3.31 to ???
3.31 to ???
This is a discussion on 3.31 to ??? within the F150 Ecoboost Towing forums, part of the F150 Ecoboost Forum category; Hello! My wife and I just set off on an adventure for the rest of the year to the end of the road in Alaska, ...
Results 1 to 10 of 16
Like Tree6Likes
Thread: 3.31 to ???
    Ecoboost Sr Member avwizz's Avatar
    50
    15491
    26 times
    3.31 to ???
    Hello! My wife and I just set off on an adventure for the rest of the year to the end of the road in Alaska, Prudhoe Bay. Weíre in Georgia now and Iím considering the possibilities of a gear change. Tires are stock size for those wondering.
    I was estimating 9mpg but am getting 8.5-9 and thatís just in the south east.
    Obviously if we were to change the difference in MPG would almost never make up the cost of the change but weíre looking at close to 20k miles with this set up.
    I know some of the responses will be ďsell your truck, itís not worth the changeĒ or dump some of your stuff/change tiresĒ but this is what weíre rolling with.
    So math wise at 70mph (weíre usually a little slower but thatís easy math)
    3.31 @ 2000
    3.73 @ 2250
    4.10 @ 2450
    What would go with? Any experience towing at those gears? Especially the 4.10.
    Ecoboost Regular J-Winship's Avatar
    Nov 2017
    157
    50913
    60 times
    3.73 would be a normal towing gear for that truck. But why the change? You never said that.
    3,898
    1738 times
    I usually lock out 6th gear when I tow (3.31). I like my towing rpms between 2500-3K rpm.
    Nov 2017
    157
    50913
    60 times
    I would stick with the gear set you have and keep locking out 6th. Or go with 4:10 setup. I have a 3:31 setup I do the same with. Also a 3:73 I still lock out 6th. Also have a 3:55 setup with the 10speed and 9and 10 get locked out. 4:10s might be what youíre looking for. But youíll always be that way even empty. If itís not a FULL TIME towing truck just lock out 6th and call it a day. Less stress on the trans anyway being in less of an overdriven pulling a load.
    noodles likes this.
    Oc
    672
    4453
    249 times
    70 mph was around 2k rpms in my 2014 with 275/65-18ís and stock 3.73ís. Your tireís must be much smaller? Is the gear change for mileage or towing power? Donít waste your money if youíre trying to improve mileage.
    50
    15491
    26 times
    Quote Originally Posted by J-Winship View Post
    True it wasnít directly stated. Reasons would be potentially better MPG. Better performance, better for the truck long term over the course of the trip.
    50
    15491
    26 times
    Quote Originally Posted by noodles View Post
    I always lock out 6 but even in 5th itís just at 2k rpm. Been messing with 4th and at 65 itís at 2500.
    Ecoboost Veteran mj0528's Avatar
    442
    57273
    45 times
    What are your rpms in 8th when running 60 or 65?
    Nov 2017
    157
    50913
    60 times
    Quote Originally Posted by mj0528 View Post
    In 8th at 60 Iím about 1900 rpm. 7th puts it about 2250.
    3,242
    1165 times
    Your RPM's don't sound quite right. 32" tire is about stock.
    Here is my calculator on google drive for both the 6 speed and 10 speed trucks. You can punch in a speed, tire OD, and pick which transmission gear you want it to display the RPM's of on the left in the green cells.
    https://drive.google.com/open?id=1Eu...-CXOGL-b2rAy9c
    I don't really think you need more than 3.73's on stock tire size. I live in the mountains in Utah and my truck has 3.73's and does great.
    I also wouldn't expect much of an improvement in MPG. I get 10 at best.
    Mitchf150 likes this.
  1. 3.31 rear???
    By BlueJeansBoosted in forum F150 Ecoboost Chat
    Last Post: 04-06-2014, 11:52 AM
  2. 3:31 gears and 35s
    By 13ecoboost in forum F150 Ecoboost Performance
    Last Post: 03-13-2014, 03:42 AM
  3. 3.31 mistake???
    By eyedreamn in forum F150 Ecoboost Towing
    Last Post: 12-17-2013, 08:01 PM
  4. Guys/Gals w/3.31 gears
    By alvio_ramon in forum F150 Ecoboost Chat
    Last Post: 10-08-2013, 08:15 PM
  5. 3.31 vs 3.55 Gears?
    By BLUEOVALRACER in forum F150 Ecoboost Performance
    Last Post: 07-06-2013, 02:23 AM
