problem with bilstein 5100 front shocks installation
This is a discussion on problem with bilstein 5100 front shocks installation within the F150 Ecoboost Suspension forums, part of the F150 Ecoboost Garage category; Hey guys, so today I got around to installing my Bilstein 5100 height adjustable front struts. I decided to go with the max lift of ...
Results 1 to 10 of 19
    Ecoboost Jr Member scar69's Avatar
    Mar 2015
    Alberta
    21
    9664
    Hey guys, so today I got around to installing my Bilstein 5100 height adjustable front struts. I decided to go with the max lift of 2.1" and set the seat collar to the highest setting 5th ring. I followed the bilstein instructions and also the video below by Stage 3 motorsports. Once I had everything installed and torqued up I put the stock wheels back on and set the truck on the floor to see how it would sit. For some reason the truck was sitting a little over 3" higher than stock. I thought maybe I put something in upside down or put a spacer in that wasn't supposed to be used so I pulled both strut assemblies and took them apart. I did have everything installed properly according to the Bilstein instructions so I then decided to lower the seat collar down to the second lowest point. I put everything back together, installed them on the truck, put the wheels back on and set the truck on the ground. Instead of lowering the truck I actually gained another 3/4" of ride height so now the front of the truck is sitting almost 4" higher than stock. WTF is going on? I am completely at a loss and for the life of me can't figure out what is causing this. Any ideas? TIA
    5100 (Ride Height Adjustable) - Shock Absorber
    2019 F150 XLT Sport Supercab 4x4
    2.7L Eco, 302A, 3.55's
    CaliOffroad Americana 20x9, 0 offset
    Dick Cepek Fun Country 285/55/R20
    Ecoboost Regular billjc's Avatar
    134
    6659
    48 times
    Did you roll the truck to settle the suspension?
    Sent from my SM-N960U using Tapatalk
    Mar 2015
    Alberta
    21
    9664
    Here is a pic of the passenger side.
    Mar 2015
    Alberta
    21
    9664
    Quote Originally Posted by billjc View Post
    No I didn't. After removing the jacks and seeing the crazy amount of lift I figured I screwed something up. Should I take it for a short drive and see if it drops down a bit?
    134
    6659
    48 times
    Just roll it a few feet. It will settle with very little movement. Then measure.
    Mar 2015
    Alberta
    21
    9664
    Ok thanks, I'll give that a try this morning when I get to the shop.
    Mar 2015
    Alberta
    21
    9664
    When I got to the shop this morning I rolled the truck back and forth a bit as you suggested and it did come down a bit and the now truck is sitting right at 2" over stock. I have the circlip set in the second lowest groove which is supposed to give an average lift of 0.79". I'm not sure why I'm getting a bit more than double of what Bilstein shows in the instructions. Maybe it will drop a bit more over time? Anyhow, I have it booked in to my dealership for a wheel alignment on Tuesday but it is driving straight and I had no issues with a short test drive. Now I need to get my fender flares installed and put my rims and tires on. Thanks for the help billjc!
    Ecoboost Regular Fstrnyou's Avatar
    SC, near Charlotte NC
    125
    70710
    51 times
    Since each adjustment raised the truck, I would have kept moving it around until it got up to 10" lift.
    134
    6659
    48 times
    I can't tell from your pics, but did you happen to have a leveling kit installed prior to installing the bilsteins? The spring doesn't seem to be sitting as high in the pocket as mine do.
    Eco-Beast ptown's Avatar
    1,626
    693 times
    My thoughts but hard to determine from the pictures
