oil line on passenger side turbo is leaking, is that line attached with the visible
This is a discussion on oil line on passenger side turbo is leaking, is that line attached with the visible within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Nut or does it attach with some sort of keeper. Basically if I wanted to remove the oil line do you unscrew the nut or ...
Results 1 to 2 of 2
    Ecoboost Jr Member 70 torino's Avatar
    Feb 2017
    Utah
    20
    28977
    Nut or does it attach with some sort of keeper. Basically if I wanted to remove the oil line do you unscrew the nut or is it pressed in with a metal ring or something? I saw a picture of a new uninstalled turbo and it had that not on the turbo without a line. My 2013 is leaking there and burning the oil on the turbo. I was going to try and tighten the nut which looks about impossible because of the location but Im not sure that would do anything.??
    1,150
    416 times
    It should be just a nut with the end of the oil tube that fits into the inlet on the turbo. If you tighten it, it may fix the issue.
  1. Need help and please! Broken oil cooler line
    By Quinnford in forum F150 Ecoboost Problems
    Last Post: 08-17-2017, 05:58 AM
  2. Leaking water over passenger side turbo..
    By prorider17 in forum F150 Ecoboost Chat
    Last Post: 01-15-2017, 03:58 PM
  3. Passenger Side Turbo Ring Removal
    By MidnightMatador in forum 2nd Gen F150 Ecoboost
    Last Post: 05-26-2016, 08:07 PM
  4. Discovered oil on passenger side bottom
    By Kbuicker in forum F150 Ecoboost Problems
    Last Post: 01-14-2016, 12:41 PM
  5. Exhaust leak passenger side turbo
    By stovall977 in forum F150 Ecoboost Maintenance
    Last Post: 01-08-2016, 02:51 AM
2011 ford f150 water leak passenger side
ecoboost turbo oil line
news
