2012 f150 surging
2012 f150 surging
This is a discussion on 2012 f150 surging within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; My 2012 f150 ecoboost is surging at approximately 1/3 throttle when the engine is not fully warmed up. Once the engine is warmed up it ...
  • 1 Post By noodles
Thread: 2012 f150 surging
    Rookie f150ecoboost's Avatar
    Nov 2017
    Lawton, MI
    49674
    2012 f150 surging
    My 2012 f150 ecoboost is surging at approximately 1/3 throttle when the engine is not fully warmed up. Once the engine is warmed up it goes away. It sounds like the waste gate is popping off when it does it. Any thoughts?
    Nov 2017
    Lawton, MI
    49674
    Here is a video of the problem.
    Ecoboost Regular TeamShine's Avatar
    May 2014
    Shreveport, Louisiana
    161
    5048
    34 times
    Came here to find the answer to this as well. Mine does this with and with out a tune. With a tune the problem is exacerbated and the truck shakes pretty bad. My RPMS flutter real bad and can hear waste gate or BOV cycling constantly. Mine did throw a flashing check engine light but the went off. I tried to check codes with X4 but it said there was no codes.
    Also mine does this even when the engine is warmedup.
    2011 eco with 115,000 miles.
    3,891
    Quote Originally Posted by f150ecoboost View Post
    Def seems like the wastegates are cycling. Check for possible bad vacuum hose, or suspect wastegate solenoids/connection. In the meantime, let it warm up.
    Cuervo likes this.
    Nov 2017
    Lawton, MI
    49674
    Update. I took my truck to the local Ford dealer last November and it was determined that the waste gate on the right hand turbo was stuck closed. They replaced the turbo and the noise went away. Unfortunately, now I have new noises. Now it is buzzing while under moderate to heavy throttle. It also had a loss of power. I took it to the dealer again and they corrected a couple vacuum leaks which seems to have corrected the loss of power but the noise remains. I replaced the solenoids to the waste gates on both sides thinking that they may be the culprit. This did not correct the problem.
  1. 1800 - 1900 rpm surging with tune
    By aj.n.amber in forum F150 Ecoboost Problems
    Last Post: 07-12-2017, 06:56 PM
  2. 2012 F150 ecoboost surging during acceleration
    By JST4FN in forum F150 Ecoboost Problems
    Last Post: 08-31-2016, 11:53 PM
  3. 2011 EB Surging / Hesitating
    By Cutlass454 in forum F150 Ecoboost Problems
    Last Post: 08-31-2016, 12:18 AM
  4. Replies: 14
    Last Post: 11-17-2015, 09:36 AM
  5. Replies: 24
    Last Post: 09-09-2014, 01:41 PM
2011 f150 ecoboost surging forum
2012 f150 surging issue
