P0299
P0299
This is a discussion on P0299 within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; I did a decent amount of searching before posting.. Had this issue traveling up to Georgia about a month ago. Iím tuned but otherwise stock. ...
Results 1 to 10 of 14
Like Tree11Likes
Thread: P0299
    Ecoboost Sr Member avwizz's Avatar
    50
    15491
    26 times
    P0299
    Had this issue traveling up to Georgia about a month ago. Iím tuned but otherwise stock. I wasnít towing anything, but did notice the CEL came on and I read the code (p0299). I cleared it to see what would be happening when it came back on again. Eventually it did however nothing big happened. I did a little searching and pointed at a possibility of a solenoid (I believe) was a starting point to check. Theyíre cheap so I replaced it.
    Fast forward to tonight. Weíre traveling on the highway home with our TT and I notice it just wonít go past 6psi regardless of gear and struggling to keep 70. No CEL however. I pull over and restart the truck thinking some computer has gotten jammed up or something. Restart and go and all the power is back, hitting 18 psi getting up to speed no problem. About 5 minutes in same thing but this time it throws the P0299 code and weíre back to about 5.5 psi max.
    Thoughts on where to look next? I donít imaging itís a leak somewhere (but havenít checked) since why wouldnít it limit the boost all the time? Could I have just one side of the turbos going bad?
    3,898
    1738 times
    P0299 is an underboost code, caused by your turbos not being able to produce/hold the desired boost as commanded by the PCM.
    Mostly happens when under load. Especially noticeable when towing.
    I'd start with checking intake pipe connections and vacuum lines.
    Ecoboost Sr Member hammonds42's Avatar
    May 2018
    Indiana
    75
    62673
    23 times
    Following. Currently have the same issue. Replaced solenoid on top of intake with no difference.
    Sent from my SM-G955U using Tapatalk
    50
    15491
    26 times
    Quote Originally Posted by hammonds42 View Post
    I did that a couple weeks ago and did not solve the issue however I did swap out the EBOV today and will be towing tomorrow to see if that took care of it. Mine did end up having a tear in the orange membrane. We shall see.
    Mikedick77 and bespurcell like this.
    512
    127 times
    I'd be pretty optimistic that you solved the issue with that if I were you. Let us know. You may end up helping the next guy that comes along.
    noodles likes this.
    50
    15491
    26 times
    I got to take the TT out today for about 60 miles and no issues. Looks like that solved the issue.
    Sent from my iPad using Tapatalk
    hammonds42, Mikedick77 and noodles like this.
    3,898
    1738 times
    Quote Originally Posted by avwizz View Post
    That tear would definitely cause a boost leak, especially under heavy load.
    Glad you got it sorted.
    west coast mountains
    4,778
    1740 times
    Same thing I had in my old 2013 3.5, made a huge difference after I replaced it
    50
    15491
    26 times
    Quote Originally Posted by Sirikenewtron View Post
    Iím not sure about you but it took care of my stumble on acceleration issue too. I wanted to drive a bunch to make sure that wasnít just my imagination but itís back to silky smooth.
    Sirikenewtron and Mikedick77 like this.
    4,778
    1740 times
    Very nice.
    Mine mainly just felt sluggish off the line bit once I found the tear and replaced it it was back to spinning tires
  1. P0299 code when towing
    By ArAggie in forum F150 Ecoboost Problems
    Last Post: 09-27-2016, 11:17 AM
  2. P0299 underboost code
    By Cburman in forum F150 Ecoboost Maintenance
    Last Post: 07-27-2016, 07:53 AM
  3. DTC Codes P0304, P0306, P0299, P2629, P0300, P2198
    By shiner-bock-beer in forum F150 Ecoboost Chat
    Last Post: 05-12-2016, 08:34 AM
  4. P0299
    By kFirm in forum F150 Ecoboost Problems
    Last Post: 03-25-2015, 07:27 PM
2011 f150 p0299
2013 f150 p0299 code
