2012 F150 Ecoboost Turbo surging
This is a discussion on 2012 F150 Ecoboost Turbo surging within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; My truck is making some weird noises when I am traveling around 70 mph. I have the stage 2 AFE intake on it. I don’t ...
Results 1 to 6 of 6
    Rookie Chacemullin's Avatar
    Dec 2018
    69388
    My truck is making some weird noises when I am traveling around 70 mph. I have the stage 2 AFE intake on it. I don’t know what is causing this noise to occur. I have a video but cannot upload it here. I can email it to you if need be.
    I was just seeing if anyone else was experiencing this weird turbo surge. I have no clue what to do to fix it, may get it tuned or go back to stock cold air intake. Any thoughts? Thank you
    6,550
    2623 times
    Upload it to YouTube then link it.
    Gold Supporting Member RedRooster's Avatar
    May 2017
    799
    35105
    529 times
    How long since plugs been changed? If more then 20,000 miles...replace. Pull all three sensors and clean. Clean throttle body. KAM reset. Do a Throttle Position Re-learn. Are you showing misfires when you pull codes?
    PaPa's Truck....Her name is "Candy".....2012 Lariat SCREW....Red Candy Metalic....has a couple of mods for fun!☺
    FR CAI, FR Catted DP, FR Cat Back Exhaust, FR CAC, BBK TB, CRP Performance Manifolds, SPD Ported Adapters, Turbo Smart BOVs, SCT LiveWire TS+, Unleashed Tuned, UPR DV/MCC/CSS, UPR Billet Crank Breather Valve, MSD Red COPs, SP 542s @ 0.027, Reische 170* T-Stat, Bilstein 5100s x 4, PowerStop Z36 x 4, MGP Red Caliper Covers, Diode Dynamics-interior Blue, Husky Liners & Guards, Chrome - lottsa Chrome, Dif. 3.31, Tires - Stock, a few other goodies.......😎
    Rookie ls1curt's Avatar
    Aug 2018
    66678
    I have a similar issue. Most notable when converter is locked up going up a hill. Truck is all stock. Have not been able to find the cause.
    6,550
    2623 times
    Waste gate solenoids are known to ****. BOV diaphragms are known to tear. Are you guys bleeding boost when you hear this noise?
    Ecoboost Regular pvtschultz's Avatar
    Aug 2015
    New Berlin, WI
    148
    13132
    39 times
    Is it a surge, or more like a misfire? Classic BOV related issue will be 6th gear, TC locked, and going from a downhill coast to a slight incline where you are rolling into the throttle. The BOVs (bypass valves) will not seal up and you'll lose power and it will often hiccup for some reason (probably a surge). Related will be quacking, farting, groaning, etc especially when driving around town. The root cause is often PCV gasses contaminating parts of the bypass control circuit.
    - Check/replace at a minimum the two bypass solenoid valves at the turbos (there is a third for waste-gate control but has not been a problem IME).
    - Check bypass valve diaphragms for tears.
    - Check bypass valve plastic cover for wear in the bore where the plunger rides. Applying a light coat of white lithium grease seemed to help.
    - Check/replace vacuum check valve at intake manifold.
    - Clean both MAP sensors.
    - Check that the PCV line going to intake just after air cleaner is connected/snug (don't ask me why, but it seemed to cause me a problem when fell off).
    https://www.f150ecoboost.net/forum/3...irmed-fix.html
    https://www.f150ecoboost.net/forum/31...irmed-fix.html
    2011 F-150 FX4 EcoScrew 3.73:1
    2" Easy Lift in front, Raptor Blocks in the rear
    295/75R17 Cooper ST-MAXX (Absolutely love them)
  1. 2012 f150 surging
    By f150ecoboost in forum F150 Ecoboost Problems
    Last Post: 01-20-2019, 06:00 AM
  2. 2011 F150, occasional boost 'flutter' / surging.
    By pfbz in forum F150 Ecoboost Performance
    Last Post: 12-02-2017, 06:10 AM
  3. 2012 F150 ecoboost surging during acceleration
    By JST4FN in forum F150 Ecoboost Problems
    Last Post: 08-31-2016, 11:53 PM
  4. 2011 EB Surging / Hesitating
    By Cutlass454 in forum F150 Ecoboost Problems
    Last Post: 08-31-2016, 12:18 AM
ecoboost f150 weird noise from turbo
