Looking for Idea to replace my FX2 black 20inch rims..
This is a discussion on Looking for Idea to replace my FX2 black 20inch rims.. within the F150 Ecoboost Wheels and Tires forums, part of the F150 Ecoboost Garage category; I am building a Truck,while part of the reason I got the appearance package was the rims,We are installing chevy control arms,spindles,and hubs on the ...
  • 1 Post By agentjohnson
Thread: Looking for Idea to replace my FX2 black 20inch rims..
    Eco-Beast aboostedf150's Avatar
    houston
    1,583
    5971
    367 times
    I am building a Truck,while part of the reason I got the appearance package was the rims,We are installing chevy control arms,spindles,and hubs on the front,and in order to keep the stock rims they would have to drill out the front hubs,which I am not a huge fan of doing that...I do not like the idea of having 6 extra holes next to the studs on my hubs...
    The rear end is being shorten,so the rear hubs could stay ford...Or i can get Chevy axles hubs in the rear as well,and just get all new rims...
    So I would like some Ideas to replace my stock 20 inch rims...
    Its either I drill the frt hubs and so be it, or new rims,and rear axles..Has anyone ever drilled the hubs before,I worry about heat,and getting cracks or maybe its not perfect,and doesn't seat correctly causing issues down the road...
    Here is a picture of my truck if it helps with any ideas...thks..
    Eco-Beast agentjohnson's Avatar
    East Texas
    3,883
    4749
    1508 times
    Why are you putting chubby parts on your truck?
    mikemetz82 likes this.
    peon
    houston
    1,583
    5971
    367 times
    I do not mine explaining ...Its the hubs,and spindles ,the rest of the suspension is Custom Built aftermarket..Its the same way every major builder does it when they remove the struts to lower and bag a ford truck,or even a dodge some times depending on the factory set up....When I say Chevy its really just the design LASA...and the bolt pattern...When you go from a strut to a air bag you have to have a place to mount it,and using upper,and lower control arms is the only way. Since ford does not have a hub and spindle that will mount in place of the 09-14 ford spindle hubs the the only choice is to use a Chevy hub that is compatible with the ABS,traction control,and other systems...
    I am still doing some research to make sure everything they are wanting to use is the best way to do what i am wanting to do,so i can use the truck in the way i want to.. I hope my simple explanation helps...Thks for the question...
    Rookie smasherella's Avatar
    11
    5976
    I can take then off your hands and give you my gray ones! Lol
    Ecoboost Sr Member ja60524's Avatar
    Sep 2013
    92
    2380
    22 times
    If you were Local here in MD I would be really interested in grabbing the stock rims off of you.
    Bump for an interesting and cool idea.
  1. Looking for Idea to replace my FX2 black 20inch rims..
    By aboostedf150 in forum F150 Ecoboost Wheels and Tires
    Last Post: 09-05-2014, 11:10 AM
  2. Black Plasti Dip stock Fx4 18" Alloy Rims
    By Yake Bait in forum F150 Ecoboost Appearance
    Last Post: 04-25-2014, 03:24 PM
  3. Replies: 6
    Last Post: 03-06-2014, 04:38 PM
  4. WTT: Smoke 20" FX4 Rims from my 2013 for Black 20" Appearance Pkg
    By Riotrob in forum F150 Ecoboost Problems
    Last Post: 08-19-2013, 08:59 AM
ecoboost black rims
