None of my faucets work on my Trailer - Page 2
This is a discussion on None of my faucets work on my Trailer within the F150 Ecoboost Towing forums, part of the F150 Ecoboost Forum category; Did you fill them with water?...
Results 11 to 16 of 16
Thread: None of my faucets work on my Trailer
    1,165
    425 times
    Ecoboost Sr Member {tpc}'s Avatar
    Aug 2018
    Berkley, MI
    79
    66606
    17 times
    When you say filters, are they the replaceable inline type filters? Like a "whole house" style or something? I would bet thats where the chunks of stuff came from, its probably calcium buildup or something that hardened up while sat over the winter.
    As for winterizing, I'm paranoid. Not so much that I'll pay the dealer $150 to do it (though I have in a pinch to save time), but enough that I blow the lines out with the air-compressor AND I run antifreeze through the system. Air is free, antifreeze is cheap, process is easy, just have to have the time to do it is all.
    2018 Magnetic F150 XLT SuperCrew 2.7l Ecoboost/302A
    3,089
    1092 times
    Quote Originally Posted by {tpc} View Post
    No, these were these little plastic discs inside the faucet sitting just above the screen/aerator. Honestly, they may not be filters, it may be a flow regulator like they put on shower heads now. Either way they had a VERY thin gap for the water to pass through and it plugged up.
    I left them removed so i will try to grab a picture.
    Ecoboost Regular Kinguni's Avatar
    Lorette, MB
    103
    15424
    26 times
    Flow regulator. Standard part of every aerator. Cleaning your aerators at least once a yer is a good idea.
    2018 3.5 XLT 302a XTS SCREW LB Max Tow Magnetic No Mods
    Ecoboost Regular SuperDave23's Avatar
    Jul 2017
    Fresno, CA
    179
    40369
    32 times
    Might be crap from your water heater. I bought my trailer used (~10 yrs old) and when I pulled the anode rod to inspect what was left of it (the rod was down to 14-gauge wire thickness!) there was a ton of white calcium pieces in the bottom. I shop-vac'd a bunch out. Don't think the anode was ever changed or the heater was ever cleaned out.
    Dave
    2013 F150 4x4 EB
    2005 F250 4x4 6.0 Sold
    2002 F150 4x4 5.4 Sold
    3,740
    3091 times
    I'm still convinced (which doesn't mean much) that it was "new construction debris" that found its way into the plumbing system.
    I only think that from buying a couple of RV's new and discovering stuff in wierd places that were trapped and left there in the HASTE of the typical assembly line.
    Watch a few legitimate (not marketing) YouTube videos of RV manufacturing. It's actually hilarious.
  1. Replies: 64
    Last Post: 01-29-2018, 06:30 PM
  2. Left brake/turn light does not work on trailer
    By GDSQDCR in forum F150 Ecoboost Towing
    Last Post: 03-24-2017, 07:45 AM
  3. Just towed my work trailer
    Last Post: 03-24-2015, 06:44 AM
  4. Trailer brakes and aux lights don't work
    By Sherman in forum Off-Topic
    Last Post: 05-27-2014, 04:07 AM
  5. Trailer power tongue jack doesn't work
    By REVF150 in forum F150 Ecoboost Chat
    Last Post: 05-19-2014, 06:45 PM
