READYLIFT SUSPENSION LIFT SYSTEMS at RDP Store
This is a discussion on READYLIFT SUSPENSION LIFT SYSTEMS at RDP Store within the RDP Store forums, part of the Vendors category; ReadyLIFT 7-inch Complete Lift Kit System is made to fit the 2015-2019 Ford F-150 4WD trucks, and gives you maximum lift. ReadyLIFT offers the best ...
Results 1 to 2 of 2
    Sponsor RDPStore's Avatar
    May 2016
    Painesville Ohio
    1,121
    15899
    25 times
    ReadyLIFT offers the best comprehensive lift kit designed specifically for 2015-2019 Ford F-150 4WD trucks. The complete big lift kit systems feature the absolute best design and components available. If you want max lift for your Ford F-150 that maintains the factory ride and steering geometry. The premium complete 7.0-inch front / 4.0-inch rear 2015-2019 Ford F-150 4WD kit is specifically designed to give you maximum lift and rugged off-road strength while maintaining the factory ride on the street.
    The 7-inch lift kit features precision-designed laser-cut and CNC-formed subframe assemblies that directly bolt in. Includes heavy duty cast nodular iron steering knuckles, patent-pending rack-and-pinion steering drop correction system (U.S. Pat. App. No. 14531073), and an integrated differential drop bracket system to ensure correct CV axle angles and maximum performance in 4WD mode.
    Patent Pending fabricated industry-first offset steel strut extensions (U.S. Pat. App. No. 14532783) provide the maximum 7-inches of front lift while 5-inch tall OEM-style rear blocks (total rear lift equals 4.0-inches of lift when installed) provide a quality rear lift that doesn't sacrifice the ride. This kit even includes a Patent Pending steering extension to keep your steering performance like factory. This is a no-weld design - direct bolt-on installation.
    This system also includes a patent-pending RCS - Rack Correction System - steering extension design that works with the relocated steering rack to retain the stock steering geometry. That means no cutting or replacing the tie rod ends like on some other kits on the market. Why is not cutting the tie rods important? If the owner or mechanic replacing a tie rod down the road doesn't know a tie rod has been cut and shortened, they will install the OE replacement tie rod which will not work and the vehicle cannot be properly aligned. That is just one reason why a dropped rack and pinion is far superior. By dropping the steering rack the truck retains full OEM alignment specs, features a stock vehicle turning radius and retains the stock track width! This system even uses factory style cam plates and can be aligned to within factory specifications. ReadyLIFT even included details on the ideal alignment specs to prolong tire life and increase the performance and handling both on and off-road. Run your stock wheels or most 17-inch or larger aftermarket wheels.
    Features:
    • Allows for up to 37-inch tires
    • Retain factory steering radius
    • Allows for use of factory wheels and spare
    • Retains factory pinion angles
    • Available in silver or black powder coat finishes
    • No weld design - direct bolt-on installation
    • Reduced weight windowed crossmember design
    • Heavy gauge laser cut & CNC-formed steel construction
    • Nodular iron knuckles engineered for perfect geometry
    • No cutting tie rods - CV axles and steering retain factory angles
    • Integrated differential drop and anti-torsion system
    • Includes performance valved SST3000 rear shocks
    • Qualifies for ReadyGuard PowerTrain Warranty
    • Includes Limited Lifetime Warranty
    Tire Fitment
    • 37-inch Maximum tire diameter
    • 37x12.50 for no rub on a 9-inch wide wheel with +25 offset
    • 18-inch - 37X12.5R18
    • 20-inch - 37X12.5R20
    • 22-inch - 325/60R22
    Applications: 2015-2019 Ford F-150 4WD
    Give us a Call for Pricing and a Special Deal on 440 358 5500
    May 2016
    Painesville Ohio
    1,121
    15899
    25 times
    Pm for more information
  1. Replies: 8
    Last Post: 06-22-2016, 05:06 PM
