Ford 3.5l ts performance ecoboost ecopro
This is a discussion on Ford 3.5l ts performance ecoboost ecopro within the F150 Ecoboost Towing forums, part of the F150 Ecoboost Forum category; I've been researching this. Does anyone have experience towing with a TS Performance Ecoboost Ecopro for a 2011-2014 3.5L Ecoboost. If so, what say you ...
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By Boostking
  • 1 Post By milesej05
Thread: Ford 3.5l ts performance ecoboost ecopro
    Ecoboost Regular theasphaltrv'er's Avatar
    4 Corners ..The land God 4got
    127
    2643
    37 times
    I've been researching this. Does anyone have experience towing with a TS Performance Ecoboost Ecopro for a 2011-2014 3.5L Ecoboost. If so, what say you bout the good &/or the bad.
    It's suppose to
    . increase HP 50+
    . improve fuel economy
    . more responsive throttle
    if true
    Would appreciate any feedback.
    Milo
    13 Kodiak Brown, XLT, HD, 4X4, Ecoboost, 3.73
    15K PullRite SuperGlider
    14 Cougar 26SAB 5er
    Ecoboost Pro Boostking's Avatar
    Jun 2015
    Florida
    783
    12619
    865 times
    That device just alters data coming back to the PCM so that the PCM thinks it's not doing what it should be doing, and therefor gives more boost/timing etc.
    Not exactly a safe way to extract more power, however I do doubt it would hurt anything. A real tune is a better way to go in my opinion.
    2013 Tuxedo Black SCrew Ecoboost FX4 w Appearance Package 5.5 box, 3.73. Mods: SCT LWTS+ custom tuned, Full-Race/BorgWarner OEM+ "GT Turbos", Tifosi Exhaust Manifolds, RTR HPFP, CP-E FMIC w/ TurboSmart SuperSonic, CP-E 3" Catted Downpipes, AFE Magnum Force Pro Dry-S Intake, Borla Touring Cat-Back, Terra G2s 305/55/20 on Method N/V 20x9, Leveled Bilstein 5100 RHA 1.5", 20" LED light bar, Hellwig Rear Sway Bar, Morimoto LED Fogs, Extang Revolution Tonneau Cover, Custom LED bed lighting, DeeZee Tailgate Assist, Tailgate Remote Power Lock Mod, MaxLiner Floor Mats, Ford OEM Underseat Cargo Box, LED Interior and Reverse Lights (Diode Dynamics), Recon LED 3rd Brake Light, NL Door Detents, .50 cal antenna, Custom Coding (ForScan)
    7,556
    3289 times
    In simple terms, it is a boost fooler.
    You are better off getting an actual programmer and custom tunes. You have a $50K+ dollar truck, if you want to modify it...spend the extra money.
    127
    2643
    37 times
    Thanks for your feed back. This and other sites tell the same tale. Evidently nobody has actually installed one so that tells me allot. Miles sorry to say it's not a $50K+ dollar truck. But thanks for the compliment. Twas $38K back in the fall of 2012 when we bought it.
    14 Cougar 26SAB 5er
    7,556
    3289 times
    Quote Originally Posted by theasphaltrv'er View Post
    There is such a variance in trucks now-a-days...I just didn't want you to get offended if you paid $55K and thought I was low-balling you. lol.
    I would stay away from this as well as the aFe Scorcher...and SSi. That is my opinion though.
    Elmore328 likes this.
    3,046
    1077 times
    What i dont get is if its altering boost, how is it not totally f’ing up the AFR? Or does the fuel trim compensate?
    Jun 2015
    Florida
    783
    12619
    865 times
    Closed Loop system because it has widebands, which means it will correct to its target almost instantly.
    3,046
    1077 times
    Quote Originally Posted by Boostking View Post
    50 hp is a lot of correction though. Seems a little scary.
