Turbo leaking oil and making "Owl hooting" noise coming off boost. - Page 8
This is a discussion on Turbo leaking oil and making "Owl hooting" noise coming off boost. within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Update: I dropped the pan and checked the torque of the bolts. They all seemed fine. I replaced about 7 quarts of fluid and added ...
Page 8 of 8 FirstFirst ... 678
Results 71 to 77 of 77
Like Tree21Likes
Thread: Turbo leaking oil and making "Owl hooting" noise coming off boost.
  1. #71
    AB
    336
    36866
    152 times
    Update:
    I dropped the pan and checked the torque of the bolts. They all seemed fine. I replaced about 7 quarts of fluid and added the dorman transmission pan with the drain bolt. The noise is still there, so my plan in the last post didn't change anything with the noise. Fresh fluid never hurts though.
    https://www.amazon.ca/Dorman-265-854...72923836&psc=1
    -2019 Open Range UT2504BH.
    -Sold: 2010 Funfinder 189FDS
  2. #72
    Ecoboost Sr Member Calg_Rider's Avatar
    52
    3770
    So still have this issue nagging at me. Before spending the cash on the new parts I was thinking I would reset the preload on the factory wastegates. Did you try that before replacing? If so did you go 2 or 3 turns?
    2013 Ruby Red FX4 Ecoboost 5.5 box Crew with Max Tow Package
  3. #73
    52
    3770
    I just get at them from the top-side. It's only loosening off the jam nut and the two nuts that mount the WG to the bracket.
    If you were pulling the liners for other reasons, it would for sure be easier from the side.
  5. #74
    1,925
    1101 times
    Quote Originally Posted by Calg_Rider View Post
    3 turns according to my Ford tech buddy
    I see that Full race now sells OEM replacement Wastegates, pretty awesome if you ask me.
  6. #75
    1,206
    446 times
    Thanks for that! Just told @Calg_Rider there was no oem WGs
  7. #76
    1,925
    1101 times
    I just saw them on the site a couple weeks ago. Pretty nice to finally have the option.
  8. #77
    Rookie JF258's Avatar
    Jul 2019
    72266
    Did resetting the factory preload fix your problem?
    I replaced drivers side turbo and this started as well. I did the timing chain and phasers. No change with the noise coming from turbo. Hoping someone has had some luck in finding a fix. Seems like it is talked about a lot but then the conversation just ends with no answer.
  1. Replies: 5
    Last Post: 03-01-2018, 08:33 AM
  2. Replies: 1
    Last Post: 02-14-2018, 07:49 AM
  3. Replies: 1
    Last Post: 01-10-2018, 04:34 PM
  4. Please look/listen - exhaust leaking water and chatter noise?
    By FiremanDan in forum F150 Ecoboost Problems
    Last Post: 02-04-2016, 05:55 PM
  5. Explorer Sport EcoBoost Turbos making weird noise LOSS of power
    By xsport in forum F150 Ecoboost Problems
    Last Post: 10-06-2014, 12:51 PM
