Is my trailer too big? - Page 5
This is a discussion on Is my trailer too big? within the F150 Ecoboost Towing forums, part of the F150 Ecoboost Forum category; Originally Posted by cajunfla Front wheel well is 1/4 inch higher with WDH and trailer than without. Isn't that where it should be, close to ...
Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Like Tree11Likes
Thread: Is my trailer too big?
  1. #41
    3,694
    3061 times
    Quote Originally Posted by cajunfla View Post
    Front wheel well is 1/4 inch higher with WDH and trailer than without. Isn't that where it should be, close to measurement without WDH and trailer?
    I'd say "close enough" for that one single aspect. How much rear squat do you have at that point?
  2. #42
    Ecoboost Regular cajunfla's Avatar
    Feb 2018
    Pensacola
    162
    55570
    71 times
    Did not take note of rear squat. I'll check it tomorrow. Water tank is filled with bleach/water solution overnight to sanitize after removal of winterize stuff from factory. That 1/4 difference is with empty trailer. Need to load for a camping trip and remeasure.
    2018 Guard (WTH kinda name is that for a color) * F-150 XLT S/Crew 2.7 * 3.55 rear * Trailer Tow Package * 18" Hankook's * Pro Backup Assist * Tailgate Step * Running Boards * Fog Lights * stubby antenna * full BedRug * Gator Tonneau * windows tinted dark as legal in Florida *
  3. #43
    3,694
    3061 times
    I like that you've switched over to a methodical approach. I'm confident you can get the weight balanced using those efforts.
    That's the "physics"
    After that, the improvements are a matter of better performing components. Things like stiffer sidewalls and improved damping.
    It only makes common sense that damping that gives a nice smooth ride in an empty truck is NOT ideal for giving a good ride with 1500lbs of weight added to the equation.
    Running empty and then running pretty close to max load is as far as a difference as possible!
    Still, one thing at a time. And that's exactly what you are doing. Cheers!
    cajunfla likes this.
  5. #44
    Ecoboost Jr Member gnewby's Avatar
    Dec 2018
    South Central Kansas
    26
    68932
    That might be about how mine was ( if it was over 15 seconds ago since I done it I have forgotten LOL).
  6. #45
    Ecoboost Regular TomD's Avatar
    Kentuckiana
    171
    15806
    54 times
    I've been towing travel trailers for almost 40 years...here's what works for me:
    Adjust WDH to give 100 percent FALR...front tires inflated to factory recommendations...rear tires inflated slightly over factory recommendations. This is for P-rated XL tires. Inflating the front tires too much will add to the light feel on the steering. I've discovered it's a balancing act to get everything to work together and provide a comfortable towing experience, especially with a soft suspension and passenger rated tires.
    YMMV
    2015 F150 XL sCab Sport 4x2, Race Red, 2.7 Ecoboost, 3.73 E-lock, Tow package, Integrated trailer brake controller, Bizon tri-fold tonneau, OEM drop-in bedliner, otherwise stock
    If more restrictive gun laws were the answer, then Chicago and California would be the safest places to live.
  7. #46
    Ecoboost Jr Member Warthog5's Avatar
    Dec 2014
    Pensacola,Fl.
    29
    7397
    10 times
    On a travel trailer.....There is so much room to put junk in the front of the trailer. Propane bottles and batteries were mentioned also. Does the trailer sit level? If it's down in the front...Then it's loading to forward trailer axle more than the rear......You want it level to distribute the load evenly. My truck squats with the boat on it. 9100lbs total. But I can compensate with the adjustable height of the hitch. This keeps the trailer level.
    2015 F150 XLT S/Cab - 4X4 - 3.5EB - 3:55 Elec lock - Ruby Red - 302A Equip Group - Blind spot system - Nav - Max Tow - Tailgate step -Ext range tank - Bed Extender
  8. #47
    Feb 2018
    Pensacola
    162
    55570
    71 times
Size:  3.20 MB Trailer empty, truck full bag of fuel.
  9. #48
    Puyallup, WA
    930
    4854
    417 times
    Oh hell... Tow that thing all day long and enjoy!.. Just adjust the WD hitch as needed as you will need to dial it in for how you load it up, but in general, it looks good from the pic.
    Mitch
  10. #49
    Ecoboost Sr Member {tpc}'s Avatar
    Aug 2018
    Berkley, MI
    79
    66606
    17 times
    Quote Originally Posted by Mitchf150 View Post
    Mitch
    Agree with mitch. Looks good to me! FWIW, my rear squats a little with the trailer hooked up. I haven't done anything in relation to it though.
    2018 Magnetic F150 XLT SuperCrew 2.7l Ecoboost/302A
  11. #50
    Rookie ronwalt's Avatar
    Feb 2019
    70336
    My 2 cents from someone who felt the same condition you did, same truck. Tire side wall flex. I switched from 04 F150 with Goodyear Wrangler LT's to and brand new 2018 with some sweet riding Michelins. Took me a while of tweaking things then it hit me....that's gotta be it! Side note, 2018 2.7L ecoboost, 10 speed tranny will flat OUT TOW the 5.4L V8!!! Loving the feel of a truck not struggling to get to the top of a long interstate incline!🏁🏁
    snakebitten and cajunfla like this.
  1. Is this too much trailer? Buying a new to us camper
    By Kelvininin in forum F150 Ecoboost Towing
    Last Post: 03-31-2017, 04:05 PM
  2. How big of a travel trailer can you tow?
    By askibum02 in forum F150 Ecoboost Towing
    Last Post: 09-06-2016, 12:16 PM
  3. Too Much Travel Trailer???
    By otc318 in forum F150 Ecoboost Towing
    Last Post: 02-01-2016, 05:48 PM
  4. Pictures too big!!!!
    By silvercreek in forum F150 Ecoboost Chat
    Last Post: 06-10-2015, 08:21 AM
  5. Cupholders Too Big!
    By momalle1 in forum F150 Ecoboost Accessories
    Last Post: 12-31-2013, 10:58 AM
