High Water and the EcoBoost Turbo
This is a discussion on High Water and the EcoBoost Turbo within the Introductions forums, part of the Ford F150 Ecoboost category; Hey everyone! Has anyone had any adverse effects to their EcoBoost turbo from driving through high water? So far I have forded 4 streams with ...
Results 1 to 3 of 3
  • 1 Post By Mike Tritle
Thread: High Water and the EcoBoost Turbo
    Ecoboost Jr Member ForestMyth's Avatar
    Dec 2012
    Ft. Bragg, NC.
    35
    77
    Question High Water and the EcoBoost Turbo
    Hey everyone!
    Has anyone had any adverse effects to their EcoBoost turbo from driving through high water? So far I have forded 4 streams with my F150EB, each stream was deep enough to completely submerge my turbo cooler for at the least 35 seconds. I havent seen any adverse effects as of yet but like i said my turbo cooler wasnt under water for very long. Does anyone have any knowledge in this area that can tell me what might occur in longterm submersion?
    Thanks...
    ForestMyth
    Ecoboost Veteran Mike Tritle's Avatar
    Nov 2012
    DeKalb, IL
    413
    51
    185 times
    Shouldn't be a problem as the pressure inside would/could be higher than outside as long as the engine is under load. Its a sealed system so unless the air inlet goes sub surface there should be no water infusion.
    However, I would actively flush the cooler fins asap upon getting home to remove sediment and other foreign objects that could block or cause corrosion to the aftercooler.
    I would also install one of those inlet screens shown elsewhere a couple days ago on another thread. I'm planning to make one this weekend. Photos will phollow!
    ForestMyth likes this.
    Dec 2012
    Ft. Bragg, NC.
    35
    77
    Thanks for the answer Mike, I really appreciate it. i will look through the treads to try and find that inlet screen your talking about. I did have to wash out the sediment like you mentioned it was completely coverd in mud each time. I had to use a water bottle with a whole in the lid at the time then i used a pressure sprayer when i got back to town. Look forward to seeing your pics.
eco boost through deep water
ecoboost f150 can turbos go thru water
ecoboost turbo water
f150 ecoboost and water
f150 ecoboost in deep water
f150 ecoboost turbo
f150 ecoboost turbo cooling
high water ecoboost
