. Replies: 4
    Last Post: 12-01-2015, 08:18 AM
  4. Question about Ultra Gauge
    By benelli7d in forum F150 Ecoboost Chat
    Last Post: 01-13-2015, 08:03 AM
  5. Door panel trim
    By JR66Ford in forum F150 Ecoboost Appearance
    Last Post: 07-03-2014, 04:39 PM
