None of my faucets work on my Trailer
This is a discussion on None of my faucets work on my Trailer within the F150 Ecoboost Towing forums, part of the F150 Ecoboost Forum category; I took my trailer to moab maybe a month ago and everything was fine. When i got home i put anti freeze in it simce ...
Results 1 to 10 of 16
Thread: None of my faucets work on my Trailer
    3,048
    1078 times
    I took my trailer to moab maybe a month ago and everything was fine. When i got home i put anti freeze in it simce it was still getting cold at night.
    Anyways, i go to flush the system today and get no water from any faucet. I hooked up the city water and same issue. The thing is, when i open the drains under the fridge water shoots out continuously. Same with the hot water tank drain. The toilet also appears to flush like normal. So something is causing all the faucets to be clogged.
    3,696
    3061 times
    Is the valve at the water pump set ˝way between normal and bypass? I never touch mine since climate doesn't require winterizing. But I think the valve is used for folks that winterize. (It might be for bypassing the hot water heater?)
    3,048
    1078 times
    Update. Turns out the filters on the faucets were clogged. Pulled the filters and ran only the aerator and this is what got caught
    curtcharlespdx likes this.
    3,048
    1078 times
    I only have a valve between the pump and water tank. I closed this when i switched to city hookup to prevent it from draining into the tank. I also think my one valve in the pump is bad but that is another story and was also gunna put in a replacement today.
    3,696
    3061 times
    So this typical video does not represent your RV's plumbing diagram?
    (I realize that there are variations across RV's, but I thought most had these opinions)
    3,048
    1078 times
    Oh sorry. You were asking about the pickup hose just in fromt of the pump. No that was shut.
    The faucets were clogged with that crap in my picture above. They work now but now concerned about what the hell that is. Could it be from the hot water heater?
    I dont use the water tank for drinking anyways. Only for cooking and cleaning. Just hope the water heater didnt poop the bed over the winter.
    3,696
    3061 times
    Have you watched any RV assembly videos?
    Don't! It's scary. Lol
    They can build your RV in about 7 minutes.
    OK, a bit of exaggeration. But let's just say it is NOT carpenters, electricians, and plumbers. Instead, it's some folks that are paid by the piece! It's super fast and if sawdust or plastic pipe cuttings, or any other unintended scraps found entry into one piece of tubing or pipe used in your RV, nothing would prevent it. Or correct it.
    Clean those screens and flush all your systems out and you are good to go. Fortunately it's a rather small and closed system. There's only so much that could hide.
    Oc
    656
    4453
    239 times
    Easiest way to winterize is with compressed air. Just blow out the lines.
    3,048
    1078 times
    Quote Originally Posted by Mulyhuntr View Post
    This is what i did last fall and thats how the one way valve on the pump crapped the bed. Apparently it didnt all get cleared out and the valve frozen.
    Kinguni likes this.
    Ecoboost Regular Kinguni's Avatar
    Lorette, MB
    103
    15424
    26 times
    I like my RV antifreeze. Dewinterized today (finally a forecast without serious freezing in it) and everything is good. Sanitizing the system currently in prep for next weekend. Even the mystery leak by the city water hook up is dry. Thought I broke something on our last camping excursion last year when the temperature dipped several degrees below freezing.
    2018 3.5 XLT 302a XTS SCREW LB Max Tow Magnetic No Mods
  1. Replies: 64
    Last Post: 01-29-2018, 06:30 PM
  2. Left brake/turn light does not work on trailer
    By GDSQDCR in forum F150 Ecoboost Towing
    Last Post: 03-24-2017, 07:45 AM
  3. Just towed my work trailer
    Last Post: 03-24-2015, 06:44 AM
  4. Trailer brakes and aux lights don't work
    By Sherman in forum Off-Topic
    Last Post: 05-27-2014, 04:07 AM
  5. Trailer power tongue jack doesn't work
    By REVF150 in forum F150 Ecoboost Chat
    Last Post: 05-19-2014, 06:45 PM
