Bilstein installed price.
This is a discussion on Bilstein installed price. within the F150 Ecoboost Suspension forums, part of the F150 Ecoboost Garage category; I知 putting bilstein 4600 all around on my 2016 screw 4x4. The backs look easy. After reading multiple threads on the fronts, I think I値l ...
Results 1 to 10 of 14
Like Tree12Likes
Thread: Bilstein installed price.
    Ecoboost Jr Member Rds912's Avatar
    36
    64474
    I知 putting bilstein 4600 all around on my 2016 screw 4x4. The backs look easy. After reading multiple threads on the fronts, I think I値l skip that one. Anyone know about what a decent price for having a front pair installed would be.
    Thanks
    Ecoboost Regular Dworth's Avatar
    Ohio
    142
    14856
    63 times
    I am guessing around $500 as it takes approximately four hours.
    2013 Ford F-150 Lariat Ecoboost. Max Tow Package w/ 6.5 foot bed.
    Ecoboost Regular Kinguni's Avatar
    Lorette, MB
    103
    15424
    26 times
    I paid $170.00 up here in Canada at a Ford dealer for the fronts a couple of years ago. Plus an alignment. Doesn't take long with the right equipment. And yes, rears are easy. Just pay attention to torque specs when you tighten things up.
    Ecoboost Sr Member goJim's Avatar
    Jan 2019
    Texas
    68
    69800
    15 times
    Quote Originally Posted by Rds912 View Post
    Thanks
    Courious as to why replacing the front is hard??
    Just noticed your is a 4x4. My 2018 is rear wheel drive only
    Traded 2013 Ford F150 3.5L Ecoboost for New 2018 Ford F150 2.7L Ecoboost well outfitted!
    824
    259 times
    You have to open up the front suspension to remove the strut assembly, then compress the spring to remove. The springs on these trucks are super heavy duty and a lightweight spring compressor from auto zone won't work very well, safely. Most people end up using 2 sets on one spring, or take them to a shop to do.
    I bought my fronts online, then paid a shop $200 USD to install. Total cost was about $350-$400 if I remember correctly.
    snakebitten, goJim and Mikedick77 like this.
    Ecoboost Sr Member {tpc}'s Avatar
    Aug 2018
    Berkley, MI
    79
    66606
    17 times
    Yuck. Compressing the springs suck. I'd gladly pay a shop a couple hundy to put those on imo. Don't want to be on the wrong end of that one...
    Mr B, snakebitten, Kinguni and 2 others like this.
    2018 Magnetic F150 XLT SuperCrew 2.7l Ecoboost/302A
    Lorette, MB
    103
    15424
    26 times
    Quote Originally Posted by {tpc} View Post
    I'm with you there. I researched doing it myself and said nope!
    Olathe Ks
    758
    14790
    214 times
    I got my fronts done at a local Goodyear store. They had the truck about half a day. I paid $400 and that included alignment. The rears I did myself in about 30 minutes.
    ~Jim~
    2012 Lariat Screw; 3.5L; 4x4; 3.55 E-Locker; Lux/Tow Package;
    Exhaust; 3" Resonator Delete;Turbosmart BOVs; Bilstein 5100s; Leveled; 20% Window Tint; Full Interior LEDs; PIAA Heads/Fogs; Forscan; BFG 275/70/18 KO2s
    3,060
    1085 times
    I had a shop do the assembly of the shocks/springs for me for like $25 but installed the shocks myself. Its not too bad.
    I found unbolting the lower control arms at the frame and lowering them with a floor jack was the easiest way. Then once the top of the shock is bolted in, you just lift the control arm back into place with the jack and align the lower shock bolts. If you get the LCA bolts lined up in the same spot they were before, you shouldnt need an alignment. I brought mine in and they told me it was totally fine.
    Ecoboost Veteran Tdog02's Avatar
    Central Texas (think hill country)
    288
    22273
    117 times
    Compressing springs is not a typical job for a DIY shade tree guy. If you are careful and have the time it takes you can do it and do just as good a job as a pro shop. It will take you longer and there is risk involved.
    If you have ever seen a spring slip out when being compressed then you know how dangerous it can be. Your choice, and you will save a good deal of money. That痴 usually why I am a DIY mechanic, landscaper, plumber, electrician, carpenter, painter, barber, chef, pit master, bottle washer, brewmaster and over all general handyman.
    That said, when I put my Bilsteins on the front I知 gonna pay someone else. The rears are stupid easy and anyone can do those with damn near no experience or risk.
    2016 SCrew 2wd XLT 302A Tow pkg 3.31 EL rear Blue Jeans
  1. Replies: 0
    Last Post: 06-19-2017, 04:58 PM
  2. Replies: 9
    Last Post: 03-29-2015, 04:51 PM
  3. Who has Bilstein 5100 leveling shocks IN STOCK?
    By Bigbirt in forum F150 Ecoboost Suspension
    Last Post: 05-03-2014, 03:36 PM
  4. 4wd bilstein 1500s different from 2wd?
    By SS2013MaxTow in forum F150 Ecoboost Suspension
    Last Post: 02-17-2014, 03:57 PM
