Still running hot when towing - Page 25
This is a discussion on Still running hot when towing within the F150 Ecoboost Towing forums, part of the F150 Ecoboost Forum category; I still think an underdrive pulley on the water pump would be possible with the right engineering....
Page 25 of 31 FirstFirst ... 152324252627 ... LastLast
Results 241 to 250 of 307
Like Tree66Likes
Thread: Still running hot when towing
  1. #241
    775
    242 times
    ARE Z-Series topper w/Yakima rack, Bilstein 5100's, StopTech Sport brakes, BFG T/A KO2 on stock rims, RXP Catch can w/UPR check valves, FR Gen 2 Radiator, Saudi Trans cooler, CR Performance Engineering exhaust manifolds, Rear blocks removed, Firestone Air bags.
  2. #242
    2,948
    1016 times
    I thought about buying one to look at. They arn't THAT expensive. I believe the biggest hurdle might be that you cannot fit a smaller pulley on it because of the crap behind the pulley.
  3. #243
    775
    242 times
    I feel like it being more linear with opening and closing will help as well. It wont cool down and just shut prohibiting coolant flow and giving it a chance to spike. I did bite the bullet and bought some Amsoil HD coolant as well. As soon as it warms up I am going to do the flush as well
    I just came across the higher temp SPD stat over at 5 Star tuning: https://5startuning.com/product/spd-...ostat-ts18035/
    Doesn't drop at low as the 170* ones that I keep seeing, so if there's an increase in performance it might be a good "in-between" stat for those in colder climates. It sure is expensive for what it is. I checked the SPD website and it's not even listed. I wonder if this is new or a discontinued part.
  5. #244
    1,030
    363 times
    Never heard of that one? That is news to me. Did you get in the stant yet??
    Gearhead Tuned
    Wagner CAC - Accel Copper Plugs
    Bilstein 5100's
  6. #245
    775
    242 times
    Not yet. Wondering if I should spring for the SPD 180* and do a three-way comparison. We got pummeled with the pineapple express making it's way across the west coast so I'm sure shipping will be delayed a few days due to weather.
  7. #246
    3,446
    1753 times
    How about the 5* RAT 170° T? That's what I have not a SPD. :blush:
  8. #247
    775
    242 times
    Truck takes forever to warm up in my area with stock stat as it is (Currently about 5 degrees outside). If I install the 170 the truck would be making ice cubes. Looking for something with more flow or better control without the low temp aspect.
  9. #248
    Ecoboost Veteran trev's Avatar
    Lower Mainland, BC
    454
    7617
    140 times
    The only thing a lower t-stat is going to do is give you an extra few seconds before you begin to overheat. They work great for quick sprints but offer little benefit for prolonged high loads (towing).
    The stock t-stat opens around 180-190'ish? But everybody is complaining of temps above 220. Wide open is wide open.
    I ran a 170 for a full year and wasn't impressed. When coasting down hill in cooler weather coolant temps would drop down to 160f
    2014 FX4 screw, max tow, 3.73, 402a, 5.5', Unleashed 91 & 93, Wagner CAC, solo res DP's, DO water meth inj, Helwig RSB, Bilstein 5100's, 275/60/20 Duratracs, Blizzak DMV2's (winter)
  10. #249
    1,030
    363 times
    I think we should all send a email to @Mishimoto and ask them to do something about it? Or hopefully @NMB2 would probably do a better job
    Gearhead Tuned
    Bilstein 5100's
  11. #250
    2,948
    1016 times
    Quote Originally Posted by trev View Post
    Mine does this too with the stock t-stat.
    What might help is if the replacement t-stat is less restrictive and can get coolant out of the radiator faster. The faster the flow through the radiator, the hotter the average temperature, the more heat gets dumped. You let the coolant sit to long and it cools and doesn't give off as many BTU's.
  1. 2013 trans running hot after TSB 13-6-8 fix
    By jct501 in forum F150 Ecoboost Problems
    Last Post: 04-26-2017, 10:19 AM
  2. Transmission temps: How hot is too hot?
    By thestrangebrew in forum F150 Ecoboost Towing
    Last Post: 08-17-2016, 07:27 AM
  3. Hot Pipes
    By kFirm in forum F150 Ecoboost Performance
    Last Post: 02-05-2016, 11:02 AM
  4. Heated seats not hot enough
    By trev in forum F150 Ecoboost Chat
    Last Post: 11-07-2015, 01:07 PM
f 150 eco boost runs hot only while pulling
f150 runs hot when towing camper
news
