Turbo leaking oil and making "Owl hooting" noise coming off boost. - Page 2
This is a discussion on Turbo leaking oil and making "Owl hooting" noise coming off boost. within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; You have two different problems if it leaking oil and making that noise, I think, donít shoot the messenger, please. 2012 Screw 3.5L...
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 70
Like Tree18Likes
Thread: Turbo leaking oil and making "Owl hooting" noise coming off boost.
    Ecoboost Pro waterbuffalo's Avatar
    946
    22266
    365 times
    2012 Screw 3.5L
    Ecoboost Jr Member Calg_Rider's Avatar
    47
    3770
    Yeah, the oil is on the outside so I think the seals are on there way out. Hooting noise might be just a symptom of a larger issue.
    2013 Ruby Red FX4 Ecoboost 5.5 box Crew with Max Tow Package
    497
    122 times
    Quote Originally Posted by Calg_Rider View Post
    So your thinking likely just the air management issue - wastegate or bov? I was also until I saw the oil on the unit. If as suggested the oil is "normal" then yes I will likely look into replacing the wastegate since the bov is already done.
    That's where common sense tells me to go with it, yes. Plus I always start with the "costs less" stuff first before making a large unnecessary purchase and regretting it later. Some of that only costs you time. Might help to get an ear by that system, and have someone throttling it up and down while you listen. Found a few exhaust leaks that way.
    Ecoboost Master ptown's Avatar
    1,453
    629 times
    Itís a little difficult/different when itís not under load. I thought the same thing but never could get the same sound with it sitting there in park or neutral
    Rookie Clonetrooper334's Avatar
    Oct 2018
    67920
    I just bought a 2011 F150 Ecoboost. The turbo and block were replaced in Aug. due to a failure, so they are Ford's updated replacement... My system makes the same "hooting" noise when you let of the throttle under movement. Dealer said it was a normal noise....?
    47
    3770
    I think thats crap. I never heard it on the first 80000 km and it only started after the left side turbo was replaced.
    Not happy with FORD right now. Opened a case with Ford Canada and they insist on having a diagnostic done again at a Ford dealer even though I have photos of the leaking turbo. I get it to a point so I did what was requested. Dealer comes back with no faults found, drives and sounds normal and NO LEAKS. I even forwarded the email from the other garage showing pictures of the wet turbo. I am at a loss now. I really wish the problem would come on and stay on but its so inconsistent its crazy. Oh, and I am not seeing much around for just a wastegate swap for the 13-15 models unlike the 11-12 years so that option may not be easy. My other thought was a boost control solenoid. That I could see as a possible intermittent failure item.
    Rookie Hoot Owl's Avatar
    Jan 2019
    12
    69524
    I have a ‘13 screw limited making the same hooting noise while gently backing off the throttle. I have had he truck since March of ‘18 with 82,000 miles. Over the summer, I installed an AFE stage 2 intake and the x4 controller. Everything was great till about 2 months ago when the noise started. No drop in boost, vacuum or performance. I replaced the BOV with a new OEM BOV, and no change. It is intermittent, and I can not duplicate it on demand. I tried to find the waste gates, but ran into the same thing. They are available for the ‘11 and ‘12’s, but not ‘13 and up. I just bought the turbo bypass valve solenoid. One of the other posts I read, recommended replacing that around 100k miles.
    Rookie Astarcev7's Avatar
    Jan 2019
    NJ - North
    12
    69512
    I'm having the same thing happen to my 2013 now. I'm leaning towards a bad/failing wastegate and/or turbo. Always said if one failed I would replace with either the BW or Full Race turbos, looks like I need to place an order on Monday
    Jan 2019
    12
    69524
    I replaced the turbo bypass solenoid and it seemed better for about 20 miles......then I heard the noise again. I’m starting to think wastegate also. Dealer says about $1200 roughly for a pair, but they are remanned. I would rather go with Full Race or Garrett, but they are $2300. Ugh....this ones gonna hurt!
    Ecoboost Regular pvtschultz's Avatar
    Aug 2015
    New Berlin, WI
    148
    13132
    39 times
    Read the thread in my signature. The hooting is a very easy fix, just a bit of a annoyance more than anything. The first thing that I would inspect is the vacuum check valve between the intake manifold and vacuum reservoir. The BOVs need vacuum to actuate and will fart, quack, or hoot if there isn't enough vacuum to quickly pull on the diaphragm. From there, I would check the BOV diaphragms and also the plastic bore that the plunger rides in.
    https://www.f150ecoboost.net/forum/31...irmed-fix.html
    2011 F-150 FX4 EcoScrew 3.73:1
    2" Easy Lift in front, Raptor Blocks in the rear
    295/75R17 Cooper ST-MAXX (Absolutely love them)
  1. Replies: 5
    Last Post: 03-01-2018, 08:33 AM
  2. Replies: 1
    Last Post: 02-14-2018, 07:49 AM
  3. Replies: 1
    Last Post: 01-10-2018, 04:34 PM
  4. Please look/listen - exhaust leaking water and chatter noise?
    By FiremanDan in forum F150 Ecoboost Problems
    Last Post: 02-04-2016, 05:55 PM
  5. Explorer Sport EcoBoost Turbos making weird noise LOSS of power
    By xsport in forum F150 Ecoboost Problems
    Last Post: 10-06-2014, 12:51 PM
