After install Catch can results
This is a discussion on After install Catch can results within the F150 Ecoboost Problems forums, part of the F150 Ecoboost Forum category; Hey ya’ll my truck is a 2014 with 88,800 miles on it all stock. Last week installed the UPR mega catch can and after a ...
Results 1 to 10 of 27
Like Tree17Likes
Thread: After install Catch can results
    Rookie ILFAB's Avatar
    7
    66010
    Last week installed the UPR mega catch can and after a week of driving 486 miles later I drained the can and almost got a full 16oz of murky water oily crude out of it.
    Is this normal or a problem?
    Thanks all.
    ILFAB
    Ecoboost Jr Member BrianSomething's Avatar
    Feb 2018
    33
    56969
    Quote Originally Posted by ILFAB View Post
    Thanks all.
    That's what it's designed to do. Nasty looking crap. I still gotta put mine on. Bought it off a member here almost a year ago. The big question though is, "what recipe are you using it in with the insta-pot"?
    Ecoboost Veteran D0ncH's Avatar
    Nova Scotia, Canada
    484
    24850
    141 times
    It's normal dude. Especially this time of year when its colder out. The can will be colder and therefore more of the water in the air will condense in the can. Also, if you live in an area that is humid everything compounds and you get more fluid in the can.
    I have the upr dvcc and the clean side separator. I don't get much water in mine mostly oil/gas mix but it's probably due to living in Canada where it's less humid
    ILFAB likes this.
    2017 2.7L Bronze Fire 4x4 3.55 145" | Gearhead Tune | UPR DVCC + CSS | Ford Performance Super 8.8" LSD | Hellwig front/rear sway-bar | 12Volt Solutions Remote Starter | Ford Tri-fold tonneau cover | Line X bed liner | Huskey front/rear mud guards & rear wheel well liners | AVS Aeroskin hood shield | Rear block removed
    Rookie Haden8357's Avatar
    Feb 2019
    Georgia
    6
    69998
    Iíve also got the UPR, mine does the same thing except itís 98% oil/gas and Iím down south in Georgia
    7,556
    3289 times
    Normal, especially right after you install the can.
    ILFAB likes this.
    823
    258 times
    Just be sure to dump it every few hundred miles. If the can freezes, wait for a long drive where everything gets up to temperature, the hot gasses will melt the ice that can form inside the can. You can then fully dump the contents.
    ILFAB likes this.
    Nova Scotia, Canada
    484
    24850
    141 times
    Quote Originally Posted by Haden8357 View Post
    Interesting, I would have thought you would get more water in the mix due to your location
    Feb 2019
    Georgia
    6
    69998
    If they load here was the first draining of mine truck had roughly 21k miles on it. Itís been on a year to the date of being on and weíre at 45k now draining every 1500/2000 miles I keep it logged in my notes
    ILFAB likes this.
    823
    258 times
    Wow, mine is mostly water condensate like the OP. Being that dark do you check your oil level regularly?
    7
    66010
    Hey thanks everyone! I was just shocked by the amount in such a short time since the install.
    Sure glad I went for the mega can with clean side separator!
    ILFAB
  1. Catch can results after 3 weeks.
    By jag1886 in forum F150 Ecoboost Chat
    Last Post: 03-20-2018, 09:49 AM
  2. Catch can results after 2 days.
    By Brewman in forum UPR Products
    Last Post: 08-28-2014, 11:03 AM
  3. Catch Can results... 1588 miles and it's full!
    By jtzeke in forum F150 Ecoboost Chat
    Last Post: 02-13-2014, 10:01 AM
