Turbo leaking oil and making "Owl hooting" noise coming off boost. - Page 7
This is a discussion on Turbo leaking oil and making "Owl hooting" noise coming off boost. within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Thanks for the offer. My 2016 has only a single control solenoid and I've bought one as swapped it without change. My WG actuators hold ...
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 71
Like Tree20Likes
Thread: Turbo leaking oil and making "Owl hooting" noise coming off boost.
  1. #61
    AB
    320
    36866
    140 times
    Thanks for the offer. My 2016 has only a single control solenoid and I've bought one as swapped it without change. My WG actuators hold pressure throughout the system(mightyvac vacuum pump). Did you seal anything else up? My pressure control system and plumbing seems perfect.
    Once I got my aftermarket WGs all sealed up, mine stopped having the issue.
    I have a WG solenoid that’s good if either of you want to try it.
    -2019 Open Range UT2504BH.
    -Sold: 2010 Funfinder 189FDS
  2. #62
    1,868
    1043 times
    Quote Originally Posted by TCP2 View Post
    My WG solenoid and system should be same as yours except for the TurboSmart WG's.
    Too bad to hear that your's is still acting goofy. Everything that I've been able to gather is that the WG's hyper cycle when they are trying to achieve desired boost.
    I'm still open to putting another set of eyes on it, if you like.
  3. #63
    AB
    320
    36866
    140 times
    Now that it's warmed up (a bit) the noise is again at a minimum, but definitely not gone. I appreciate the offer, just living with it for this summer. Maybe take up the quest again in the fall when things cool and the noise increases. Enjoy the riding season.
  5. #64
    1,868
    1043 times
    If it get's worse or you change your mind, just shoot me a pm. Enjoy the summer, it's finally warming up!
  6. #65
    AB
    320
    36866
    140 times
    Going down a new path here. After reading this thread, it seems like this may also be a possibility. I will drop the pan and torque all the bolts on the valve body.
    https://www.f150ecoboost.net/forum/3...000-miles.html
    found the specsvalve body torques.pdf
  7. #66
    Ecoboost Sr Member Calg_Rider's Avatar
    50
    3770
    Is your truck a 2011 - 12. From my research for 2013 and up you cant buy a direct fit part for a WG swap.
    2013 Ruby Red FX4 Ecoboost 5.5 box Crew with Max Tow Package
  8. #67
    1,868
    1043 times
    Quote Originally Posted by Calg_Rider View Post
    I have a 2014. From Ford, no you can't buy just the WG's. But you can buy replacements from TurboSmart, they bolt right in.
    For 2013-14, you would need the IWG-75 with a 5psi spring.
    Calg_Rider likes this.
  9. #68
    1,150
    416 times
    How hard are they to replace? If you take off your wheel well liners they should be right there?
  10. #69
    1,868
    1043 times
    I just get at them from the top-side. It's only loosening off the jam nut and the two nuts that mount the WG to the bracket.
    If you were pulling the liners for other reasons, it would for sure be easier from the side.
  11. #70
    1,150
    416 times
    Cool thank you sir! I figured it was pretty easy but then again it doesn't hurt to ask lol
    Blown F-150 likes this.
  1. Replies: 5
    Last Post: 03-01-2018, 08:33 AM
  2. Replies: 1
    Last Post: 02-14-2018, 07:49 AM
  3. Replies: 1
    Last Post: 01-10-2018, 04:34 PM
  4. Please look/listen - exhaust leaking water and chatter noise?
    By FiremanDan in forum F150 Ecoboost Problems
    Last Post: 02-04-2016, 05:55 PM
  5. Explorer Sport EcoBoost Turbos making weird noise LOSS of power
    By xsport in forum F150 Ecoboost Problems
    Last Post: 10-06-2014, 12:51 PM
