Squealing under boost from passenger side
This is a discussion on Squealing under boost from passenger side within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; My truck just developed a loud squeal when I step on the gas. This only happens under boost and when cold. I recently added an ...
Results 1 to 10 of 13
Thread: Squealing under boost from passenger side
    Ecoboost Jr Member Rds912's Avatar
    36
    64474
    My truck just developed a loud squeal when I step on the gas. This only happens under boost and when cold. I recently added an oil cooler and transmission cooler but that should have zero effect. It started after I towed my trailer up steep grades in 110 degrees. Never had it overheat though. Any thoughts?
    Ecoboost Pro Boostking's Avatar
    Jun 2015
    Florida
    790
    12619
    872 times
    Are you saying you hear it when the engine is cold, and you hear it when its warmed up and you step on the gas?
    Could you have a belt/pulley issue?
    2013 Tuxedo Black SCrew Ecoboost FX4 w Appearance Package 5.5 box, 3.73. Mods: SCT LWTS+ custom tuned, Full-Race/BorgWarner OEM+ "GT Turbos", Tifosi Exhaust Manifolds, RTR HPFP, CP-E FMIC w/ TurboSmart SuperSonic, CP-E 3" Catted Downpipes, AFE Magnum Force Pro Dry-S Intake, Borla Touring Cat-Back, Terra G2s 305/55/20 on Method N/V 20x9, Leveled Bilstein 5100 RHA 1.5", 20" LED light bar, Hellwig Rear Sway Bar, Morimoto LED Fogs, Extang Revolution Tonneau Cover, Custom LED bed lighting, DeeZee Tailgate Assist, Tailgate Remote Power Lock Mod, MaxLiner Floor Mats, Ford OEM Underseat Cargo Box, LED Interior and Reverse Lights (Diode Dynamics), Recon LED 3rd Brake Light, NL Door Detents, .50 cal antenna, Custom Coding (ForScan)
    AB
    324
    36866
    143 times
    sounds like a warped exhaust manifold. Pretty common...especially after working the engine hard towing like that. They are a notorious weak point and the leak closes up a bit when everything expands once warm. When it's cold you can really hear the turbo through the leak.
    noodles likes this.
    -2019 Open Range UT2504BH.
    -Sold: 2010 Funfinder 189FDS
    36
    64474
    Only when is cold.
    Ecoboost Veteran BRoell's Avatar
    Laguna Hills, CA
    322
    58762
    172 times
    Did it sound like an angry cricket, like this?
    Jun 2015
    Florida
    790
    12619
    872 times
    Quote Originally Posted by Rds912 View Post
    Only when is cold.
    If you are getting on the throttle hard under boost when its cold (engine), that's not very good for the engine. You may have caused damage to something. Can you get a video?
    It would be helpful if you posted a more in depth reply. I can't sit here and speculate all the possibilities.
    3,891
    Only when is cold.
    Without hearing your truck, I can't say for sure. But with your description, I would tend to believe it's probably a warped and leaking exhaust manifold.
    36
    64474
    Angry cricket...........perfect description. I was camping and tried to post a video, but it wasn’t happening. When I got back to town I took it to the dealer. Exactly what most of you suspected, an exhaust manifold. Thanks for the replies....
    Ecoboost Veteran Burns363R's Avatar
    Iowa
    306
    6432
    58 times
    Is there a better manifold that wont warp?
    12' F-150 SCREW, FX4, 3.5TT, CRP Manifolds/SPD Turbo Adapters/MBRP Offroad DP/AFE Intake/170 tstat/CP-E intercooler, 3.73 gear, 33" Duratrac
    3,891
    Quote Originally Posted by Burns363R View Post
    F-150 EcoBoost 3.5L Full Bore Performance Manifolds Now In Stock ? CR Performance Engineering
    CRP Engineering likes this.
  1. Boost leak/hissing on passenger side
    By hammonds42 in forum F150 Ecoboost Problems
    Last Post: 06-30-2018, 10:13 AM
  2. Resolution to "squealing noise"!!
    By kittrell87 in forum F150 Ecoboost Problems
    Last Post: 06-04-2018, 09:03 AM
  3. Squealing cooling fan-2.7
    By mwemaxxowner in forum F150 Ecoboost Maintenance
    Last Post: 05-24-2016, 09:00 PM
  4. Catch can after 4K miles, passenger side
    By strongarm18 in forum F150 Ecoboost Chat
    Last Post: 04-18-2014, 09:25 AM
  5. squealing sound?!?!?
    By spence08 in forum F150 Ecoboost Performance
    Last Post: 01-07-2014, 08:38 PM
