Colour match grill - Page 2
Colour match grill
This is a discussion on Colour match grill within the F150 Ecoboost Appearance forums, part of the F150 Ecoboost Garage category; Primer is not good enough over chrome. It needs to be thoroughly sanded (or stripped) then sprayed with an adhesion promoter then primed, then many ...
Results 11 to 20 of 26
Like Tree10Likes
Thread: Colour match grill
    Super Moderator Purefection's Avatar
    Manitoooba
    768
    65694
    329 times
    Primer is not good enough over chrome. It needs to be thoroughly sanded (or stripped) then sprayed with an adhesion promoter then primed, then many coats of good paint, then clear coated. I would not attempt doing this with rattle cans (have in the past). I have successfully used spray on Bedliner to paint a chrome bumper and grille though (after proper prep). If you don't mind redoing the paint in a year then giver with the color match cans.
    On my gmc canyon I was able to strip the chrome off the plastic grille by using easy off (oven cleaner). It was very messy and stinky but did work.
    Eco-Beast madmaxmutt's Avatar
    Colorado Springs
    3,479
    3707
    1609 times
    The old FX4 grille.
    Name:  Upper Gold Camp Road.jpg
    I always liked the look of the two tone.
    GearHead_1 likes this.
    2017 Ford F350 Lariat FX4 SRW 4x4
    2017 Ford Explorer Sport 3.5 Ecoboost.
    Traded my boost: 2013 Ford F150 Ecoboost FX4 SuperCrew.
    Should've got a V8 - Check
    Should've got a Diesel - Check
    Should've got a 1 Ton - Check
    You'll run out of payload - Not Likely
    Ecoboost Pro AllWhiteEco's Avatar
    Dyersburg, TN
    917
    5973
    384 times
    Thinking of colour matching my bumpers and grill
    Does anyone else feel a sense of deja vu?
    https://r.tapatalk.com/shareLink?sha...8&share_type=t
    2014 Platinum
    3.31 E-Locker
    2.5" Rough Country Level
    22" Lariat Limited Wheels
    285/55R22 Nitto Trail Grappler M/T
    Boost Bars Lower Grille
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Livewire TS w/ Custom tunes
    3" Catless Mak Y-Pipe
    Full 3" Catback Exhaust with Magnaflow #12579
    10" RF P2 w/ ported box
    Full LED Conversion w/ Switchbacks
    Rigid SAE Fog Lights
    Manitoooba
    768
    65694
    329 times
    Yeah I saw that and was gonna mention blah blah moderators merge threads but that horse has been beaten to death
    Dyersburg, TN
    917
    5973
    384 times
    Quote Originally Posted by Purefection View Post
    I don’t blame you for not wanting to waste your breath. It’s just annoying to see him ask the same questions and post the same responses to our replies which basically said the same thing: sand the grill and use an adhesion promoter before the primer if you want it to hold up decently to rock chips.
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Dyersburg, TN
    917
    5973
    384 times
    Here’s some more advice OP: use Meguiar’s 105 and 205 compound to give the clear coat a factory looking shine after you paint the grill and let it cure. The last thing you want is your new painted bumpers and grill looking dull next to that factory paint.
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Ecoboost Jr Member Twenty13ecoboost's Avatar
    Jan 2019
    48
    69550
    Quote Originally Posted by AllWhiteEco View Post
    Quote Originally Posted by Twenty13ecoboost View Post
    I already bought the Ford colour match grey paint and clear coat.. what colour primer should I get to help match better.. my truck is grey.... should I sand down the grill or can I get away with just the primer?
    If you want it to last, I would sand the grill
    down until it’s dull and then throw on a couple of coats adhesion promoter before the primer. Not doing these steps is asking for chips in the paint.
    I’ve never heard of anyone using adhesion promoter... is that like a primer for the primer? I really don’t want it to chip and flake off. Is there another type that I can put on before the adhesion promoter for better longevity? Lol
    Manitoooba
    768
    65694
    329 times
    Let's pick one thread and stick to it. No point in putting info across 2 threads.
    milesej05 likes this.
    Dyersburg, TN
    917
    5973
    384 times
    x2
    2014 Platinum
    3.31 E-Locker
    VTA mod
    AEM Drop-In Filter
    RX Monster w/ CSS
    Eco-Beast Shrek's Avatar
    Houston, TX
    3,186
    5986
    1128 times
    Bulldog is a name brand adhesion promoter, works great on plastics.
    A few hour turn around is not a reasonable expectation for a proper paint job on anything automotive. It will certainly show in the end result if you try to rush it.
    Make sure the primer/paint/clear are all the same brand so they adhere to each other. Follow the instructions on the can or contact the manf directly.
    A cold garage is a terrible place to paint. Heat it up, remove the heaters, paint, after it's settled, bring the heaters back in. Better option, wait for decent weather!
    Elmore328 likes this.
    2014 SCREW Green Gem XLT Plus
    3.55 E-lock - OE HID -
    Heated Adobe Leather - OffRoad Package - AutoSpring 2.5/1 Kit
    DiabloSport 91 Oct Tune - Stubby - Morimoto LED Fogs - LED Backup Lights - ATP CAC
    Enkei M5 20x8.5 30mm - Michelin Defender LTX MS2 275/65R20
  1. Lock wire colour in drivers side?
    By Zeus2003 in forum F150 Tremor
    Last Post: 10-14-2015, 06:31 PM
  2. Most Popular Boost Bars to Match Platinum Grill
    By ckjaecks in forum F150 Ecoboost Accessories
    Last Post: 10-13-2014, 02:19 PM
  3. boost gauge to match interior
    By coley909 in forum F150 Ecoboost Chat
    Last Post: 05-02-2014, 09:08 AM
  4. Paint to match line-x
    By ThatOneDude in forum F150 Ecoboost Accessories
    Last Post: 11-17-2013, 01:28 PM
  5. Spray in Liner colour matching?
    By Eco-Beast_1308 in forum F150 Ecoboost Builds
    Last Post: 09-19-2013, 02:13 PM
