2017 Ecoboost F150 Catch Can Systems: Now Shipping
This is a discussion on 2017 Ecoboost F150 Catch Can Systems: Now Shipping within the MAK Performance forums, part of the Vendors category; We now have a catch can system available for the ALL NEW 2017 3.5L Ecoboost F150 from the guys over at UPR. This new generation ...
Results 1 to 1 of 1
    Supporting Vendor Adrian@MAK's Avatar
    Nov 2012
    550
    21
    268 times
    We now have a catch can system available for the ALL NEW 2017 3.5L Ecoboost F150 from the guys over at UPR. This new generation of Ecoboost Motor required that a few different things be changed on the kits. These will also work on the NEW 2017 Raptor as well.
    They are now ready to ship!
    The Ultimate Oil Separator for your 2017 to present Ford F150 or Raptor 3.5 Ecoboost Truck. The UPR Plug N Play™ Dual Valve Catch Can with UPR Pro-Series Check Valves one way electronic pressure sensor system. You can be sure that no other manufacturer can give you the level of quality and performance that UPR Plug N Play™ Dual Valve Catch Can with UPR Pro-Series Check Valves consistently deliver. Offering the largest capacity in a compact design to be sure that it will eliminate oil vapors on vehicles that are normally aspirated or power added equipped.
    This system is designed to require less maintenance between oil changes and eliminate the amount of moisture that's collected from controlling condensation better by being mounted in the engine bay. Our Patented Multi-Stage Multi-Chamber internal design is the best for controlling oil vapor and mist even in the hottest mounting locations.
    In turn, our new design was developed to work the best in the engine bay without any second guessing of its true performance capabilities. Does require drilling of your factory inlet for the WOT connection.
    Most importantly this system keeps your PCV system performing with the level of protection and performance it deserves by not filling the intake and CAC / Inter-cooler full of oil like the factory designed system does.
    Manufactured from Domestic T-6 6061 Aluminum bar stock and finished off using only the best Diamond cutters to exceed your expectations of what a superior product should fit and look like.
    UPR is the largest aftermarket catch can manufacturer in the country. Continually improving our designs to stay ahead of the competition and give you the cutting edge technology of tomorrow today. We are so confident we offer an unconditional warranty on our products to let you know you can always count on UPRproducts.
    Link to Purchase:
    2017 F150 3.5L Ecoboost Plug N Play Dual Valve Catch Can System
  1. Replies: 25
    Last Post: 12-30-2016, 08:00 PM
  2. Why The Long Shipping Delay On 2017's
    By AZ99 in forum F150 Ecoboost Chat
    Last Post: 12-27-2016, 10:02 AM
  3. When will the 2017 F150s begin shipping out of Dearborn?
    By Mobilman44 in forum F150 Ecoboost Chat
    Last Post: 12-08-2016, 09:40 AM
  4. Replies: 15
    Last Post: 04-20-2015, 10:18 PM
  5. MBRP Ecoboost F150 Exhaust Systems - 50.00 Rebate
    By Stage3Motorsports in forum Stage 3 Motorsports
    Last Post: 07-16-2013, 05:28 PM
