FullRace intercooler
This is a discussion on FullRace intercooler within the Introductions forums, part of the Ford F150 Ecoboost category; I have a 2011 f150 fx4 with 96’000 miles, I had my coils and plugs replaced and I’m still having an issue. Since I have ...
Results 1 to 8 of 8
Like Tree4Likes
  • 2 Post By Envious
  • 1 Post By snakebitten
  • 1 Post By Envious
Thread: FullRace intercooler
    Rookie Thrashbo58's Avatar
    May 2019
    71466
    I have a 2011 f150 fx4 with 96’000 miles, I had my coils and plugs replaced and I’m still having an issue. Since I have an aftermarket intercooler I can’t drain it correct? Guys I apologize in advanced. I don’t know a whole lot about truck. Thanks
    Eco-Beast ptown's Avatar
    1,527
    659 times
    You didn’t tell us the issue. Assuming you’re talking about the condensation shutter, you can remove it in about five minutes by removing the hood latch bolts and the two 3” clamps on bottom of each hot/cold side of the IC. You would then be able to see if there’s any abnormal residual build up. Take pictures of the inside if you do
    May 2019
    71466
    Ya shuddering issue. I checked the aftermarket intercooler and it’s not dirty. When the plugs and coils were replaced it seemed like everything was fixed. My turbo doesn’t whistle like it used too. I don’t rag the truck at all.
    Ecoboost Sr Member Fstrnyou's Avatar
    SC, near Charlotte NC
    81
    70710
    22 times
    I could be wrong here, but the design of the Fullrace intercooler shouldn't be susceptible to condensation build-up. It is mounted high with the end tank pipe connections pointing down.
    I'm still on the stock intercooler and I make sure I give it the beans every few days to flush out any accumulation.
    1,150
    416 times
    Quote Originally Posted by Thrashbo58 View Post
    I feel like this is an issue IMO. A lot of the guys that don't get on it I feel like have more issue. It may just not be heating it up enough for carbon burn off
    snakebitten and Blown F-150 like this.
    3,690
    3057 times
    This is dangerously close to becoming my Ecoboost mantra.
    Which currently, in summary, is FRESH clean oil, full operational temps (both oil and coolant), and pour coal to this thing often.
    1,150
    416 times
    I feel like they are similar to diesels. They like to be under load and like their fresh fluids and their maintenance. Not necessarily abuse them but definitely don't baby them. There is some speculation as well, that soot and fuel in the oil causes the timing chain wear
    3,690
    3057 times
    You said it even better.
    I love the diesel parallel. It's perfect.
    Not that I want a 12-16 quart sump when it comes to oil changes, I can't help but wonder if it would benefit this motor for some of the exact same ways it does the diesel?
  1. Help w/Fullrace intercooler kit and Turbosmart install ???
    By Brignac in forum F150 Ecoboost Performance
    Last Post: 03-14-2019, 09:19 PM
  2. Corsa DB or fullrace?
    By bair1218 in forum F150 Ecoboost Performance
    Last Post: 08-07-2016, 10:11 AM
  3. Fullrace exhaust
    By gotboost150 in forum F150 Ecoboost Performance
    Last Post: 03-13-2014, 11:22 AM
