Two issues - Page 2
Two issues
This is a discussion on Two issues within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Originally Posted by Elmore328 Have you ever played around with FORSCAN that you could have accidentally turned off the white line feature? Nope. As much ...
Results 11 to 20 of 24
Like Tree16Likes
Thread: Two issues
    Ecoboost Veteran GDSQDCR's Avatar
    Nov 2014
    Pleasant Hill, CA
    420
    7165
    113 times
    Quote Originally Posted by Elmore328 View Post
    Nope. As much as I want to modify the truck, I have stayed away from that for now. It is under warranty still, and I do not want to screw that up. I only have another 58K miles roughly, so less than 2 years before I can start modifying it.
    2015 3.5 SCREW FX4 Lariat
    3,973
    3210 times
    Quote Originally Posted by GDSQDCR View Post
    Wish I could leave things alone.
    I could TELL myself that I'm not going to "modify", but I already know I'd have lied.
    I think I lasted 15 minutes with my RV, for example. (something the warranty screams to be protected) Hauled it home and went straight for the screw gun and immediately "remodeled" the bedroom and dining room.
    Made a pile in the driveway to be burned.
    Hope you find your white lines.
    (shame on him for pointing it out. Lol)
    3,524
    1814 times
    Yea......keeping the truck stock?, umm....well, err-thats a problem-lol
    This works for me periodically......
    855
    279 times
    The best part of that photo is the fact that it's on a winch!
    9,207
    3614 times
    Quote Originally Posted by meaz93 View Post
    I installed my intercooler while I was repairing a coolant leak. It was my "new radiator".
    2016 2.7 4x4 screw
    meaz93 and Elmore328 like this.
    Ecoboost Veteran mj0528's Avatar
    442
    57273
    45 times
    I've gotten a few things approved that way. Lol
    damn the luck honey, that's gonna have to be replaced. I've used that probably a little much that she's a little Keen to it now
    Ecoboost Jr Member Jeep Shadow's Avatar
    Hastings, MN
    46
    5313
    19 times
    So two issues have popped up recently. I will be taking it to the dealer for repairs but am curious as to potential causes.
    2015 Lariat CC fx4 with max tow. 67k miles.
    1. When I put the truck in reverse, my red, yellow and green lines show up but the white lines that move are not there. I went I got the settings and toggled the button for rear park aid on/off but there was no change.
    2. I do not have rain sensing windshield. With my wipers in the off position, they periodically operate like I am in the intermittent mode. If I turn them back on, wait a couple and then turn them off, they stay off.
    Thought on either of these issues?
    Thanks!
    Anthony
    The lines are not in the park aid on my 13'. You need to turn on what says "guidelines". Park aid is the audible beep. I know this on mine because I don't like the lines. But, every time I change program it adds them back in.
    Gold Supporting Member radtekjeff's Avatar
    Niceville, FL
    64506
    Battery
    Thanks!
    Anthony
    I had my battery tested after my 2017 F150 Eco Lariat continually/intermittently going into sleep mode. The 1 year old Motorcraft battery tested good. I still felt like the battery was not up to par. I replaced it and no more issues.
    Niceville, FL
    64506
    I had my battery tested after truck intermittently going to sleep. It tested good but issues continued. I replaced the 2 year old Motorcraft battery and no issues since.
    Nov 2014
    Pleasant Hill, CA
    420
    7165
    113 times
    Quote Originally Posted by radtekjeff View Post
    Things like this make me want to just go and replace the battery. It is only $145 for an interstate. I may go this tomorrow ... the truck is scheduled to go in on Monday to the dealer.
  1. two puddles under turbos
    By shane in forum F150 Ecoboost Problems
    Last Post: 01-29-2015, 06:36 PM
  2. Two step??
    By Boostnf150 in forum F150 Ecoboost Performance
    Last Post: 06-17-2014, 06:21 PM
  3. two things! new guy here and picture upload
    By mbriones in forum Introductions
    Last Post: 03-01-2014, 09:12 PM
  4. Not even two months... Rear ended this am going to work
    By Beez in forum F150 Ecoboost Chat
    Last Post: 07-19-2013, 10:47 PM
